12V battery maintenance for dummies when gone for weeks
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Girl__wonder, Jan 4, 2026.
  1. VelvetFoot
    VelvetFoot Active Member
    1,209
    472
    New York State
    2026 Prius
    Nice battery.
    I put a bluetooth battery monitor and a NOCO 1 under the battery cover.
    I love that battery monitor-a nice little toy. It uses very little juice. Thanks again @Gokhan !
    A flat extension cord for the NOCO easily fits under the weather stripping, as I've seen for myself and at least one other can attest to as well.
    I bought the charger just from reading the forum, lol. My plan is to not ever use it, since I do like to drive my nice sporty car!
    Girl__wonder and Gokhan like this.
  2. Mendel Leisk
    41,898
    You can connect a permanent wire either location, hatch or engine bay. The latter may be more convenient, especially for on-board style chargers, where what comes out of the car is the charger’s power cord.
    My charger is exterior style, mounted on the wall in our garage, and still works well with the (CTEK) quick connect. It’s secure garage parked though; if you’re in a carport or driveway, it’s somewhat insecure.
  3. VelvetFoot
    1,209
    472
    New York State
    2026 Prius
    I like onboard chargers.
    I've got the entire charger under that battery cover. Just have to run a 120V extension cord to it and plug it in.
    Installing it under the hood didn't seem intuitively obvious to me on my Gen5. An onboard charger would receive more exposure to the elements under the hood, even if one could find a nice place for it, cleverly install the charging cables permanently to the fusebox, potential voltage droop to the battery, etc.
    Whatever, it was quite easy in the hatch.
    Girl__wonder likes this.
  4. Mendel Leisk
    41,898
    I’d prefer under the hood, doubly so for onboard style, for the convenience of having a secure/locked car, power cord coming out through grill. Appreciate motorized grill may complicate this, but there’s always a way.
  5. VelvetFoot
    1,209
    472
    New York State
    2026 Prius
    As I said, flat extension cord fits easily under hatch weatherstripping on a GEN5.
    No complicated cord fabrication routing and mounting issues and potential future wear issues.
    To each his own, I suppose.
    Either way, you still have to remember to unplug. :)
  6. Mendel Leisk
    41,898
    And/or prep for the time you forget. Secure the unit’s power cord solidly on the car side (so it doesn’t end up dragging along the road), secure the extension cord (I loop ours round a barbecue leg), use an extension cord style where it pull straight out to disconnect (not 90 degrees), and pulls out easily.
  7. VelvetFoot
    1,209
    472
    New York State
    2026 Prius
  8. Gokhan
    Gokhan Senior Member
    6,531
    2,608
    Paramount CA
    Speaking of to each his own when it comes to making your life easier, I still can’t convince @Mendel Leisk to upgrade from his bicycle hand pump to a digital compressor. One of those days, I will send him one as a gift.
    Girl__wonder and VelvetFoot like this.
  9. TGTGUUD
    TGTGUUD Member
    97
    73
    San Francisco
    2024 Prius
    If you park in the garage, get a 1A trickle charger and leave it connected.
    If you park under the sun, get a solar trickle charger and stick it to the inside of your hatch glass.
    I bought a cheap one under $20. And it kept the supposedly dead battery alive for a few more months. It charged the battery just enough to crank the engine once a day. Before that the car wouldn't start at all overnight.
  10. Girl__wonder
    Girl__wonder Junior Member
    22
    2025 Prius Plug-in
    XSE
    Hi everyone, thanks for the help. @Mendel Leisk I'm taking your advice and using the Solar battery tester. (it's better than the TopDon). I'm going to keep the NOCO10 vs. the 1. Right now, I'm still not comfortable leaving it on all the time (and today my battery is fine. It's brand new! lol and has 470 CCA). So going forward, the plan is to be mindful of my driving (take a longer drive on the highway, if it makes sense), test the battery periodically, and charge it then. Before a trip, I'll make sure it's fully charged and then...if I expect to be gone a long while, I may ask a friend if he can drive my car to work sometimes. (He has an hour+ commute and likes cars. Maybe fun for him?)
    As a bonus, the freebie Toyota "remote connect" service expired this week. This is the app that periodically monitors the car and sends a message that I left the driver's side window open. I'm not renewing (it's $15/mo), so hopefully that will reduce a bit of the parasitic drain.
    @VelvetFoot I have a 2025 with the battery in the back. A friend's suggestion: run the power cord out through the open window on the rear passenger side. That way that hatch can stay closed, no issue. This is my plan. Not sure if you've tried it (though it sounds like you're not having issues with the cord and the hatch).
    FWIW, one day I was thinking: surely there must be a way to turn off that rear dome light. So I flipped the locking switch on the hatchback door. It worked: the car thought the hatchback door was locked. But...my key fob couldn't unlock it (oof!). I had to play around and finally got it unlocked. I'm not doing that again but FYI.
    Thanks again everyone. I really appreciate all the help.
    Mendel Leisk and VelvetFoot like this.
  11. Girl__wonder
    22
    2025 Prius Plug-in
    XSE
    LOL. Even I have a cordless compressor--to pump my bike tires :) . Ryobi was having a deal when I bought a couple other tools.
    Gokhan likes this.
  12. BiomedO1
    4,126
    2,168
    SacTown, Ca
    If you don't want the charger ON all the time, you can place the outlet on a timer. That way you can keep a routine, regarding plugging everything in and unplugging everything. IMHO; it's better and easier to keep a routine - so you don't forget to plug or unplug something.;)
  13. Gokhan
    6,531
    2,608
    Paramount CA
    I believe it is okay to leave the Noco Genius connected, at least according to Noco.
    What happens when you leave it connected is that it turns off automatically when the battery is fully charged, then it will turn back on after about three days when the battery charge drops by approximately 5%, fully recharging the battery and turning off again. The on/off cycle then repeats indefinitely.
    I think it might be better to connect it to the service connector under the hood (see the Gen 5 Prius owner’s manual). You can also close the hood over the power cord if you route it through a gap over the headlamp.
  14. Mendel Leisk
    41,898
    Yeah our ‘10 is on a charger ALL the time it’s parked in garage. When we roll in I pop the hood, connect it the next morning.
    The charger came with fused wiring quick-connect which I installed at front/left corner of engine bay, positive wire snaked into fuse box’s positive input cable connection, negative wire bolted to car body.
    Current battery will be 11 years old next September lol.
    #54 Mendel Leisk, Feb 28, 2026
  15. HamiltonPrius
    HamiltonPrius Member
    206
    98
    Parts unknown in Virginia
    2026 Prius
    To the OP… just have someone start your car and turn on the AC so the ICE runs once or twice a
    week for about 10 minutes each time. That should be sufficient. That has been my experience owning 2 model years of Prius.
    #55 HamiltonPrius, Feb 28, 2026
  16. Gokhan
    6,531
    2,608
    Paramount CA
    10 minutes in the READY mode is roughly enough to compensate for a day’s drain, let alone a week, for Gen 4 and Gen 5. If your battery SOC is low, it may not even last 2 weeks of drain, as you lose up to 3% SOC every day.
  17. HamiltonPrius
    206
    98
    2026 Prius
    Just giving my experience. I hardly drove my new car for at least a month and a half during the brutally cold weather and only started it a few times…..it started like a champ every time. I’m using it more the last several days and everything is fine.
    #57 HamiltonPrius, Feb 28, 2026
  18. HamiltonPrius
    206
    98
    2026 Prius
    Only changed out the battery once in my Gen 4 in 10 years using it sparingly and parked in my driveway in all kinds of weather.
  19. Gokhan
    6,531
    2,608
    Paramount CA
    OK, what you don’t realize is that your battery SOC is very low right now. The Gen 4/Gen 5 Prius BMS cannot fully recharge the battery once the SOC drops too low, like after the car sat undriven for a month. So, get a Noco Genius and charge the battery manually to 100% SOC ASAP. Otherwise, there is a good chance that your battery will fail soon.
  20. HamiltonPrius
    206
    98
    2026 Prius
    Is a Noco Genius just a plain Jane trickle charger? If so I already have 2 battery tender brand trickle chargers.
