Denso vs. NGK 4912 Spark Plugs? Are Amazon or Rock Auto problematic for 'fakes'?
Discussion in 'Gen 3 Prius Technical Discussion' started by davekro, Feb 4, 2026.
  1. davekro
    davekro Active Member
    516
    75
    SF Bay Area, East Bay
    2013 Prius Plug-in
    I was wondering if it was worth it to consider using an equivalent spec'd NGK 4912 (ILKAR7B11) vs. the OEM choice of Denso SC16HR11(Toyota p/n 90919-01275)?
    Although Rock Auto lists four different NGK part numbers for the 2013 Prius, Chat Gpt says only the NGK 4912 (ILKAR7B11) matches the Denso/ Toyota Spec. and is of equal quality to the Denso SC16HR11. I understand that Chat Gpt, can make mistakes. But what seems to be the consensus of this NGK plug being of equal quality as the Denso?
    On Rock Auto, I see four different NGK Spark Plug part numbers listed as compatible for the 2013 Prius.
    NGK 4912 {Alternate Inventory Numbers: ILKAR7B11} $5.89 (O'Reilly's price $23.99! :eek:O )
    NGK 92274 {Alternate Inventory Numbers: LKAR7AHXS} $9.47
    NGK 93501 {Alternate Inventory Numbers: LKAR7BIX11S} $6.58
    NGK 94297 {Alternate Inventory Numbers: LKAR7BGP} $5.38
    Rock Auto- DENSO 3499 {Alternate Inventory Numbers: SC16HR11} $10.39
    O’Reilly’s and Autozone local stores Denso 3499 $17.99
    toyota.oempartsonline.com Lists Spark Plug - Toyota (90919-01275) for $14.49
    So, is the $5.89 NGK 4912 just as good as the $10.39 Denso at Rock Auto?
    Any worries of getting a 'fake' Denso from Rock Auto?
  2. Hayslayer
    Hayslayer Active Member
    434
    252
    I use RA quite frequently and have purchased dozens of sets of Denso plugs. Never had a counterfeit.
    Many people believe a spark plug is just a spark plug, but I also know I've never had a skip or miss after installing a new set of Denso plugs in a Prius.
  3. ASRDogman
    ASRDogman Senior Member
    7,718
    3,960
    You just can't trust rock auto any longer. I had used them in the past, and had no issues.
    But they are using more and more of the cheap chinese crap. Like pretty much everyone else, sadly.
    I ran ngk once because autozone didn't have the Bosch plugs. They only lasted a few thousand miles
    before they started missfiring. I replaced them with the Bosch plugs and haven't had any failures.
    Just check the box and make sure they aren't made in china. (y)
    Denso have been very good plugs. Getting they from the deal will cost a little more, but the chance of
    getting the cheap chinese copies, is pretty much zero. They last over 100,000 miles, how often do you think
    you'll need to replace them???
  4. Mendel Leisk
    41,764
    How much is the savings, say an inexpensive bottle of wine, every 12 years or 120k miles?
    I typically buy plugs from a local automotive place, a dedicated automotive place. With our ‘10 though, the Denso’s were $2~3 CDN per plug cheaper, through dealership. Worth a call.
    douglasjre likes this.
  5. indel
    indel Member
    246
    78
    Northwest Indiana
    Given their loooonnnnnggggg change interval, spark plugs is not the item to try to save money on. Buy it from the dealership. Last fall, I was able to buy some for $13 a piece with free shipping.
  6. PriuSocal
    PriuSocal Member
    282
    52
    SoCal
    Personally I have used RockAuto BUT although their pricing is below average, they get you in the shipping and you would think the more you order the better deal you get but thats def NOT the case as they practically charge you individual for every item. Now as for the spark plug question, I recently went with the NGK ILKAR7B11 which are currently at closeout price of $5.23 each. They are great and def authentic BUT I would steer clear of Amazon or Ebay as you are 99% to receive fakes (from personal experience). The prices are usually too good to be true (i.e parts store $10 each Amazon/Ebay $3 each) and even those at near parts store prices are still high chance of being fake.
    Wether you go NGK or Denso as long as they are Laser Iridium, you will be happy. Just dont get the cheaper options as priced may be tempting, stick to OEM directed Laser Iridiums.
  7. ASRDogman
    7,718
    3,960
    The cheap chinese copies say double iridium.... It doesn't mean they are....
  8. indel
    indel Member
    246
    78
    Northwest Indiana
    There are two main problems with rockauto:
    1. They do not have phone customer service
    2. If you order 2 or more parts, chances are they will be shipping from multiple warehouses causing multiple shipping fees. It's all B.S. to generate more revenue.
    I refuse to order from them.
  9. douglasjre
    douglasjre Senior Member
    2,198
    731
    Null, NL
