OEM TPMS sensors from the dealer are definitely more reliable and avoid most compatibility issues. But I’m using Autel sensors on mine and programmed them with a TPMS tool—no problems so far. DIY guy passing through.
unfortunately here in NA, the CC3’s aren’t coming for a while hence I fitted the CC2 on my recently acquired’26 PHEV in SE trim using 215 55 17 but the dealership had to install new alloy rims and couldn’t use the OEM rims (not exactly sure why) as it had something to do with the fitment/width of the new tires vs OEM. I used tire size comparison and the specs are within tolerance but hey, dealership supplied the new alloy rims as part of the deal so why not
A 215 tire is slightly oversized but doable on the 6.5 OEM wheel. I can understand though the dealership not wanting to do it to protect themselves from liability issues.
I think you’re right that it was the main reason why (avoid any liability issues) but as it turned out, the new alloy rims they installed looked better than the stock OEM wheels with hub caps and OEM tires (stored in their storage for 3yrs free btw), see the new rims:
BIG difference on wheel and tire weight compared to my dead 2009. I was surprised how much more the OEM 2026 weighed.
