Fuel Blasted Out As I was Trying to Fill Up
Discussion in 'Gen 2 Prius Main Forum' started by qmanqman, Feb 6, 2026.
  1. qmanqman
    qmanqman Active Member
    439
    152
    CO
    Not sure what this means but here it goes.
    On my last tank (2 weeks maybe) my mpg dropped from 40-45 to 34-36. I've been using the Conoco that's on my way to work and also happened to be the cheapest in town (1.69-1.79/gal the last couple months). I thought maybe it was bad gas so I figured I'd try someone else next tank.
    I also looked at my maintenance records and noticed it has been 15,000 since an air filter change so I bought a new one. When I installed it I noticed what looked like mouse/rat droppings on the intake side of the filter. Now I'm thinking oh hell maybe I have a dead rat stuck in the intake duct which is messing with mpg . . . but I'm still gonna wait til next tank.
    Today I go to fill up on that "next tank" and the fuel nozzle immediately clicks off whenever I squeeze the trigger all the way. I finally found a slow speed that it would go in. I typically put in 7 gal on a fill up (from one blip on the fuel gauge) but this time I got up to 8+ and so I pull the nozzle out and gas comes gurgling out and spilled all over the ground. It looked like the gas inlet was burping over and over.
    So my question to y'all is "WTMF'ingH" is going on there? Car runs perfectly fine.
  2. dolj
    dolj Senior Member
    8,549
    4,341
    Wellington, New Zealand
    Maybe one of the air bleed lines in the EVAP system is blocked?
  3. ChapmanF
    18,501
  4. Mendel Leisk
    41,863
    The engine or cabin filter, just curious.
  5. pasadena_commut
    pasadena_commut Senior Member
    2,804
    834
    Southern California
    Best to go to another pump when that happens, and if they are all the same model nozzle at that station, go to another station. Sooner or later we all run into a nozzle that will do this. In some instances a problem nozzle will give a normal fill by putting the nozzle in upside down, or at least it will let in a few gallons. Best not to push it. You probably overfilled the tank using the slow method (you already knew it wasn't sensing right...) which is why it burped gas back out.
  6. qmanqman
    439
    152
    CO
    engine
  7. qmanqman
    439
    152
    CO
    ya that was my plan
  8. Hayslayer
    Hayslayer Active Member
    460
    265
    If you run the flow rate too low, the auto shut off on the fuel pump will not trigger correctly.
    That's one reason I avoid using the first latch setting on most handles. You just never know.
  9. pasadena_commut
    2,804
    834
    Southern California
    As in, it will overflow? I always use the lowest flow rate setting on the nozzle and have never observed an overflow like that. With the exception of the Prius I have also never seen an early shut off. That's more than 50 years of filling gas tanks, somewhere north of 1000 fill ups. However, it represents far fewer nozzles tested since I tend to use the same pump at whichever station(s) I am frequenting at the time.
  10. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    had it happen once
  11. qmanqman
    439
    152
    CO
    I never run the flow rate too low. I always squeeze the trigger fully and lock it in place. This time it would click off almost immediately. Over and over again. That's why I started flowing it slowly so I could get some gas in there. Took forever to fill up.
  12. ebikeman
    ebikeman Member
    116
    Northwest
    Sounds like a charcoal canister failure.
  13. qmanqman
    439
    152
    CO
    UPDATE: filled up yesterday with no issues. Weird.
  14. notspam3
    notspam3 Member
    91
    46
    Toronto
    2024 Prius Prime
    XSE Premium
    The fuel sits in a bladder inside the fuel tank. When you hit the button to release the fuel door, there's a solenoid that's supposed to release the bladder to let you put more fuel in the tank. If the solenoid fails to open you will have the problems you experienced.
    The work around is to close up the tank and lid and press the re-fuel button again. There should be a message on the dashboard saying "ready to refuel" after you hit the button.
    I had the same issue occasionally pop-up on my Camry Hybrid. It's a known issue. I had the issue pop up maybe 5/6 times in 8 years, mostly in cold weather. I suspected something freezing up and/or the cold affecting the solenoid operation.
  15. dolj
    dolj Senior Member
    8,549
    4,341
    While what you say might work on a Gen 2 Prius (where this thread is), I'm fairly sure there is no message that pops up saying, "Ready to fuel." There is no refuel switch either, there is just a fuel hatch release lever down by the seat front next to the driver's door.
    Rocket Man and Brian1954 like this.
