Any reason to replace my MAP sensor?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mhdriver, Feb 21, 2026.
  1. mhdriver
    mhdriver Member
    158
    61
    florida
    205k miles, not getting a code from it. Mileage is 49 mpg. I bought one from Amazon for about $24. I can either return it or toss it on, Which should I do?
  2. VelvetFoot
    VelvetFoot Active Member
    1,234
    485
    New York State
    2026 Prius
    wrong forum
  3. mhdriver
    mhdriver Member
    158
    61
    florida
    Definitely! My mistake. Thanks.
    VelvetFoot likes this.
  4. BiomedO1
    4,166
    2,181
    SacTown, Ca
    IMHO; if it ain't broke - DON'T screw with it. Attached is an example of replacing stuff that's working fine. Especially if your going to install a non-OEM and possible counterfeit part in place of an OEM part. MAP sensors don't really wear-out; unless you've removed the air filter and it's constantly getting pelted by debris. Just change your air filter every 30K miles.
    #4 BiomedO1, Feb 21, 2026
  5. Mendel Leisk
    41,925
    I think there'd be a code if there was any problem with the current MAP (Manifold Absolute Pressure) sensor. It doe sit in a bit of a cesspool though. I'd leave it be.
    ^ Looked up the part nunmber using Google AI, got this:
    89421-47010
    $24 USD on Amazon, sounds a bit sketchy...
    Couple of reputable links:
    Buy Genuine Toyota 8942147010 (89421-47010) Sensor Assy, Vacuum. Prices, fast shipping, photos, weight - Amayama
    Vacuum Sensor #89421-47010 | Autoparts.toyota.com
  6. mhdriver
    mhdriver Member
    158
    61
    florida
    Yeah. I'm just going to get MAF sensor cleaner and clean them both. That is the MAF
  7. Brian1954
    Brian1954 Senior Member
    2,411
    968
    South Central PA, USA
    FYI, I have reported this to the moderator and asked it to be moved to the Gen 3 forum.
  8. mhdriver
    mhdriver Member
    158
    61
    florida
    Good idea :).
  9. Tideland Prius
    16,621
    *moved*
    Brian1954 likes this.
  10. PriusCamper
    PriusCamper Senior Member
    13,078
    5,306
    Pacific Northwest, USA
    Do both!
