P0301 DTC, 210k mi. Still has Orig. plugs: Replace all Coils too?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by davekro, Feb 1, 2026.
Tags:
  1. davekro
    davekro Active Member
    516
    75
    SF Bay Area, East Bay
    2013 Prius Plug-in
    This is embarrassing. I have never changed the plugs in my wife's 2013 Prius Plug-In (purch. new 10/23). Her last trip to do errands, it jerked aggressively she said, one time when she was accelerating normally (straight). I scanned for codes. My Autel MK 808S shows 4 Faults, all P0301 Cyl. 1 Misfire detected (1 each as Pending, Current, Permanent, and History. I was aghast when I checked my service log, and saw that I had never changed the spark plugs (I see NOW, due at 120k!). So, of course I will be changing the plugs.
    Sounds like there is a decent chance that Cyl 1's coil may be bad. Chat GPT said after changing the plugs, swap Cyl. 1 & Cyl. 2's Coils, to see if the DTC moves to Cyl. 2. Good for troubleshooting the immediate failure, BUT.. Chat GPT mentioned that plugs with 200k+ miles, with worn wider gaps, "...causes Increased firing voltage demand on the coils. 120k–180k miles → common first failure. 200k+ miles → failure is not surprising at all. At 210,000 miles, original coils are officially on borrowed time. So yes — Cylinder 1’s coil being weak or failing is absolutely plausible.
    So should I just bite the bullet and replace all four coils, as they may all be on their last legs by the higher current demand they have been working harder than normal to supply to jump the wider gaps?
    Any particular Spark Plug brand(s) recommended, or brands to especially avoid?
    I see coils going for between $35 to $75, or even $125 each for Denso. On the other hand, I also see
    BDFHYK Ignition Coil Pack UF596 and Iridium Spark Plugs, set of 4 each for $47.69! #1 Best Seller, 4 stars, (4,300 reviews), 100+ bought in past month. That price seems WAY to cheap. Maybe those are shops buying, not DIY people putting them in their own cars??
    Any recommendations for quality Coils at reasonable prices? Are 4 plugs + 4 Coils kits worth even considering? I have only seen no-name combo kits.
    With the time involved to remove wipers, plastic and metal cowls, I want the replacement plugs and coil(s) if installed to last a long time. ;o)
  2. ASRDogman
    ASRDogman Senior Member
    7,723
    3,960
    383,000 plus miles on my original coils.....
    Have you just replaced the plugs? That would be the smart thing to do. Then see if you still get misfires.
    You can also move the coils to see if changes.
    davekro likes this.
  3. ETC(SS)
    7,288
    Even the dinky battery in the G3 PHEV can keep the engine off enough for a 200K car to have plugs that probably should be replaced but are not as worn as a wireless G3.
    Don't sweat it.
    Replace the plugs.
    Keep the coils, swapping #1 with #2 for troubleshooting.
    You may have larger problems than worn plugs or a sketch coil and so you're going to want to trade time for money in this case if you can DIY.
    Avoid Amazon's and Ebay's infamous CCP sourced "Non OEM genuine" plugs.
    (EVERYONE KNOWS NOEM underperforms and can cause no end of trouble!!!)
    This is the one example that defines the rule of exceptions for getting OEM parts from the stealer.
    Or is it the exception to the rule?
    CURSE YOU self-referential logical paradox!!! :ROFLMAO:
    davekro likes this.
  4. Mendel Leisk
    41,785
    While spark plug would seem a likely suspect, gen 3's are prone to head gasket failure, odds getting better around 150k miles, and near-certainty over 200k. It usually starts on cylinder one (leaking coolant into cylinder), and throws code P0301.
    Has the EGR (Exhaust Gas Recirculation system ever been cleaned?
    Is engine coolant level stable in the reservoir?
    Any cold-start shakes?
    Obviously plugs are overdue, but that, or a coil, may not be source of the code.
    mjoo likes this.
  5. davekro
    516
    75
    2013 Prius Plug-in
    Thanks for this. Today, I will remove the wipers and cowling and replace the plugs. I'll leave all that hardware off until it's driven and (fingers crossed), I am very lucky that solves the issue. o_O
    Brian1954 likes this.
  6. ETC(SS)
    7,288
    Don't forget to check your coolant. ;)
    davekro likes this.
  7. davekro
    516
    75
    2013 Prius Plug-in
    • I do not understand what you are saying. Can you clarify? I assume you are referring to the 12V starting battery. I did replace the original OEM 45 AH 12V AGM battery last year. I made some small physical adaptations to replaced it with a 55 AH AGM Deep Cycle battery. If interested in the details of how I did the small mods and lug conversion parts for this 12V battery conversion, see this thread:
    ‘Fitting mobility 12volt AGM battery’. Page 30, posts # 581, 583, and 585'.
    • I have not been driving it when the severe shaking, intermittently, occurs. But my wife describes it as quite violent. That does not sound like a misfire. But if a small amount of coolant is leaking into Cyl. #1, maybe after the engine has warmed up and been shut off a few mins. (or longer), even during pauses from running when the HV battery takes over… That water in a cylinder would cause a much higher compression ratio in that cylinder making that piston not want to complete its compression stroke and make the engine ‘buck’. This worries me. [ I bought a new GMC work van in 1999. It was not driven that often, but in 2007 w/ 51k miles, it had hard starting issues. Then one day returning from work an hour from home, goes up a steep grade, it started bucking violently. I figured the engine had thrown a rod, but since it was still running, I kept going to the CHP weigh station at the top of the (Sunol) grade ¼ mile away. I parked it in the huge empty parking lot, with the trail of oil in its path. I then learned that GMC trucks of that era were known to have issues if coolant was not changed regularly. It wasn’t the mileage, but the 8 years, that made the known to be problematic coolant issue become catastrophic in this case. I had the 5.7L Vortec L31 replaced with the same long block crate engine for $8,700 (engine $5,700, labor $2,800, rodded radiator + oil cooler $125). ]
    • Thanks for the warning. I’ll get some name brand, Iridium’s if not the same Denso plugs and do the plug swap today. (A prayer to the engine Gods. ;o)
  8. ASRDogman
    7,723
    3,960
    While the plugs are out, use a bore scope if you have one, if not, try a flashlight and look down each
    spark plug hole. If the head gasket is damaged, likely cylinder #1 and/or 2 piston will look cleaner
    then the other two because coolant is leaking into the cylinder.
    Mendel Leisk and davekro like this.
  9. davekro
    516
    75
    2013 Prius Plug-in
    Of course that was the first thing I checked, and added coolant...
    BUT, I had NOT put 2 and 2 together until you asked this obvious question. [​IMG] THANK YOU!
    Several days ago, this saga started with my wife's first report of the Check Engine light. The Engine Coolant was still showing in the plastic coolant reservoir, but way below the Min. level. I added 1/2 gal. (25% of 1.9 gal capac.) to bring it to full level.
    JEEZ, with your reminder that the system had lost a half gal. of coolant, my brain just put 'loosing coolant' in the same thought as 'possible head gasket coolant leak'! [​IMG] In the past 12 years since new, the coolant reservoir has shown 'Full', with never having added an ounce of coolant.... Until now. So, for some amount of time in the recent past, it has lost 2 quarts of its 7.6 quart coolant capacity! There is no coolant residue in or around engine bay and no puddles leaks on the ground. I changed the engine oil and filter 4 months ago (Mobil 1 0-W20). At that time it was dirty, but not foamy or milky at all. Currently, the oil is clean and clear. No foaminess or milkiness. So coolant is not leaking into the oil.
    I watched a ChrisFix YouTube “Do Head Gasket Sealers Actually Work (FULL 2yr TEST with Engine Teardown)” In it, he describes how to verify you have a head gasket leak into the combustion chamber using a Head Gasket Test Kit $38. Or Spill Proof Funnel $20.
    Not sure I need a confirmation that the coolant is going into Cyl. #1. Is there anywhere else it could go? But I will order the Funnel kit to confirm exhaust bubbles coming out through the coolant.
    I started watching some of this “COMPLETE 2010-2015 3rd gen Prius Head Gasket replacement "how-to" step by step Video. I think I could handle the job of replacing the head gasket. Though I could fork out $ ($5k to $7k+) to have a shop do the job, I’m not sure it would feel like a good investment. My wife loves this car and we’d love to keep it going. But paying for a shop would not feel great if the car would be worth only +/- $8,000 on the private sale market. So I guess I’d need to commit my time and bandwidth to doing the repair myself to make it feel like a worthwhile endeavor.
    ETC(SS), once your question brought ‘head gasket’ et al replacement onto the radar, I spent the day in research, NOT doing the Spark Plugs replacement and Coil Swap test. ;o) Ultimately, the violent jerking my wife describes, does not sound at all like the car simply loosing power intermittently. :eek:P So I am transitioning my mind to the bigger job. Part of me likes the idea of proving to myself that, just turning 72, hey, I still have some skills (left), assuming it works out successfully, LOL. ;)
  10. davekro
    516
    75
    2013 Prius Plug-in
    I like that idea! It may just be yet further confirmation to see the top of a silver 'steam cleaned' piston in Cyl. #1, Ha, Ha.
    The borescope mention makes me think... Did I buy one of those a few years back??... Or just research them thinking it would he cool and useful to have one. I'll have to poke around in my messy work bench, garage, and MIND, to see if anything comes to light! :D;o)
    After today's thinking that once I start into this project, I'm pretty sure, I'm in for the Whole Enchilada (Head Gasket and all parts down under there like: Water Pump, Timing chain tensioner, Thermostat, maybe 4 new coils...). If I'm investing 3-5 days (slower brain these days, yah know ;o), what's a few hundred more dollars here and there in parts 'while I'm in there' compared to MY time investment and the many thousands I'd pay in shop labor -and- marked up pricing on parts too, if I had to go that route.
    #10 davekro, Feb 2, 2026
  11. ASRDogman
    7,723
    3,960
    ... the past 12 years since new... You haven't REPLACE the coolant????? That is bad...
    Old coolant will start to eat the head gasket, or so it's believe to do that. It's easy and inexpensive
    to change it though.
    No need to waste you money on coils if they are functioning... Spark plugs, yes.
    No reason to replace the tensioner, coolant pump, maybe, you can just get the impeller, thermostat,
    another maybe. Certainly wouldn't hurt. Mine is original.
    It's always best to do a complete diagnoses of your issue before starting to replace parts that don't need to
    be replaced and are not part of the issue.
    For the Prius, you won't really see coolant in the oil, or exhaust in the coolant. Because normally the
    gasket fails between the #1 and 2 cylinders. By the time you see coolant in the oil, or exhaust in the coolant,
    the engine will barely be running, or have a piston through the block.
    davekro likes this.
  12. Mendel Leisk
    41,785
    That tests for exhaust gas in coolant, which is not the usual 3rd gen Prius HG failure mode, at least not in the early stages. Borescope inspection of cylinders is more conclusive.
    again: any EGR cleaning done? Think I know the answer, but just for the record.
    top 2 links in my signature relate to EGR cleaning, last link is full engine section from repair manual. (On a phone turn it landscape to see signatures)
    also: watch relevant @NutzAboutBolts here.
  13. ETC(SS)
    7,288
    Putting some repair $$$ into a Pip in the SoCal probably isn't a bad idea in spite of the fact that the car isn't really worth 8K anymore now that it's suffering from the Prius Death Rattle.
    Besides....8K for a head gasket is high even by SoCal standards.
    It will be closer to 5k from some place like Gasket master or another Indy.
    Add in about a thou of other incidentals and you're looking at less than a year to recoup the expense versus the cost of the average used car payment of something like $600 a month.
    I do not think it's unreasonable to expect that you will get another year of service from the PIP - even though it's far enough along on the back nine for you to smell the bar food cooking in the clubhouse.
    Best reason of all to repair it.....your wife loves the car.
    Good Luck!
  14. Mendel Leisk
    41,785
    @NutzAboutBolts video on head gasket replacement is definitely worth a watch, very thorough, linked here.
    If DIY’ing, the cash outlay is under $500 USD, for the genuine Toyota engine overhaul gasket kit and head bolts.
    Last link in my signature is the full engine section from repair manual. (On a phone turn it landscape to see signatures)
  15. davekro
    516
    75
    2013 Prius Plug-in
    I am shopping for a good borescope. I'll search PriusChat, Google, review Amazon, I did F Fwd thru Farm Projects' borescope review for borescope recommendations, especially for the smaller dia. 12mm Gen 3 Prius spark plug hole. A lot of variables to narrow down.
    I saw your copy pasted questions over on my other thread where I answered this Q' plus a lt of new information: Head Gasket Replacement Shop Recommendations- San Francisco Bay Area I'll copy my answer and other details here, for continuity of this thread for future readers...
    "The EGR has never been cleaned"
    "I don't know over what period of time the Engine coolant level had dropped well below the minimum mark. It's my wife's daily driver, so I'm rarely under the hood to notice. I changed the oil in Sept of 2025. It's likely I would have noticed if the coolant reservoir was down much from the full mark at that time. After my wife first reported a check engine light 1/28/26, I saw that the coolant was WAY below the Min. mark, but still showing in the reservoir. Without running the engine, it took 1/2 gallon of 50/50 Zerex coolant to bring it to the full mark. It has remained there to date, but it has mostly been parked except one three mile errand after the coolant was added and the codes were cleared, thinking the issue would be solved by adding back the ≈ 25% of the missing coolant.
    On her next, same 3 mile one-way errand, she got the shaking engine again. NOT from cold-start, but AFTER her short 5-10 min stop at the shopping center. She had one more (3rd) trip to that shopping center, with the same result of the jerking engine just after she started back to home. Tonight, I made that same trip, which was MY first time for a first-hand experience. It drove smooth as normal from cold-start on the 3 mile trip there. I was continuing my research, parked, and go figure two hours went by. ;o) When I put the car in Ready, it ran on the battery until I got onto the highway. As soon as I accelerated normally, it switched from HV battery to the engine, and immediately there was ≈ 2 seconds of engine shaking, then smooth again. As I continued this test drive, stopping several times for varying amounts of time (2, 5, 10 mins., every time the car switched to the ICE engine, the ICE rattled for 2-3 seconds, then smooth again. I had my Autel MK808S scanner in 'Live Mode' to monitor the ICE while I drove. Outside ambient temp. was ≈ 50ºF (10ºC). On my 3 mile drive out, the coolant temp was 158ºF (70ºC). On the return trip, the temp started rising 170, 185. So, as I was now in a 25 mph (40kph) zone, I slowed and accelerated strongly several times to see if it would continue to rise. It got up to 195ºF (90ºC). Hmmn? Then I continued driving, but normally, w/o the hard accelerations, and it settled at 170ºF (77ºC). I took it back out to the highway to see what a steady 65 mph (105kph) would get for temp. At that highway speed the coolant temp was a steady 195ºF (90ºC). Hmmn?
    Would you agree that it seems to be a hot-soak restart misfire, not a cold start Misfire?
    What does having a hot-soak restart misfire, instead of a cold start Misfire mean?"
    Thank you for that great 'full engine section from repair manual.' !!
    I did watch his three videos. They were very clear and meticulous. That is when I started thinking about not doing the head gasket job myself. After that questioning, I saw @rjparker 's post #2 on my Head Gasket Shop Rec'c thread mentioning the JDM engine swap option. I am liking the idea of THAT possible path big time now. I'm leaning towards paying a shop like Gasket Masters to do the engine swap job. I'm lucky that they have two shops relatively close to me. One in Stockton,CA- 45 mins. away. Haward, CA- 55 mins. away.
    It just occurred to me, since I am seriously considering doing an engine swap, would it be unwise to do a stop-gap temporary fix by trying Bar's Leaks Head Gasket Fix? I'm not sure how much of a risk it would be of gumming up the cooling system any or somewhat, that would still be in place after an engine swap.
  16. ASRDogman
    7,723
    3,960
    DO NOT DO THIS! IT WILL NOT WORK!
    It will only clog up the radiator, heater core, water pump, thermostat, and all the little passages
    in the cooling system.
    It will clog everything except where the head gasket is damaged.
    If you replace it now, or have it replaced, it will cost less. And won't throw a piston through the block.
    You don't need an expensive bore scope, how often will you use it?
    It just occurred to me, since I am seriously considering doing an engine swap, would it be unwise to do a stop-gap temporary fix by trying Bar's Leaks Head Gasket Fix? I'm not sure how much of a risk it would be of gumming up the cooling system any or somewhat, that would still be in place after an engine swap.[/QUOTE]
  17. ETC(SS)
    7,288
    Bar's Leak: Asked and answered.
    IMO, you need to make one important decision and ask yourself a fairly important question very soon now.
    The decision is whether you're going to replace the motor, and the question is whether or not you have access to a tow truck, and if your spouse drives through neighborhoods, or in situations that she would not want to break down in.
    Not judging, because right now in many parts of the country the freekin WEATHER can kill you.
    You already seem to be experiencing the "Prius Death Rattle" and they CALL it that for a pretty good reason.
    See also: Hydro-lock.
    Trust me.....water does not really like to be compressed very much, which means that soon your car will decide FOR YOU whether or not you're going to have to do a heart transplant instead of just a bypass or a stent....after your car gets towed, in all likelihood.
    Remember....
    They call them 'engine swaps' instead of engine replacements, ALSO for a pretty good reason. ;)
    Good Luck!
    #17 ETC(SS), Feb 6, 2026
  18. ChapmanF
    18,418
    The main problem with calling it that is that the Prius drivetrain will make that same horrifying rattle no matter what is making the engine severely misfire.
    In this thread, the car seems to be losing lots of coolant, so head gasket is probably not a wrong diagnosis.
    But sometimes people with other reasons for their misfiring hear that same sound and panic before reaching a proper diagnosis, because they saw it called "the death rattle" somewhere.
    The classic AECS article gave an example where the owner ended up letting the car go for scrap price, and the shop then replaced the failing spark plug:
    https://aecs.net/techniek2012/March%20prius.pdf
    davekro and mjoo like this.
  19. davekro
    516
    75
    2013 Prius Plug-in
    I intend to take our 2013 Prius to the Gasket Masters shop in Manteca CA, to get a full professional diagnosis. I still feel the desire to invest a bit of time to pull the wipers and two cowls to check the spark plugs before going to the shop. I just found out my brother-in-law has an inexpensive borescope that connects to your phone. So, now before I take it to the shop, I will be pulling and inspecting the plugs and peaking into the cylinders, especially Cyl. 1 that is getting the P0301 'Cyl. 1 Misfire Detected' code. I'll install 4 new plugs. The Car Care Nut recommends isolating the EGR valve/ System to eliminate it as an issue (4:00 min mark) and see if anything changes. I doubt the EGR System is at least the main issue for our Prius, but I'll be doing his test as due diligence. After the test, I will clean the EGR valve (carefully), its cooler and piping, because it has never been done.
    rjparker recommends that I reinstall the two cowls and the wipers, rather than driving to the shop with the parts in the back (w/ nuts and bolts bagged and well labelled). More labor for me and more labor for the tech at Gasket Masters (that I pay them for ;o). When I talk to them, I may ask them their preference on this.
  20. ASRDogman
    7,723
    3,960
    A failed head gasket is a KNOWN issue with the 3rd Generation Prius. And some Gen4 Prius'.
    So when certain issues arise, it's almost a given what the issue is..
    You'll also need a pressure tester to put pressure on the cooling system so you can see the coolant
    leaking.
    The worst this to do is bring in "parts" from a partially disassembled engine!!!! Now they have to figure
    out where everything goes. It can be a nightmare.
    So unless you plan on installing it yourself after they do their work, put it back together....
