Solar Charging Roof Not Working!
Discussion in 'Gen 5 Prius Main Forum' started by maiki, Oct 30, 2025.
  1. Gokhan
    Gokhan Senior Member
    6,474
    2,590
    Paramount CA
    #161 Gokhan, Feb 9, 2026
  2. Gokhan
    6,474
    2,590
    Paramount CA
  3. Gokhan
    6,474
    2,590
    Paramount CA
    @maiki, could you post the same display I posted, showing each day separately?
  4. AgentPTFC
    AgentPTFC Member
    58
    40
    PNW
    2025 Prius Plug-in
    XSE Premium
    Update on my end. I had accumulation for the first time this year on monday. The morning had showers then was sunny in the afternoon. Then today was more sunny than monday with clouds in the morning but no rain but accumulated less than monday. Im wondering if the extra accumulation had something to do with the water drops on the roof. Needless to say things seem to be working as expected.
    VelvetFoot and Gokhan like this.
  5. Gokhan
    6,474
    2,590
    Paramount CA
    I’m glad it works. Perhaps the rain has cleaned it. You need to keep it sparkling clean for it to work.
  6. AgentPTFC
    AgentPTFC Member
    58
    40
    PNW
    2025 Prius Plug-in
    XSE Premium
    I had a big jump in production this week on a clear sunny day in late Feb. I stored 400Wh over the 8 hours at the office.
    Maiki, I'm curious to hear an update.
    Gokhan and bisco like this.
  7. hill
    8,897
    Here's an interesting perspective /fun facts thinking about 400 watt hours of charge. So, a (now) 7yr old Chevy Volt charges at 7.2kW which - in order to compare - it would take roughly 3½ minutes to charge 400 watt hrs in the 7yr old volt - vs a solar roof's 8 hours!
    Also - presuming a plug-in hybrid gets a relatively decent 3 mi/kWh - that 400 watt hr charge would let you travel a bit over 1mi.
    And isn't it something like a $600 option? Not counting that you have to buy the most expensive optioned prius on top of that - in order for the PV panel to even be offered?
    well - to each his/her own
    #167 hill, Feb 27, 2026 at 1:30 PM
    BiomedO1 likes this.
  8. bisco
    52,284
    No different than expecting a hybrid to save money
    Gokhan and BiomedO1 like this.
  9. BiomedO1
    4,015
    2,109
    SacTown, Ca
    That's why I tell people to do their own DUE DILIGENT; and not listen to the marketing hype. Marketing hype is designed to SELL YOU stuff; NOT save you money. If you want to save money - DON'T buy it......... It doesn't help that the OP is only looking at the mileage counter and claiming that the panel isn't working; instead of looking at Wh stored to see if the panel is actually defective.:(:sleep:
    The roof panel just isn't meeting the OP's expectations. Bottom-line, it's a 200W panel trying to fill a ~8KW battery. It's simple math from there.o_O
    Note: that we aren't taking into account charging losses or losses due to supervisory equipment that regulates the charging process.
  10. Gokhan
    6,474
    2,590
    Paramount CA
    Come on, guys, even if it is not cost-effective, it is a very nice feature. Besides, we even spend money on things that have no direct benefits and even on things that have harm, and this thing at least has a benefit.
  11. Gokhan
    6,474
    2,590
    Paramount CA
    It is clear at this point that there is no malfunction in these systems, but they require strong sunlight, a clean panel, the correct angle of the sun and the car, and so on.
  12. hill
    8,897
    There you Go . . . . . people buy meth, people buy trank & thus - other costs - they're are not as bad. True. Same logic as the spouse in a troubled marriage claiming I'm not as bad as Charlie Manson.
    Hey - who hasn't wasted money on questionable stuff throughout their life when you have extra income - or and you really can't afford it. If you buy a nice car & you enjoy it? You & your circle can easily get in & out of it?
    Enjoy
    LOL
    #172 hill, Feb 27, 2026 at 3:54 PM
  13. Gokhan
    6,474
    2,590
    Paramount CA
    I don’t think people without extra income can even afford the base Prius PHEV, let alone spend an extra $600 on the solar roof.
