Kinda an odd problem about my 12V battery-cables
Discussion in 'Gen 2 Prius Main Forum' started by priuslyfe, Feb 1, 2026.
  1. dolj
    dolj Senior Member
    8,490
    4,309
    Wellington, New Zealand
    Oh my!
    How have you routed the jumper cables?
  2. PrimalPrius
    PrimalPrius Junior Member
    53
    America
    They just run on the floor on the right side of the pass seat. It's a "temporary" arrangement. (I don't have any rear seats or any rear interior panels at all to make more room for cargo, long story.)
    A wife would yell, but I don't have that problem.
  3. dolj
    dolj Senior Member
    8,490
    4,309
    Oh, you've run them back to the battery in the back?
    When said this up-thread:
    I interpreted you to mean the front jumper point, which a lot of people mislabel 'the battery in the front'.
    That makes more sense now.
  4. PrimalPrius
    53
    America
    Yes, the jumper cables run from a wrong battery that's in front of the pass seat to the back. (I forget what size battery, walmart sold it to me used for $20.xx+$10 core. They supposedly installed it in some car because the guy had to have a battery that night for an emergency and then the guy came back a few days later demanding a full refund because it wasn't technically the right battery.)
  5. Hayslayer
    Hayslayer Active Member
    432
    252
    Is there a reason you don't just install the correct battery?
  6. PrimalPrius
    53
    America
    Yes. My Prius. It would damage the stock battery in a day by draining the voltage too low when the car sits. I'm not going to invest in the correct battery until I have time to sort out the current drain.
    If I remember right, pulling the fuse for the locks reduced the drain. The button under the steering wheel effected it too, but my memory is a bit fuzzy.
  7. rjparker
    10,361
    6,486
    Not sure how this helps the Op who has a broken 12v main cable.
    There may be a connection through unorthodox junk box attempts to keep a Prius running.
    #47 rjparker, Feb 8, 2026 at 5:08 PM
  8. PrimalPrius
    53
    America
    He broke it because he has been disconnecting and reconnecting (the wrong) cable. Fixing the cable won't fix the reason why he has been disconnecting the battery.
    I mentioned the arrangement I'm using to make disconnecting the battery easy because 1) no more broken cables 2) somewhere in the thread OP mentioned considering changing the battery location to make disconnects easier.
    (No part of the rear works for me personally because the car if often loaded with cargo, making the manual hatch release very cumbersome to reach and sometimes impossible to reach).
  9. priuslyfe
    priuslyfe Member
    249
    61
    UPDATE:
    Fixed the cable. Used the Home Depot part above (retail: Commercial Electric (526 936), Aluminium, #14Sol/Str - #2 Str Splicer/Reducer Connector). Worried about resistance in cable if crimping wasn't perfect. Once I was informed that high-voltage doesn't travel through the positive-cable I was much more relaxed about the fixing the car myself. About a 10 minute job and left some slack in the black cable in case something goes wrong and it needs to be fixed again. the Prius DCDC Codes automatically were removed once proper charge was going through the cable.
    THANKS AGAIN!
  10. rjparker
    10,361
    6,486
