Adding Second Set Of Wheels With Snows (TPMS)
Discussion in 'Gen 5 Prius Technical Discussion' started by VelvetFoot, Feb 5, 2026.
  1. Gokhan
    Gokhan Senior Member
    6,459
    2,580
    Paramount CA
    Yep, it is standard operating procedure for garages to lose your beautiful, top-quality OEM tire valve caps.
    Do what I plan to do. Get some cheap ones from Amazon and replace the Japanese OEM Pacific Industrial Co., Ltd. tire valve caps with those whenever you take the car to a garage or service. Then, put the OEM tire valve caps back. You can get the OEM ones for cheap at the next Black Friday sale.
    VelvetFoot likes this.
  2. Mendel Leisk
    41,786
    Whenever I hand either the car, or loose wheels, over to a tire shop, the valve caps are in my pocket.
    What ARE you on about; those are stock, gen 3 Plug-In rims.
  3. VelvetFoot
    VelvetFoot Active Member
    1,083
    411
    New York State
    2026 Prius
    Can't find the spares now. Those things are easy to lose. :)
    Gokhan likes this.
  4. Gokhan
    6,459
    2,580
    Paramount CA
    I know, but that shouldn’t stop you from experimenting with aero wheel covers. For example, this: ;)
    Here is the detailed aerodynamics study by that guy who tried that cardboard aero wheel cover on his silver Gen 3 Prius:
    Wheel covers and base pressure on a silver Gen 3 Prius
    #24 Gokhan, Feb 15, 2026 at 5:37 PM
    mingc likes this.
  5. Gokhan
    6,459
    2,580
    Paramount CA
    Gen 5 aero wheel covers look very good, in my opinion.
    #25 Gokhan, Feb 15, 2026 at 6:16 PM
  6. Gokhan
    6,459
    2,580
    Paramount CA
    This is actually a very bad idea. If they decide to wash your car (as a courtesy) or if it rains, etc., etc., your TPMS sensors could be ruined. Just replace the tire valve caps with sacrificial ones when you hand the car over, and replace them with the good caps, such as the Japanese Pacific Industrial, Co. Ltd. OEM caps, when you get it back.
  7. VelvetFoot
    1,083
    411
    New York State
    2026 Prius
