2008 Prius Muffler Hanger Rusted Away
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mike Axsom, Feb 10, 2026 at 4:29 PM.
  1. Mike Axsom
    Mike Axsom Junior Member
    Bargersville, IN
    Hello. I've searched and found options for when the hanger on the muffler itself is broken, but I'm missing the one that should be on the actual frame of the car. Are there replacement hooks out there or affordable options for the DIY'er? I'd rather not have to go to a muffler shop to get something welded on but will if that's the only option. Thank you all so much for any help.
  2. Mendel Leisk
    41,761
    The missing hanger was presumably welded to the car body? Can you weld? If so, I'd get some comparable round bar, bend to suit,, debur the end, weld it in. Putting it in position in the rubber connector would likely help to position it for the weld.
    I've never welded (apart from an abysmal attempt in high school shop, muffler shop would be my approach. :)
  3. hurricos
    hurricos Junior Member
    60
    Burlington, Vermont
    If you weld, don't do it poorly like I did.
    PXL_20260123_053005572.jpg PXL_20260123_061533778.jpg PXL_20260123_063917056.jpg
    fragglestickcar likes this.
  4. hurricos
    60
    Burlington, Vermont
    To complete my thought:
    I used 1/2" steel bar stock, cut into the metal and then heated it with a torch to get it to bend (since I don't have a brake press or anything like that). I got very lucky with the shape; I'm nearly certain that I'd have messed it up on second try.
    I used TIG, 3/16" electrode and pedal, ~50-110A, 1/8" filler rod. I used wayyyyy too much current, and the new stock was way too thick for how thin the sheet metal of the car is.
    This is my third time welding, ever, and the first time doing it to a car.
    If you can clean the area up and remove the muffler for a shop, they will have a very easy time welding in a hook for you from stock they have on hand -- the cleanup and staging part is most of their work.
  5. Mike Axsom
    Bargersville, IN
    Alas, I cannot weld. I was hopeful someone would point out a bolt-on hook option that I've been unable to locate on my own. Seems like maybe I should just pull the muffler, which is hanging on by imagination, and take it to the shop.
  6. hurricos
    60
    Burlington, Vermont
    Yeah, pulling the muffler and heat-shield (which I doubt is still present) will earn you some points with the shop you bring it to.
  7. Mendel Leisk
    41,761
    If it's not dragging, I'd just bring it in as-is. And if it is dragging, wire it up a bit. It's just needs a hanger, why break loose the flanged connections, you're just asking for leaks.
  8. hurricos
    60
    Burlington, Vermont
    The shop will need the space to do the new weld justice (working in that crevice is a pain with the muffler there; doable with MIG). The real value: if the muffler has been hanging on for a while my experience that exhaust joint is already leaking and the donut needs replaced.
  9. Mike Axsom
    Bargersville, IN
    It's beyond dragging although I do have it suspended with galvanized pipe tape. The inlet pipe is rusted completely free from the muffler body.
  10. Mike Axsom
    Bargersville, IN
    Thank you for the pictures. I wasn't sure where the hook had been until I saw yours. Doesn't look like a bad weld job as long as it holds.
