Engine moves with transmission shift?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Untimely Mechanic, Oct 11, 2024.
Tags:
  1. Untimely Mechanic
    Untimely Mechanic Junior Member
    St. Paul, MN
    Greetings:
    The attached videos are of my 2007. The behavior occurs when shifting from Park to Reverse or Drive, and I'm wondering if it's normal or if it means something is loose!
    Thanks!
  2. Tombukt2
    13,240
    2,392
    Yep that's engine torque flexing mountst doesn't seem too too bad.
  3. Mendel Leisk
    41,791
    Something to keep in mind, if you’re doing something like mounting an oil catch can.
  4. Has Raf
    Has Raf Member
    180
    43
    Stoke-on-Trent, England
    IMG_2779.jpeg Worn engine mounts? Check lower engine mount underneath.
  5. Untimely Mechanic
    St. Paul, MN
  6. pasadena_commut
    pasadena_commut Senior Member
    2,754
    822
    Southern California
    I suggest you replace that. The rubber doesn't compress much so the motor motion you see now is from those cracks and the gap on the bottom (if that isn't just a shadow) closing and opening. When that horizontal crack close to the nut goes all the way across and that block of rubber works its way out there will a lot more motion than you see now.
    Some people repair these things by filling the gaps with various rubber compounds. It needs to cure for a day or two before use or the new stuff will just extrude out. Replacing it would be a better fix, but filling with rubber compounds is much less expensive.
  7. Untimely Mechanic
    St. Paul, MN
    What is that thing called?
  8. pasadena_commut
    2,754
    822
    Southern California
    What thing? The motor mount? The rubber in the motor mount? For the latter search for "fill motor mount".
    This isn't a recommendation but this page gives a pretty good description of how to fill a motor mount:
    https://www.suspension.com/diymmi
    Looks like the cure time is longer than I remembered. Caution, many people try filling, find the ride is then too rough, and
    end up buying the OEM ones anyway.
    OEM mount part numbers (don't know if all of these are still available, probably?):
    https://www.amayama.com/en/genuine-catalogs/epc/toyota-usa/prius/NHW20L/8936/engine/1107
    There are also aftermarket motor mounts, see for instance:
    2007 TOYOTA PRIUS 1.5L L4 ELECTRIC/GAS Motor Mount | Shop Now at RockAuto
