2009 Prius 248000km Death triangle no codes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cmd_car, Feb 4, 2026.
  1. cmd_car
    cmd_car New Member
    Sydney, Australia
    i-Tech
    I am new user/ new owner of a Prius 2009
    I bought a 2009 Prius with 248 000kms in it and after about 3 days there came a big triangle warning on dash with exclamation mark. I used a OBD2 scanner but no error codes.
    Then I went onto check battery (12V)
    without engine ON voltage was about 11.9 with engine ON it is 13.8 V
    After about 5-6 hours I realised no Big triangle sign/ exclamation on dash
    I went to an auto shop and check ed the 12V battery and the reading was 12.25V CCA measured 267 CCA (rating 370 CCA)
    The battery is AGM 5511 battery and as per the previous owner of the car who had it for 10 years, battery was never changed. ( I doubt it)
    Does this mean my 12V battery is bad? or brake actuator failure (as a friend of mine suggested)
  2. Tombukt2
    13,264
    2,395
    I think more than likely that cheap think scanner just can't see all the computers in the car to get you your codes the red tri. Is telling you pike hayeee take a peek over herr at this orange light .... Your scanner may not know what that orange light is attached to so it thinks all systems go . Cars got too much going on for some tools
  3. bisco
    52,263
    If the battery is ten years old, change it.
    Then get an autel maxi 200 to read the codes
  4. BiomedO1
    3,998
    2,103
    SacTown, Ca
    I took a quick look at thinkobd 100 and it's a BASIC OBD2 reader for ICE cars. NO access to ABS or Traction battery ECUs - It's only looking at the ICE ECU. So go find a better scanner that will scan ALL ECU's in that car. If it threw a red triangle, there's a error code stored someplace.
    Good Luck..
    BTW; if you had an actuator issue, you'd also get traction control lamp. Get the 12V battery tested; 11.9V isn't low enough to trigger anything. That happens closer to 10.5V.
  5. Brian1954
    Brian1954 Senior Member
    2,362
    949
    South Central PA, USA
    It means that you need a better scanner to read the trouble codes. If the warning lights are on, there are trouble codes that should be read.
    Read post #1 and then scroll down to post #37 in this thread, https://priuschat.com/index.php?posts/3246758
    I recommend the Autel AP200. It is a Bluetooth OBD2 dongle and you install the Autel app on your phone. You need internet connection to set it up.
  6. cmd_car
    cmd_car New Member
    Sydney, Australia
    i-Tech
    I got the car checked at a Hybrid expert and they could not find any faults with main battery or the 12V battery-He also thinks the warning may have come up from drained 12V battery. I did a 1.5 hr drive at 70-80kms most o the time , so hopefully it will charge up 12V battery. Slight relief (fingers crossed).
  7. scargi01
    scargi01 Active Member
    785
    58
    Missouri
    Did you check the oil?
  8. PrimalPrius
    PrimalPrius Junior Member
    72
    America
    Yep. 12V battery with low voltage causes red triangle. (Although based on my experience it's not consistent).
    (Had it most recently today. Or technically yesterday. I was scanning codes and the triangle appeared. Cause was that the car had managed to suck my 12V down to 10V. Battery capacity must have gotten very low. My fault as there have been a few times I have forgotten to disconnect the 12V battery after driving or thought that I would be driving again soon, but didn't.
  9. ChapmanF
    18,435
    Did he tell you what the trouble codes were?
    That's more important here than whatever J. Random Hybrid Expert may have thought they meant.
    If he didn't tell you the codes, maybe you can call back and find out if he kept any record.
  10. Brian1954
    2,362
    949
    Was the "red triangle" on when the mechanic scannered for trouble codes?
    If so, what trouble codes did the mechanic find?
  11. PrimalPrius
    72
    America
    On my car, red triangle caused by low 12V battery voltage does not appear to ever cause a code, but modules like ABS/VSC/TRAC can log "Low battery positive voltage" or something like that.
    (My money says that this was done on purpose to prevent lots of trips to the dealer during warranty period for a code that just requires charging or replacing the 12V to fix).
    #11 PrimalPrius, Feb 9, 2026
  12. cmd_car
    cmd_car New Member
    Sydney, Australia
    i-Tech
    Battery was tested and said to be fine- I even charge the battery using a battery charger -when I connect the battery the warning lights came back on and stayed for about 1 day-during that 1 day period I drove about 70kms and the warning lights disappear again.
    yes- all the fluids are in normal levels and circulation of the inverter cooling fluid is OK too
    He found no codes (but he was unable to figure out which scanner to use initially) He tried few scanners and seems to found no codes
    No red triangle when he checked the car
    #12 cmd_car, Feb 16, 2026 at 5:35 AM
  13. cmd_car
    cmd_car New Member
    Sydney, Australia
    i-Tech
    Apart from above_ I noticed that red triangle do appear on very hot days. The first time it came the temperature was about 40 C and today also it came up (temperature was 34 C) . I checked the inverter fluid circulation-it seems OK
  14. BiomedO1
    3,998
    2,103
    SacTown, Ca
    Have you cleaned out and tested the traction battery cooling fan assembly? The error may be related to the traction battery getting too hot?? You need to use your AC system, since the traction battery air intake is pulled from the car's internal cabin.
    Are you talking about the 12V battery or traction battery? As I stated earlier, you need a better scanner to read the rest of your onboard computers.
    #14 BiomedO1, Feb 16, 2026 at 10:22 PM
  15. bisco
    52,263
  16. cmd_car
    cmd_car New Member
    Sydney, Australia
    i-Tech
    I purchased Autel AP200 and plugged in to OBD2 port but it does not get connected to the phone via Dr. Prius app-The default app get connected but it does not provide any error codes. I checked Dr Prius app and it says use Panlong OBD2 scanner . But amazon clearly flags it is not suitable for my car. I am bit confused what to do..wonder if the discussion forum details are actually reliable or am I doing something incorrect?
  17. mr_guy_mann
    mr_guy_mann Senior Member
    4,072
    1,990
    NJ-USA
    Did you:
    - Install the Autel MaxiAP200 app;
    - Create an account with Autel & activate the dongle (with the dongle serial number);
    - Choose Toyota as the "free" car brand;
    - Download the Diag Asia & Toyota apps;
    - Connect the dongle & phone via bluetooth;
    - Launch the app - select your "area" (Australia? I assume) - then select Toyota - year - model & connect to your car;
    - Autoscan all systems
    The Autel device and app only work with each other. You would need a different device for DrPrius. (it's an app that's useful for monitoring HV battery data but otherwise is quite limited)
    Brian1954 likes this.
  18. cmd_car
    cmd_car New Member
    Sydney, Australia
    i-Tech
    bought
    Veepeak OBDCheck BLE and it was able to do the job.
  19. Brian1954
    2,362
    949
    The Veepeak will work well with the Dr Prius app, but the Dr Prius app is very limited when it comes to reading trouble codes. The Autel AP200 is capable of reading all the trouble codes that the Prius could have. Install the correct Autel app like described in post #17.
    What codes did the Dr Prius app find?
