Is this good MPG ?
Discussion in 'Gen 4 Prius Fuel Economy' started by PriusLover2019, Feb 20, 2026.
  1. PriusLover2019
    PriusLover2019 Junior Member
    Bangladesh
    2019 Prius Prime
    I have Prius 2019 A touring Japan one with 17inch Rim
    I drive in Bangladesh heavy Jam and I get 56 MPG combined according to the lifetime run of 53K KMs
    BTW, I have ZVW51 chassis
    Is this fine?
    #1 PriusLover2019, Feb 20, 2026
  2. BiomedO1
    4,105
    2,148
    SacTown, Ca
    It depends on how much of that is all EV driving.
    Mine is around 83 mpg and has been as high as 102 when I was still commuting to work - 15 miles one way. obviously I could've charged on both ends and not use any gasoline at all. I usually fill-up at least once a month, but I don't sit in traffic either.
    YMMV
  3. bisco
    52,363
    Excellent if you don’t plug in
    PriusLover2019 and BiomedO1 like this.
  4. PriusLover2019
    Bangladesh
    2019 Prius Prime
    It is Just Hybrid, Not PHEV. hehe :)
    So it is Fine?
  5. BiomedO1
    4,105
    2,148
    SacTown, Ca
    Your bio suggest it's a PHEV; that is the "Prime" designation used here in the States that it's a plug-in. As opposed to a standard non-plug-in Prius. Toyota's current designation has dropped the "Prime" designation all together and simply call them PHEV. A premium package would be known as a Touring or XLE package on this side of the pond. NOT a Prime.
    Run a couple of tankfuls of gas and do a manual calculation to get your average fuel consumption. It's different for everyone, depending on terrain, traffic, weather, tire inflation pressures, condition of the roads you travel on; and AC usage.
  6. bisco
    52,363
    It’s way above average!
  7. VelvetFoot
    VelvetFoot Active Member
    1,178
    461
    New York State
    2026 Prius
    Also, are those imperial gallons?
  8. Tideland Prius
    16,611
    4.2L/100km? (23.8km/L). That’s fantastic in heavy traffic. Usually get that in normal traffic (which I guess would be considered light in your area haha). In light traffic, (morning or late evening), I can drop it below 4L/100km.
