Unable to connect to emissions test computers
Discussion in 'Gen 3 Prius Technical Discussion' started by Striker_, Feb 15, 2026.
  1. Striker_
    Striker_ New Member
    Atlanta, GA
    My 2011 Prius has been unable to get through emissions testing at four different emissions sites now. It's a connection failure every single time. Sometimes it gets past one initial step but fails to connect later on and most times it doesn't connect at all (I've tried a few times at some of the sites). However my BAFX OBD reader works fine and so does the AutoZone one. There are no codes reported. I've checked the voltage and it's 12V on the OBD port, nothing weird there. Given the failures are only on emissions computers, I have no idea what I could reasonably check to try and resolve the issue. They're all using the same OBD port and using the same CAN bus.
    I've had the car for years, it's never had an issue in the past with emissions testing. Not really sure what to try. I could hook a scope or logic analyzer to it if need be but frankly I can't think of any weird variation in protocol/timing that could suddenly pop up nor do I have any data on what it should be to compare against to determine if it even existed, so diving super deep into that doesn't seem helpful.
    Any ideas at all?
  2. AzWxGuy
    AzWxGuy Weather Guy
    1,065
    547
    Tucson, AZ
    2021 Prius
    I would take a closer look at the OBD port, looking for dislodged contacts or something out of alignment. Realize it is in a bad spot to get a comfortable look at. Doubt that the emissions warranty applies in this case, but a chat with your maintenance service writer might help.
    PrimeDan likes this.
  3. Tombukt2
    13,336
    2,401
    That socket pops out I do believe or slides out etc . It is a replacement part if I'm not mistaken but seems no issue as you're not direct scan tool works and flashes and transmits data I assume you didn't say it did but said it worked . Seems like the states tool is failing not car . Pass my car . It ain't broke not a light on anywhere . The tailpipe sniffer is in range see the display? Don't look at me buddy this is a Toyota you know it passes you can't connect that's state issue not a my car issue . Not holding my car hostage that's why I don't live in these places.
  4. bisco
    52,337
    Those scanners may not be able to read all the ecu’s
    Danno5060 likes this.
  5. Striker_
    Striker_ New Member
    Atlanta, GA
    The pins looked fine but it's hard to tell given the angle. I did some probing and the only thing I found was 30 ohm to chassis on the signal ground of the connector. I shorted the two grounds to try to fix that (like most handheld OBD scanners do internally) and although my scanner still worked, no luck with the emissions computers still.
    I took it to a local Toyota mechanic and they reported that only the left seat sensor and TPMS modules showed up on CAN for them. No clue how when everything showed up for me just yesterday. Going to have a chat with them but weird as hell all around.
