P0A80 code + engine misfires?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pdxprius2010, Feb 16, 2026.
  1. pdxprius2010
    pdxprius2010 New Member
    Portland, OR
    The first appearance of the P0A80 code on my vehicle (2010 prius at 200k miles) was accompanied by multiple misfires and some rattling from the engine bay, which stopped after about 10/15 seconds. The misfire codes have since gone away on subsequent ignitions but the rattling has come up again once.
    Basically wondering - can hybrid battery deterioration cause engine misfire, or is it likely a separate/unrelated issue?
  2. rjparker
    10,608
    6,653
    Most likely separate issues.
    Brian1954 likes this.
  3. ETC(SS)
    7,379
    It's possible that your 12vd battery is bad instead of the larger traction battery- but yep.......if your traction battery is original then it could be the "Replace Battery" code.
    I'm a little more concerned with the misfires and rattling under the hood.
    I'm not aware that a knackered traction battery will cause those symptoms.
    Google: "Prius Death Rattle" and check your coolant level soon....like when you read this.
    If at all possible, stop driving the car immediately.
    Coolant loss can cause an over-temp issue which can damage your engine in seconds.
    200,000 miles is a good run.
    Usually the head gasket fails before then..... ;)
    #3 ETC(SS), Feb 17, 2026
    pdxprius2010 likes this.
  4. rjparker
    10,608
    6,653
    On initial startup an early head gasket leak can cause a lot of misfires with resulting severe rattles and not set a code.
    The logic at startup requires several misfires in the first 1000 revolutions to set a non-illuminating pending code (1st trip).
    A second sequence of 1000 revolutions with misfires has to occur again (second trip) to set a current misfire code.
    The coolant needed to cause a cylinder misfire can be counted in drops and often stops misfiring in a few seconds. At first the misfire rattles are occasional and do not occur on every startup.
    Normally an early head gasket leak has burnt off the coolant before the second trip and the engine runs smooth with no misfire code.
    A coil, plug or injector as the root cause of a misfire continues and easily codes.
    As a hg leak becomes more advanced the misfires might last long enough to code and eventually the engine will show coolant loss.
    An articulating borescope is an effective hg diagnosis. Compression, leakdown, combustion gasses in the coolant and coolant in the oil testing usually are not good enough on these engines.
    Borescope tests should be run on a cold engine with the coolant system manually pressurized.
    Car Care Nut HG Borescope at 660s
    South Main Auto
    Excellent Borescope Footage at 6:50
    Articulating Borescope on Amazon
    #4 rjparker, Feb 17, 2026
  5. pdxprius2010
    Portland, OR
    Thanks for the replies -
    Engine coolant is reading low. Havent replaced coolant since I purchased the vehicle used at 140k miles. Topped it off when I did a full clean out of the egr system a couple years back. Since then have had an engine misfire code once, but it went away for a year and did not come back until this past week (when hv battery code also appeared).
    12v battery also reading low and should be replaced.
    Thinking as a plan of action: 1. top off coolant, 2. Install new 12v batt, 3. Conduct further diagnostic on engine / hv battery
