Heat stopped working: 2012 Two, 145K Miles
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by indel, Feb 15, 2026.
  1. indel
    indel Member
    267
    87
    Northwest Indiana
    The heat has been working fine all winter. In fact it's so strong that I have to keep it around 68F to not get too hot. We are having warmer weather this week in the midwest. On a long drive this evening, the heat won't work properly. I was blasting it at 75F and still cool air.
    - 2012 Two at 145K miles
    - Both coolant tank levels are at the top mark and have been consistently there for the 3000 miles I have owned the vehicle
    - ICE coolant temp hovers around 88-91C (190-195F) - see below
    - No CEL or heat malfunction indicator
    How should I go about diagnosing this problem?
  2. rjparker
    10,437
    6,544
    1. Read second coolant temperature sensor located downstream of the heater and exhaust heat recirculation system. This is a dual passage cooling system.
    If there is air in the heater core the second sensor will be low.
    Techstream Sensors
    2. Verify heater blend door is moving. One method is to turn blower on high and switch temperature from Lo to High and back. Air flow will slow as blend door allows air through heater core.
    Obviously there should be air flow.
    3. Verify water pump flow in Coolant Reservoir when coolant has opened thermostat. Use flashlight to observe flow from top reservoir hose.
    Brian1954 and indel like this.
  3. indel
    indel Member
    267
    87
    Northwest Indiana
    Very helpful, thank you! I will check these out tomorrow.
