2011 engine light shake when starting after new plugs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by icyrius, Feb 21, 2026 at 1:37 PM.
  1. icyrius
    icyrius Active Member
    240
    114
    Florida, USA
    2014 Prius v wagon
    Hello,
    I noticed after installing a new set of spark plugs (Iridium DENSO SC20HR11), the engine does a light 2 second shake when turning on after switching from ECO. However, the rattle sounds like it’s coming from the exhaust touching the catalytic converter protector I installed due to theft in my area. Could this rattle be caused by the new spark plugs? I should I try better gas in my tank or something?
    Thanks
    52,258
    How many miles on her? Are you losing any coolant?
    Where did you get the plugs?
