Issue selling 2017 Prius to Carvana due to diagnostic scan
Discussion in 'Gen 4 Prius Main Forum' started by S1n, Feb 22, 2026.
  1. S1n
    S1n New Member
    Hey everyone,
    I am selling my 2017 Prius to Carvana and ran into an issue during my drop off appointment yesterday. When the advocate inspected the car, their diagnostic scan tool (Bluetooth dongle), which is FIXD brand, was not able to read my vehicle. It connected but the message indicated that the car was not responding to the sensor. Because they were required to submit a successful scan to their system, they were unable to proceed with the purchase. The advocate asked me to reschedule the appointment and take care of the issue before coming back. I mentioned that the scan tool itself might be the problem, but she explained that she had used the same tool on other cars earlier that day without any issues. She even tried scanning my car again with me present, but the result was the same.
    After leaving, I tested the car using two different diagnostic scanners (Bluetooth dongles) that I own, and both connected successfully and read the vehicle without any problems. Because of this, I do not think there is an issue with my OBD port, wiring, or fuses. It seems more likely that the FIXD scan tool they use does not work well with my car.
    I have read a few posts from others who experienced similar issues when selling to Carvana, but I have not found a clear solution.
    Their offer is pretty good, and I do not want to miss it. I am rescheduled for another appointment next week, and I want to make sure the scan works smoothly this time. Has anyone dealt with this before or found a workaround? Any suggestions would be appreciated.
    52,337
    Can’t you bring your scanner and show her?
  3. S1n
    S1n New Member
    No unfortunately. I was told that they have to use their own scanner to proceed.
  4. Tande
    Tande Active Member
    550
    337
    Mich.
    Call Corporate? ......
  5. Boston_Pilot
    Boston_Pilot Junior Member
    Seaside Park, NJ
    2020 Prius Prime
    Would that have any real effect? Can’t make them but the car…..that’s pretty damn frustrating though. Maybe a different location?
  6. S1n
    S1n New Member
    Just an update:
    I purchased a FIXD diagnostic tool that seemed to be the same as the Carvana advocate used. So far it works just fine. Connects and scans. When I try on accessory mode, it doesnt connect though. Looks like the advocate run the scan in accessory mode, not in ready mode. That's what I suspect, but we will see on Thursday. I will update. Thanks for comments.
    ColoradoBoo and bisco like this.
  7. S1n
    S1n New Member
    Last update:
    Today they were able to scan my car and everything went well. I made sure that they scan on the ready mode after explaining what happened last time.
    Seems like the problem first time was what I expected. The advocate tried to scan it on accessory mode and it didn't read the car.
  8. rjparker
    10,438
    6,545
    Your car is not communicating until you get to On mode or Ready mode. Accessory is one push without brake, On is two pushes without brake.
    S1n likes this.
  9. Boston_Pilot
    Seaside Park, NJ
    2020 Prius Prime
    Am I missing something here? Didn’t he just say that was the issue, as he suspected?
  10. rjparker
    10,438
    6,545
    He said he had to go to Ready. Going to the On state would have done it.
