EVs work in the cold
Discussion in 'Tesla' started by bwilson4web, Jan 26, 2026.
  1. bwilson4web
    16,314
    Source:
    One minor technical flaw, a useful summary needing these points:
    • 250 kW SuperChargers - each is independent and not shared with other SuperChargers. The earlier 125 kW units worked as pairs,
    • Preconditioning - it is critical to have the car plugged into at least an L2 charger and schedule the departure time. This will pre-warm the battery giving more efficient operation along with cabin pre-heated. Let the Grid power the initial warm-up.
    • Cold air drag - the denser air increases the drag significantly. It is important to run slower speeds to stretch the range. Use "dog mode" to preserve battery and cabin heat instead of drawing from the battery later.
    • Built-in mapping - it shows all superchargers within hundreds of miles to optimize route. Best of all, identify L2 charger equipped motels to start the next day with a preconditioned car. A little more costly but saves time: GOOD, FAST, CHEAP
    This was the return trip metrics in 30-43 F weather:
    • 1000/256.5 = 3.9 miles/kWh
    • 338.7 * 2 = 677.miles in 16 hours
      • 677 / 14 = 48 mph
    PrimeDan likes this.
  2. hill
    8,884
    Plus - when any vehicle, gas or EV is pushing through slush & snow, that's going to create more drag, couple that with ice buildup inside the wheels? More drag. Then, there's cold, and REALLY cold.
    Thank the Lord it hardly ever gets this cold - well below zero, very often, but when it does? An EV or PHEV heat pump is useless, so cabin comfort and windshield defroster have to rely on resistance heating which further suck the life out of a pack - just like it sucks the life out of a gasser having to crank over a engine block &/or turn axle & transmission gears over that are dealing w/sub Sub-Zero temps.
  3. BiomedO1
    3,968
    2,091
    SacTown, Ca
    That's why it's always nice to have a gasoline backup - especially if you end up behind a interstate pileup or long chain control lines. You can burn your battery down rather quickly using those resistant heaters. Better to just utilize the seat and steering wheel heaters, but then you'll have to deal with glass fogging.
    hill likes this.
  4. bwilson4web
    16,314
    I would probably choose a less volatile fuel and combustion that does not generate carbon monoxide. Furthermore, a more efficient combustion cycle that allows reuse of waste heat:
    • liquid cooled engine and exhaust - cool in the cabin
    • modest electric generation - 100 watts
  5. Isaac Zachary
    Isaac Zachary Senior Member
    2,636
    1,353
    Is it just me, but isn't preconditioning in an EV essentially the same thing as warming up a gasoline car? I mean, sure, the EV might have a timer set to come on automatically. But other than that, isn't the concept the same?
    Don't all internal combustion engines reuse the waste heat?
    I don't know. We get well below 0 °F daily during winter here in "the coldest town in Colorado" but we've had plenty of gasoline and diesel vehicles that have gone long past 200,000 miles without any major issues, From my grandpa's Honda Accord with over 400,000 miles on it, to our Ford Aerostar with over 300,000 miles on it, to our VW Golf diesel that had some 700,000 miles on it. The cold might be hard on them, but not enough to make that much of a difference. Just change the oil often and it'll be fine.
  6. bwilson4web
    16,314
    • Uses grid power - about 1/3d to 1/5th the cost.
    • Does not wear the engine, oil, or lower gas tank. Battery charged for the day
    • No noxious fumes from a cold, catalytic converter.
    • Don’t have to go out in the cold to start the car.
  7. Isaac Zachary
    2,636
    1,353
    Not overall cost for most of us.
    • Cheapest practical used EV: about $20,000
    • Cheapest practical used ICE: about $1,000
    That's over 20 years of driving to break even for me. For other EV owners who wouldn't consider a $1,000 car depreciation is killing them right now. Only in some cases are people actually able to make an EV cheaper overall. But if cost is really a concern, then ICEV wins for most people.
    IF EVs are actually cheaper to own, then show me. But I can't make one work. Too expensive, even if the electricity were free.
    • Engine wear is only a problem if the ICEV can't outlast an EV in longevity.
    • Lower gas tank is only a problem if the ICEV can't still go farther than the EV.
    Just going by the average car, it seems an average ICEV lasts some 200,000 miles, before any major issues, even in a place like here, "the coldest town in Colorado." If EVs are lasting longer than that, then I'm all ears. But I'm not yet convinced.
    IF EVs are actually lasting longer than ICEVs, then show me. So far there seem to be too many stories of less-than 200,000 mile EVs needing battery replacements that cost tens of thousands of dollars, many times more than what the car is worth.
    Remote start on ICEVs is also a thing you know. So again, not a reason to buy an EV.
    BUT:
    I can agree with you there. This is why I did try to go with an EV for a while. The EV didn't work out. But yes, as much as I feel that a lot of the reasons people say "EV's are better" are just part of the gimmicky propaganda to push EVs as if they were better, when there're not, I do feel that this is the reason they are better.
    #7 Isaac Zachary, Feb 12, 2026 at 2:54 PM
    Trollbait and BiomedO1 like this.
  8. fuzzy1
    10,563
    You exaggerate. With today's national average gas price a bit under $2.94/gal, that would imply an average electric price of $0.043 to $0.071 / kWh. While I do know of a very few electric utilities in my state charging that low (one even lower), they serve only a very small population. The national average is closer to $0.180 - 0.190, the cheapest state average is $0.124, and only two other states average under $0.13.
    My area has among the nation's highest gas prices, coupled with below average electric prices, and home charging is much closer to 1/2 the cost of gasoline.
    As public recharging consolidates, replacing formerly "free" amenity outlets around here with fee-based commercial networks, the away-from-home charging is now more expensive than gasoline. Yesterday I paid $0.39/kWh at a medical complex (plus a connection fee) to add a bit so that my PHEV could make the round trip all-EV. That is the lowest public rate I've seen in the past year, apart from the few remaining free spots.
    PrimeDan and Isaac Zachary like this.
  9. BiomedO1
    3,968
    2,091
    SacTown, Ca
    I know a doctor that is a early adopter of the Tesla. Free charging for life; but he paid well over $100K for it. He was too cheap to install an L2 charger @ home and fast charged for free - well relatively free. A doctor's time is worth money, so twiddling your thumbs at a charger was costing him money. He thought he got a deal; when his battery pack replacement cost him $15K.
    He knew I was a "car guy" and was raving about his Tesla. It was a status symbol and cult following back then. I was in a Prius C at the time and told him I don't see it. So I showed him on a bar napkin calculation that his breakeven was 30+ years, not counting the $15K wack and tire replacements; he just took. I believe my Prius C was around $15K out the door....
    YMMV
    BTW; I believe electricity cost will continue to increase; not because of more BEVs - but because of the power hungry AI data centers driving your devices. We don't have excess electricity generating capacity; unless we start building nukes - 10 years ago.....
    Trollbait and Isaac Zachary like this.
  10. mikefocke
    4,036
    1,829
    Sanford, NC
    Don't worry about power, the DOD/DOW is going to be using coal so that will take a load off the grid.
    Not to mention that green house gasses are now officially clean and so no need for auto emissions regulations.
    PrimeDan and BiomedO1 like this.
  11. BiomedO1
    3,968
    2,091
    SacTown, Ca
    Don't forget to remove those expensive stack emissions scrubbers. Well just DOGE the EPA so they can't inspect or certify them. If the law is not enforced, is it really a law????? FWIW: That's a Bondi question.
    Trying not to remember the Don's "clean" coal initiative. While Beijing's skies are turning blue; ours will be going grey soon.:(:eek:
    I've almost forgotten about those oh so sweet sweet inversion layers we used to get here in the valley.
    #11 BiomedO1, Feb 12, 2026 at 7:43 PM
  12. bisco
    52,227
    my ev works in winter, but there's nothing cheap about it. runs about the same as gas
  13. bwilson4web
    16,314
    EVs are not for everyone:
    • $24,000 - what I paid to convert a 2017 Prius Prime into a 2019 Model 3.
    • $0.07/mi Prius Prime cost per mile vs $0.02/mi in Model 3 using $0.12/kWh home electricity.
    • Edmunds claims my Model 3 is worth $5,000 BUT IT IS NOT FOR SALE.
    • Coolant valve failure. $1,000, cost early $9,000 battery replacement.
    • $0.00/mi cost around town after replacing TSLA stock with solar roof.
    So I’m sympathetic to the insurmountable EV problems of others that I’ve not experienced. I did start with a 2014 BMW i3-REx, $30k, and my backup is a 2017 BMW i3-REx, $15k. I somehow, accidentally avoided those problems and live a comfortable retirement.
    Many paths led us to PriusChat and over time, we will continue our various futures. If some return to ICE, so be it. More Prius, good on you. Mine is home powered EV that I have no interest in leaving nor can afford to leave.
  14. bisco
    52,227
    I paid $16,500. for the bolt after tax credits and trade in.
    I don’t think I’ll ever see a deal like that again
    #14 bisco, Feb 13, 2026 at 2:42 PM
    bwilson4web and Isaac Zachary like this.
  15. Isaac Zachary
    2,636
    1,353
    I paid $15,000 for a +$40,000 MSRP Toyota with only 50k miles and 5-years-old with virtually no accidents or damage.
    I'm sure I'm not going to see a deal like that in a very long time, if ever.
  16. bwilson4web
    16,314
    I've bought two VMW i3-REx
    • 2014 - +$50,000 list price, paid $30,000 for used with ~6,000 mi
      • went with 2nd wife when she left
    • 2017 - +$50,000 list price, paid $15,000 for use with ~50,000 mi
      • still in service
    Similar and better deals for BMW i3-REx are available if you look and wait:
    • GOOD
    • FAST
    • CHEAP
    Isaac Zachary likes this.
  17. bisco
    52,227
    Chevy equinox ev going for some seriously low prices, but you sometimes get what you pay for
  18. Isaac Zachary
    2,636
    1,353
    Yeah, if I needed a car today I'd consider one. But would it be worth trading in the Avalon for one? I don't think it would. The range isn't enough to get to the next charging station going out if town on a single charge, and I'm not too sure the range extender would do that well here going over mountain passes, especially in the winter.
  19. bisco
    52,227
    I don’t think so, but it’s a personal decision
