Featured Has anyone heard of the Hyundai Nexo?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by BiomedO1, Feb 11, 2026.
  1. BiomedO1
    4,058
    2,136
    SacTown, Ca
    I just ran into this car while surfing. Apparently this car has been around for a while. I'm only referencing this because of the recent demise of the Toyota Mirai - mainly the lost of convenient hydrogen stations. Thank you again Shell oil..... Used Toyota Mirai for Sale in Sacramento, CA (with Photos) - CARFAX
    Don't know how well they'll sell, if you can't refuel it.
  2. Trollbait
    12,661
    I think it was outselling the Mirai globally at one time.
    Don't know its current status.
  3. hill
    8,909
    The more relevant factoid might be - is there anything not outselling the Mirai?
  4. BiomedO1
    4,058
    2,136
    SacTown, Ca
    I would serious consider getting one, If I didn't have to burn a half tank of hydrogen to get to someplace to refuel it.
    What do they say about insanity; Doing something over and over again and keep expecting a different result????
    PrimeDan likes this.
  5. PriusCamper
    PriusCamper Senior Member
    13,004
    5,286
    Pacific Northwest, USA
    If I was out surfing big waves I sure wouldn't want to run into a car, maybe a whale or a dolphin, but definitely not a car.
  6. hill
    8,909
    Then there's this;
    Why Hydrogen Fuel Costs $36/kg in 2025 | The Real Cost of Driving FCEV
    Then there's the issue of pressurized fuel. Not necessarily opposed - as once upon a time I'd converted an Econoline to run propane (back when it was <39¢/gallon & regular was $1.20). But propane is ~145 PSI. But 10,000 PSI hydrogen?
    (cringe factor)
    #6 hill, Feb 12, 2026
  7. mikefocke
    4,039
    1,834
    Sanford, NC
    A while back I posted a picture of a propane fireplace repair truck that was a Rav4 with propane adaptation. Easy to do when you havew a big tank where you park overnight. And are visiting locally. Not sure where they put the tank or if it had a gas tank too. Would that make it a tribred?
  8. BiomedO1
    4,058
    2,136
    SacTown, Ca
    I have several gas stations within a mile of me that can fill propane tanks; but would someone be on staff that can operate that equipment when you drop by.
  9. mikefocke
    4,039
    1,834
    Sanford, NC
    I see gas tanks for sale at gas stations but they are taken off site to be filled and cleaned. I see very very few if any stations that could fill.
    At the same time, my little town has at least 4 propane suppliers. Most of the home tanks are rented and can, by state law, only be filled by the company that owns them. I own mine and can go where prices are lowest.
    Today I went by a Tesla charging station 100 yards off an interstate with 10 kiosks, is that 10 or 20 stalls. All were empty at 3PM on a nice day.
  10. Trollbait
    12,661
    That would be a dual- or bi- fuel.
  11. bwilson4web
    16,347
    Superchargers have a variable cost rate ranging from a low of $0.28/kWh up. To avoid traffic, I typically leave after 10 PM and often find only one or no other EVs there.
    It is common to find pairs of SuperCharger stations on opposite sides of commuting routes. Depending upon rush hour bias, one side will be fully subscribed versus the other partially occupied.
    Unlike gas stations, there are no attendants or periodic gas trucks. So I stop somewhere approaching the charger for a biology break before charging.
    I’ve also been the only EV driver at Charge Point or Electrify America stations. The density is high enough I don’t worry about most cross country trips so some should occasionally be empty.
    #11 bwilson4web, Feb 12, 2026
  12. mikefocke
    4,039
    1,834
    Sanford, NC
    Interesting that you don't see signs on Interstates for EV chargers like you do at many exits for gas stations. Guess all EVs are recent enough that they point you to them via their navigation apps.
  13. Trollbait
    12,661
    I say it was that way before the cars did anything. Aside from some free Level 2s, all the charge networks required apps for access and paying. Pointing out where a charger is helps the business. Then Superchargers is/was a closed system; only the Teslas needed to know where they were.
    Now, I have seen a couple signs for chargers. I think installation of physical signs take time, and chargers are being installed quickly. There is going to be lag for the signs even if they were a priority.
