Blower motor maybe, but code B1421?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by GreenMeanie, Jan 25, 2026.
  1. GreenMeanie
    GreenMeanie Junior Member
    52
    My 2006 with 113k is not putting out any air from the vents at all. Neither heat nor cold nor defrost. It was making strange sounds a couple of weeks ago, and now I realize that nothing at all is coming out, no matter what the temperature is set to. Code B1421 comes up, but it says that's to do with the sun sensor. To me, it seems like the blower won't blow anything. Not sure how that has anything to do with the sun sensor. Thoughts?
  2. ChapmanF
    18,555
    Two different things. You have some problem with your blower and no code for it (that's not shocking, even modern cars with obd still can have things go wrong that don't set codes), and, unrelated to that, you have B1421.
    B1421 isn't quite any 'trouble' code really, just a tool for you to know whether the dash solar sensor works. If you have B1421 in the dark or the shade, and you don't have it in bright sun, the sensor works.
  3. GreenMeanie
    52
    Yeah, I was wondering if the blower motor would actually throw a code. But does it sound to you like the blower motor is the problem? Figuring out where to go from here. I'm not going to worry about the sensor, since it threw that code before and it never gave me a problem up until this blower motor thing.
  4. ChapmanF
    18,555
    I'm pretty sure if you take it the glove box and then peer in through the recirc air inlet, or pop out the cabin filter and peer in that slot, you can see if the blower is turning.
    If it isn't (and you have things set so it should be), you may also be able to give it a little nudge (watch your fingers) and see if that starts it.
  5. pasadena_commut
    pasadena_commut Senior Member
    2,857
    850
    Southern California
    I think maybe giving it a nudge with the car completely turned off, to see if it spins OK, would be the place to start. If it won't go around by itself for a turn or two after a push the lubrication on the bearing is gone or there is something in there jamming it up. The latter can be fixed, but the former is pretty much a death sentence for the blower. If there are leaves or twigs in there it will often make a sort of periodic crunching noise while it tries to turn. If it spins easily then pull off the external wiring and test the internal wiring with an ohmmeter, there might be a short or open. The next step is usually to see if applying 12V to it will make it run - but only if the blower is designed for that, some expect PWM or other inputs. I don't know what the Prius blower wants.
    Little computer DC fans can often be resuscitated for a while by lubricating them - ones that wouldn't start by themselves will once again. That often doesn't work with larger DC blowers, where access to the bearings to apply the lubricant may not even be possible. Example - the HV pack blower's plastic impeller is permanently mounted to the motor shaft. It is possible to get the case over the motor off the back, providing access to the back bearing, but I have never found a way to reach the front one because that impeller is in the way. If this blower's impeller can be removed, then maybe it can be lubricated.
  6. GreenMeanie
    52
    Ok. The blower motor spins if I give it a nudge, both for hot and for cold. But I'm having to do that every time. What might be the fix for that? Is it a loose wire?
  7. ChapmanF
    18,555
    Worn brushes would be my guess.
  8. GreenMeanie
    52
    Worn brushes...on the blower? Apologies for density; Friday night and all
  9. pasadena_commut
    2,857
    850
    Southern California
    Brushes are the little graphite bits that pass current to parts of the motor which rotate. Those wear with use and slowly fill the motor full of graphite dust, and eventually they become short enough that they stop making contact.
  10. GreenMeanie
    52
    So replacing the blower motor should solve the problem? I've seen the video on how to do this, and I think I can handle it myself. Any place in particular you'd suggest to buy replacement motor, or should this Amazon one work?
    Amazon.com : fans
  11. pasadena_commut
    2,857
    850
    Southern California
    Amazon is full of fakes. Buy at your own peril.
    rockauto.com has some options and their price is usually pretty good. The part they send will in fact be the part you ordered made by the company it claims to be.
    If you want the OEM part call around, dealer prices vary.
  12. GreenMeanie
    52
    Thank you, @Pasadena. I will look.
  13. GreenMeanie
    52
    Just to update and thank all, I ordered a replacement blower from Rockauto, and installed it myself after looking at a couple of YouTube videos. Only tools needed were screwdrivers of both types, socket wrench with allen head, a hand mirror, pillows to lean on, and patience. Works perfectly. Just in time for massive heatwave in SoCal, too.
    All help and advice were most appreciated!
    Brian1954 likes this.
