Key transponder. Chip model?
Discussion in 'Gen 2 Prius Technical Discussion' started by Hello1024, May 28, 2024.
  1. Hello1024
    Hello1024 Junior Member
    UK
    Got an ID67 chip and tried to program it to my car as a 2nd key using the 'chicken dance' method. Got the "2-1" error (registration failed), which is exactly the same error as if you just put a pen in the slot (ie. it doesn't see the new key chip at all).
    So... to all you technical people:
    * What model(s) of chip are acceptable? transpondery says "Transponder Texas Crypto 4D DST / ID67 / JMA TPX2 / Errebi TX2 / CN2, CN5 / K-JMD; OEM Key: 89994-47061 89994-47060 and others."
    * Does the chip need to be 'precoded' (ie. some data written to the chip) before enrolling it? mhhauto suggests that "page 1" of the chip needs to be written with the data "32 or 52" to mean a master key. Does the car itself write that during enrollment, or must it be pre-written?
    * Does the european version of the gen 2 prius use the ID70 chip instead of the ID67? Other toyotas of this era seem to all use ID70 for EU versions...
    (note that all of this is about the *transponder* - ie. the bit that is detected with the key in the slot. Not asking about the 'smart key' part or the remote lock/unlock part, which are different chips and different keying mechanisms.)
  2. Tombukt2
    13,733
    2,486
    The transponder system is that little trapezoidal shaped piece in the very bottom of the key fob not the green board correct?
  3. Tombukt2
    13,733
    2,486
    You have the original key fob to this vehicle that you're doing whatever you're doing to and behind the Toyota logo there's not a gray FCC or whatever registration for all the electronic numbers and what have you for that particular fob that you're looking at in your hand at the time? Have something like ID 3675 I have to go look at a picture.?
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,009
    NJ-USA
    I pinged my US spec Gen 2 fob with Autel KM100, and got an ID of: TIRIS DST 4D (and the chip unique ID number).
    IDK if the chip you have is programmed with an ID or not (some might be blank and need a programming tool to make or clone the ID?)
    Years ago I got a "normal" RFID transponder chip blade type key as a backup. It's cut to unlock the door and the chip is programmed into the immobilizer. However, in order for the dash slot to read it and allow the car to power up, I have to insert the key head in one orientation. If it's flipped around the transceiver won't detect it.
  5. oschn
    oschn Junior Member
    26
    @mr_guy_mann do you still have the Autel KM100? Could you check which data is written on page 1? I suspect it should be 33 or 53.
    And cound you also check if it is maybe 4D70? I suspect the lists online are confused and target gen 1 Prii when they're saying 4D67.
  6. Tombukt2
    13,733
    2,486
    I scanned a gen3 and got ID4 tags . I couldn't complete what I was doing because the launch 4:35 scanner was locked for immo functions per some following of an industry wide ADoptionof some BS .
  7. oschn
    oschn Junior Member
    26
    Yeah, 4D seems to be a given. But which 4D is actually used, I find conflicting information. I really am about to buy this stupid VVDI tool to just finally get an answer to this
  8. Tombukt2
    13,733
    2,486
    I'm looking into k518 key tool completely wireless all keys lost unlocked for all markets
  9. oschn
    oschn Junior Member
    26
    Could you please check which 4D chip is used with Prius gen 2 fob?
  10. Tombukt2
    13,733
    2,486
    If you go to UHS supply and look up transponder chip . UHS sells one traezoidal chip that covers all protocols or most of you can read the specs of said chip on site it can be burned with many protocols id4 etc . You're going to burn on that ship the data you pull with your k518 from your IMO box which is up behind the intake on the passenger upper dash clearly marked it's wer fresh air enters HVAC system hidden very well . Need flashlight to see it.
  11. mr_guy_mann
    4,109
    2,009
    NJ-USA
    Here's what the tool shows when I pinged my fob. I'm not a locksmith so not sure what kind of data it should be showing. IMG_20260227_134031255_AE.jpeg
  12. Tombukt2
    13,733
    2,486
    And now if your tool could do it you could buy the chip from UHF supply and burn that transponder ID number on to that chip and you're car will see that chip you burned .
  13. Intuitionx2
    Intuitionx2 New Member
    usa
    I believe you need
    4D69 Transponder Chip
    Tombukt2 likes this.
  14. Tombukt2
    13,733
    2,486
    Yep uhs supply has em for like 4.98 .in stock
