Should I replace old coil springs to strut?
Discussion in 'Gen 3 Prius Main Forum' started by Tekken, Feb 16, 2026 at 1:45 AM.
  1. Tekken
    Tekken Member
    258
    77
    Los Angeles, California
    Hello, i Installed a new pair of front & back Monroe strut on my 135k miles Prius 2013.
    The front pair struct so stiff on bumpy road. As you can see the coil spring differently. Should i swap the old coil spring to a new strut?? Please see picture & advice. Thanks
  2. ASRDogman
    ASRDogman Senior Member
    7,727
    3,961
    The strut was not REALLY designed for a direct replacement. It fits, butttttt......
    As you know... It won't be the same.
    Depending on where you got it from, you can return it for a refund and just get the strut
    from Toyota. Don't forget the bumper and dust cover.
    Yes, the spring itself will be a little weaker than when new, but still better than aftermarket.
    In theory, the oem spring "should" fit in the new strut cartridge.... But who knows....
    All it will take is time and effort to find out. (y):whistle:
  3. Tombukt2
    13,232
    2,392
    The original is a very rate spring you see by the winding at the top being not the same as the bottom the replacements many times are Not vari rate speings. The vari rate will squeeze right in. No issues . You can put the strut tube in a vise and use a wheel to compress vari rate and apply nut if no spring compressor . Many folks have long taken the wall mounted spring compressor down and thrown it away.
  4. indel
    indel Member
    252
    78
    Northwest Indiana
    I cannot understand either the question or the answer.
  5. Tombukt2
    13,232
    2,392
    Two different types of springs they will both interchange on either strut doesn't matter wal mart tools can make it happen no shop needed .
