DashCam Battery Thoughts?
Discussion in 'Fred's House of Pancakes' started by VelvetFoot, Feb 26, 2026.
  1. VelvetFoot
    VelvetFoot Active Member
    1,162
    459
    New York State
    2026 Prius
    Yes, not your usual pancake thread, but there are no forums that cut across models, so here I am.
    I put in a couple of dashcams. Parking mode would be a nicety, and so, the need for a battery.
    Dashcam batteries are still pretty expensive.
    I just tried a Duracell power pack I had laying around. Wouldn't work. Not passthrough charging. Only does one thing at a time.
    I was hoping to plug a battery pack into the car's usb-c connection and the dashcam into the battery.
    I suppose there are li-ion safety concerns, but not sure how realistic they are in my use case, here in upstate NY. LiFePo could be an option I suppose.
    The power stations get too bulky, and no need for 120VAC.
    Thoughts?
  2. Prodigyplace
    12,654
    11,824
    Central Virginia
    Why not tap into your 12V battery? That is what the Toyota sold camera on the 2025 Camry does. IMO DashCam should be included in the packages that include the panoramic view cameras since most all the hardware is already there for 260 monitoring.
    Perhaps your Prius has the camera connector behind the rear view mirror roof panel.
  3. VelvetFoot
    1,162
    459
    New York State
    2026 Prius
    I have two cameras already installed.
    No, on the LE, nothing to hook up to.
    I don't want to put any stress on the small 12v battery when parked.
    Hence, the external battery.
    If I unplugged and replugged to the Duracell power pack mentioned above, it would work but be a pain.
    I have a mini UPS by Talent Cell that would work. It needs 12v input.
  4. ETC(SS)
    7,330
    Easy answer....
    Prius. :rolleyes:
    Talent Cells are popular in the amateur radio community's crazy preppers corner.
    "I'm told" that many TalentCell rechargeable lithium-ion battery packs support pass-through charging, allowing them to power devices while simultaneously being charged.
    TWO dashcams?
    Couldn't you just get ONE good one?
    Good Luck!
    #4 ETC(SS), Feb 26, 2026
    Prodigyplace likes this.
  5. VelvetFoot
    1,162
    459
    New York State
    2026 Prius
    Less complex, for me, wiring.
    Not hardwired.
    There are usb-c power ports for the rear passengers as well as the front.
  6. Prodigyplace
    12,654
    11,824
    Central Virginia
    The 2025 Camry has the same anemic battery issue but the Toyota Webcam accessory uses it. All 2025 and newer Camry are Hybrid only.
  7. VelvetFoot
    1,162
    459
    New York State
    2026 Prius
    Parking mode could be a battery killer. I'm not looking for trouble.
  8. Trollbait
    12,662
    If you are using the 12V outlet, nearly all cars cut power to that when off. Probably the same with the USB outlets.
    Do these dash cams not have their own battery?
  9. VelvetFoot
    1,162
    459
    New York State
    2026 Prius
    The concept is that the external battery gets charged while driving, with usb power passing through to power the dash cam.
    External battery only when parked.
  10. PriusCamper
    PriusCamper Senior Member
    13,006
    5,287
    Pacific Northwest, USA
    There's lots of threads on here about adding a second 12v battery to the system... That's your solution, but sounds like you don't want to do that. Also what type of Dashcam system did you buy? There should be a battery management settings for parking security. As in I think your solution is going to learn from people who are using the same system as you. Priuschat can't provide that help, but do report back to us and let us know what you come up with.
  11. VelvetFoot
    1,162
    459
    New York State
    2026 Prius
    Be positive.
  12. Trollbait
    12,662
    All the dashcams I've looked at with a parked mode had a built in battery or capacitor. Why do you even need an external battery for these dash cams?
  13. VelvetFoot
    1,162
    459
    New York State
    2026 Prius
    Parking mode. Prius' small battery.
  14. VelvetFoot
    1,162
    459
    New York State
    2026 Prius
  15. Trollbait
    12,662
    Have they become such power hogs that the built battery or capacitor can't power park mode?
  16. VelvetFoot
    1,162
    459
    New York State
    2026 Prius
    I've only had a couple of them, but neither had a backup battery. There does seem to be a capacitor that gracefully powers down the unit after loss of car power.
  17. VelvetFoot
    1,162
    459
    New York State
    2026 Prius
    A truck almost merged into the side of my Gen5 a couple days ago. Its horn could use an upgrade. :)
  18. Prodigyplace
    12,654
    11,824
    Central Virginia
    Toyota's doesn't. It plugs directly into the vehicle that has a 12V feed for parking mode.
    Toyota Integrated Dashcam | Benefits & Features | Toyota Owners
  19. PriusCamper
    13,006
    5,287
    Probably not, but people with brand new cars are always trying to think of new stuff to worry about because their car isn't going to give them anything to worry about for year and years and years....
    #19 PriusCamper, Feb 26, 2026
  20. VelvetFoot
    1,162
    459
    New York State
    2026 Prius
    Whatever. Why comment dude?
