Latest on battery news
Discussion in 'Gen 3 Prius Main Forum' started by mhdriver, Feb 10, 2026.
  1. mhdriver
    mhdriver Member
    130
    52
    florida
    What's the best way to get a battery these days? I do see Green Bean offering a sodium battery for around $2k, but lots of unhappy customers. I do see people selling batteries on EBAY for about $850 "remanufactured".
    What has anyone done with refurbished batteries and how did they work out? I do remember there was a lithium battery, but it seems that didn't make it. All the latest/greatest batteries seem to have no supply, which tells me they really don't work well enough.
    Just curious to here perspectives. Assume your battery needs replacement today. What do you do?
  2. Prodigyplace
    12,622
    11,806
    Central Virginia
    I personally would search for a junkyard deal. One good option would be something like my scrapped 2017 Prius Two that had the NiMH battery but was scrapped at 50K miles. The Prius One and Two (not Two Eco) had NiMH batteries. I do not know how that translated to the later Gen 4 Trim names.
    hurricos likes this.
  3. bisco
    52,238
    Oem is still the best.
    After that, reliability suffers, to one extent or another
    Prodigyplace likes this.
  4. DirkAshburn
    DirkAshburn Member
    157
    65
    Virginia
    I wouldn't go refurbished personally. For new, be it OEM or otherwise, make sure you get at least a 3yr warranty with it.
  5. mhdriver
    mhdriver Member
    130
    52
    florida
    NexPower sent me an email today. They are now offering the sodium chemistry battery for $1900. One year warranty for a self install. States that Gen 3 requires GT3 solution, whatever that means. I would suspect it means I'd have to pay more for my 2015.
  6. mhdriver
    mhdriver Member
    130
    52
    florida
    After cleaning my EGR/Manifold/PCV system my mileage recovered. Got 50.9 mpg today. I have a Gen 3 trim 5 with the bigger tires, That cuts 3 or 4 mpg off according to Tampa Hybrid. I'm cleaning my fan and holding off on the battery until I get codes.
    bisco and Jameso like this.
  7. ASRDogman
    ASRDogman Senior Member
    7,730
    3,961
    greenbean was horrible! They were selling "used" batteries.
    But they finally got wise and went with Sodium Ion. Which is the way to go.
    No issues with the heat or cold. Mine was same as a normal day when it was in the upper 20's
    for a few days. The charge/discharge didn't change and it held the charge during the cold weather.
    It is something you can do yourself.
    Lithium batteries are good, unless it gets very cold out. Or they get wet...
    The sodium ion is a much lighter, stronger, and safer battery.
  8. hurricos
    hurricos Junior Member
    66
    Burlington, Vermont
    This is what I do. I have almost exactly the same thing you do - a 2017 Prius battery from a front-end collision with 44k miles. I paid $720.
    bisco and Prodigyplace like this.
  9. mhdriver
    mhdriver Member
    130
    52
    florida
  10. hurricos
    66
    Burlington, Vermont
    > When did you buy your battery? What was after tax cost?. I'm assuming you installed yourself. How was the core handled and did it actually improve your mileage? And finally, what year Prius and how many miles before your original battery went bad?
    Brown's Auto Salvage in VT.
    $720 was after tax, might have been a little lower - I think it was $660 before tax? I can go find the receipt if you care about that kind of difference. VT state.
    I haven't installed this one yet; it's a spare. I work on Gen2 Prii often for my makerspace friends. In theory, I bought it in advance for a 2008 Prius with 216K and its original battery. It's doing fine, I just like to be prepared because the unexpected is not free to navigate around, and I have enough of these cars in my orbit.
    The salvage yard did not want a core. I've bought three batteries this way. In the past, businesses haven't asked for a core, though I'm guessing that in this tariff environment, the demand for the core will increase as availability dries up. In one of those cases the core was reused elsewhere (repacked into the battery case of a different friend who had not started his car since 2019 after receiving P08A0).
    Disposal of the second core, which replaced a shadetree reman, has become a problem, since I needed the case, and my local Toyota dealership refused to even see it; besides that, I've heard tell that, even when packed into cases, Toyota doesn't want hybrid batteries that have non-sequential-serial cells.
    Improve mileage? I haven't checked or cared. My goal has been minimal TCO at maximum convenience and reasonable safety. I've only replaced batteries that throw codes; I don't care about the difference between 37 mpg and 50 mpg.
    As an an anecdote, the first broken Prius I'd bought made 48mpg doing 75 from Burlington to EWR on a 2023 reman Green Bean battery bought from a junkyard for $450+tax. 2007 Prius, https://downloads.laboratoryb.org/reports/CARFAX_2007_PRIUS_JTDKB20U673205431.pdf, around 170K. This had its original battery.
  11. Prodigyplace
    12,622
    11,806
    Central Virginia
    Mine was t-boned in the passenger door by a 4Runner.
  12. mhdriver
    mhdriver Member
    130
    52
    florida
    The thing about these batteries is I don't think they store well without degrading. Correct me if I'm wrong. So having a spare battery, no matter how cheaply you come into it, just isn't worthwhile.
  13. hurricos
    66
    Burlington, Vermont
    I've heard many things on PriusChat, and (outside of evidence- or citation-backed claims) never found them true. The premise of using junkyard OEM packs supports this; the lack of commentary from Toyota about degradation of their NiMH packs after long periods of sitting also supports this. Even if the packs *did* degrade, so long as they degrade evenly across all cells -- a feature of using non-reman OEM packs -- the result remains a totally functional pack which does not throw codes nor encourage poor power management behavior from the car.
    NiMH has high self-discharge rates (see citations to #Self-discharge-rates), and self-discharge rates that vary cell-to-cell as SoH changes, so it's possible that PriusChat-cited anecdotes are emphasizing the lack of capacity of the battery on first start after storage. I don't know the logic in the HV ECU, but it's possible that'd suffice to trigger "channel goes low" codes.
  14. Mendel Leisk
    41,791
    #14 Mendel Leisk, Feb 17, 2026 at 12:05 PM
  15. hurricos
    66
    Burlington, Vermont
    I can't find a confirmation on the HS code for the G9510-47060; I have one record found where a G9510-47060 was accepted to an Indian port as 8507.5000. Harmonized Tariff Schedule does not have JP in the "special rates" list, so it should be a 3.4% tariff. (To get the details on the column meanings, roll over the (i) button near the "RATES OF DUTY" header.)
    Just because Amayama offers a price, doesn't mean they have the stock, and doesn't mean it's available ... but we are talking a Prius battery here, not Honda Insight parts.
  16. Mendel Leisk
    41,791
    That's never been my experience, albeit with smaller purchases. And if they don't have something, they've always said as much.
