Oem Brake Pads
Discussion in 'Prime Main Forum (2017-2022)' started by Joe Wall, Feb 22, 2026.
  1. Joe Wall
    Joe Wall Member
    242
    52
    Wisconsin
    What oem brake pads do you recommend for a 2017 toyota prius? Any links for best pricing?
  2. Joe Wall
    Joe Wall Member
    242
    52
    Wisconsin
    Prius prime
  3. rjparker
    10,461
    6,564
    oem... I would input your exact trim to verify pn
    25% off deal ends in 6 days
  4. BiomedO1
    4,090
    2,140
    SacTown, Ca
    Just a quick footnote: If your not doing anything to the rotors - you should at least measure them. If they're too thin, your going to get rotor warp, brake pulsation; halfway through those new pads. Possibly flush out the brake system while your at it; if you don't have the brake fluid replaced at a regular interval.
  5. Mendel Leisk
    41,865
    The Car Care Nut (youtube channel) was saying there's 2 levels of OEM available. Not sure if that's still the case, or just in the States. Anyway, a call or visit to dealership would clarify what's available, and as aforementioned, you might want to have the VIN at the ready. In my experience, just saying "I need front/rear brakes pads for "this model of such-and-such model year" has always sufficed.
    More info on rotor specs and how to check, in my signature (3rd gen rear brake drag info attachment). (on a phone turn it landscape to see signatures)
    #5 Mendel Leisk, Feb 22, 2026
