Adding Second Set Of Wheels With Snows (TPMS)
Discussion in 'Gen 5 Prius Technical Discussion' started by VelvetFoot, Feb 5, 2026.
  1. Gokhan
    Gokhan Senior Member
    6,455
    2,577
    Paramount CA
    Yep, it is standard operating procedure for garages to lose your beautiful, top-quality OEM tire valve caps.
    Do what I plan to do. Get some cheap ones from Amazon and replace the Japanese OEM Pacific Industrial Co., Ltd. tire valve caps with those whenever you take the car to a garage or service. Then, put the OEM tire valve caps back. You can get the OEM ones for cheap at the next Black Friday sale.
    VelvetFoot likes this.
  2. Mendel Leisk
    41,785
    Whenever I hand either the car, or loose wheels, over to a tire shop, the valve caps are in my pocket.
    What ARE you on about; those are stock, gen 3 Plug-In rims.
  3. VelvetFoot
    VelvetFoot Active Member
    1,079
    407
    New York State
    2026 Prius
    Can't find the spares now. Those things are easy to lose. :)
    Gokhan likes this.
  4. Gokhan
    6,455
    2,577
    Paramount CA
    I know, but that shouldn’t stop you from putting on some Gen 4 aero wheel covers or getting some aftermarket ones. ;)
    Or this:
    Here is the detailed aerodynamics study by that guy who tried that cardboard aero wheel cover on his silver Gen 3 Prius:
    Wheel covers and base pressure on a silver Gen 3 Prius
    #24 Gokhan, Feb 15, 2026 at 5:37 PM
  5. Gokhan
    6,455
    2,577
    Paramount CA
    Gen 5 aero wheel covers look way better than @Mendel Leisk’s nonghetto Gen 3 wheel covers in my opinion.
