Oil leak after head gasket replacement
Discussion in 'Gen 3 Prius Main Forum' started by Drewdeluxe, Jun 23, 2024.
  1. Drewdeluxe
    Drewdeluxe New Member
    Laguna Beach
    Help: So I replaced my head gasket myself about 3-4 months ago and when it was time to do an oil change, I noticed an oil leak and almost two quarts missing. I was hoping it was the timing cover because it was only to that side, but to my dread, it does look like it maybe the gasket, but it's hard to tell being so close to where it meets the timing cover. Any advice or tips on how to proceed / what potentially I did wrong? How much time do I have with a slow oil leak potentially from a HG because it might be a while until I can tackle this project again, will driving it and topping off be okay for a bit? Thanks.
  2. HendersonvilleDad
    HendersonvilleDad New Member
    Hendersonville, TN
    Hey - curious what you ultimately found out with this, as I am in the exact same situation.
