Just spoke to an alignment guy who told me that the Prius has no caster/camber adjustment for the tires. Makes me feel like buying a toe alignment kit from Amazon and just watch how my tires wear.
There is some "play", so extreme minor adjustments are possible. And there are special bolts you can buy to make camber adjustment. The toe in/out and caster are the most important ones. Mine has always had a slight drift to the right. Which tells me the alignment is set for a perfectly level road. In Florida there is a 2 degree ( I think it's 2) slant to allow the water to drain. The outer edge of the RF tire, and inner edge of the LF tires wear a little more. Rotating them front to back, then swopping left to right to left evens them out.
Edit: I'm an idiot, the below was for the Gen2 Prius; I'm in the wrong forum. .. There are bolts Toyota supplies to adjust camber on the front tires -- see the XW20 service manual, page SP-4, section "7. ADJUST CAMBER". One example bolt P/N is 90105-15017. Edit: ha, hahaha. I totally knew you were talking about the Prius V, because I totally noticed I was in the Prius V / Gen3 Prius forum. Ha. Hahaha.
Specialty manufacturing makes crash bolts with your camera adjusting bolts that go where the big 19 mm bolts go that holds your knuckle to the strut I have on a few toyoda's but not Prius so far. Generally a toe adjustment . You just want at least a few times in the car's life while you have it the car to be thrust w heads on wheels to be sure you're in the green . This isn't a vehicle where we need to negate camber and all that stuff you're going to drive like that get a Rolla xre or such
I don't know what that kit is. Does it attach to the front and rear wheels and use a string so you can measure the distance from the 3 and 9 o'clock positions of the front wheels? Actually, the rims. The tires won't be even. That should get you close enough. Then watch the wear on the outer edges of the tires. If the outer edges are wearing more, you have too much toe in. If it's the inner edges, it's toed out too much. Any adjustments to the tie rods should be evenly.
Toplamper Wheel Toe Alignment Tool Kit for at Home DIY Garage Use, Stainless Steel Toe Plates with Dual Tape Measures, Quick Front-End Toe Check Amazonkit by mhdriver posted Feb 18, 2026 at 2:21 PM
Front toe is easily adjustable, I think by just loosening the locknuts ands turning the steering tie rods in/out. also for the front, either caster or camber (I'm not clear which) is adjustable, by sub'ing special bolts. In the rear NOTHING is readily adjustable, AFAIK the rear camber can be adjusted, with an aftermarket shim kit, which requires removal of the rear wheel bearing assembly to be installed. Not trivial. I think Toyota just says replace the solid axle if something's out of spec.
I have something similar to that it's just a magnetic device that's sticks on your hub and rotor assembly with magnet kinda like dial. Indicator on mag base. There's an alignment place in my town that will Mount the 4 heads on the four wheels and said everything for 50 bucks so I kinda do that every other tire change etc . I've gotta go in soon went from sliding ice to pavement really loaded up suspension . Handled surprisingly well to. No braking ice . Then to dry pavement during 360. Kind of righted the car very quickly
