NE London based Check Hybrid System P0A94-553 172 557
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LondonNET type 3, Feb 27, 2026.
  1. LondonNET type 3
    LondonNET type 3 New Member
    London
    Good Samariton sort to help me please,
    I'm in NE London my car suddenly sort of cut out while accelerating on dual carriageway and gave me quite the scare. Car is getting old 2012 Prius Type 3 and its recently had battery issues in cold weather (Needing jump start and failure to start home charged) and perhaps because of many short trips. As i have been using it to respond locally to medical emergencies in the community. Short distance, less than 5 miles normally. 12v battery is old I now realise likely should have been replaced. (C1241-552 Low or high VM1 5.85v, U0073 Control Module Com Bus off in past reports, U0126-742 Lost coms steering)
    I think what I experienced maybe an inverter/converter failure of sort I read could be replaced free in USA. But I'm in London and haven't had the car recently serviced, so it won't be done under a warranty, and I was told there is no recall of my car here. So fully at my own cost, I expect. I am currently in limp mode, petrol only, and unable to clear the P0A94 to get the hybrid system running again.
    Check Hybrid system appeared entered fail-safe driving mode. So I connected to the car to pull a Health Check. Please any advice or help would be welcomed.
    Hybrid Control
    • P0A94 – 553 DC/DC Converter Performance codes 553, 0, 172, 557, 0
    • P324E – 788 MG ECU power relay intermittent circuit
    ABS/VSC/TRC
    • U0126-742 Lost Comms with Steering Sensor module (7 Mins earlier in drive before Check Hybrid)
    • C1241-552 Low or high VM1 5.85v
    • C1259 HV/EV Control System Regenerative Malfunction
    • C1310 HV/EV System Malfunction
    • U0073 Control Module Bus off (NAV Also had this as an historic code) Com Bus Check all passed
    Plan is to try and get the car back running, then get it fully serviced and new MOT to double check nothing else wrong.
    Plan on replacing 12v Battery, Service to replace all the filters, change oil. Maybe drain and replace coolant? Not sure my inverter coolant pump is working in limp mode but want to test maybe thats in need of replacement. Concerned may need a new inverter or converter IPM replacement is what the guide seems to say though Type A inverter current P0A94 type 1 code 172 after clearing error codes and a test drive. Lots in common with this recall procedure?
    nhtsa.gov/odi/rcl/2018/RCRIT-18V684-6735.pdf
    My Hybrid system reports 896B54708000 refers to a Calibration ID (CID) used by Toyota for a hybrid system software update related to a safety recall. Are DTC s P0A94, P324E, P3004 or P0A1A present YES Does the Hybrid Control System show there is an CID update available? ? think likely never done. We purchaced second hand. If they are not offering any support and its dangerous should I be reporting it to the UK highways, or somewhere?
    Fingers crossed if fix nothing else comes up in MOT.
    Many thanks for any advice or help.
    Alex
    Original fault codes Hybrid failure.png DTC Time stamp.png P0A94 Freeze Error codes hybrid failure.png P324E-788 Converter failure maybe.png P324E-788 High temp.png P324E-788 Odd voltage drop blocks  3 4 11 12.png P324E-788 Engine idling requese MG12 Gate Request now on.png U0126 Lost Com with Steering 742.png C1241-552 VM1 5.85.png C1241-552 info 2.png Screenshot 2026-02-28 000154.png
  2. Mendel Leisk
    42,205
    What’s the miles? The inverter coolant pump may be similar in construction to the engine coolant pump, which has proven prone to fail around 150k miles.
  3. LondonNET type 3
    London
    85000 miles. It's been a good car without any real issues. I had a just eat scooter clip the rear bumper while I was waiting at a red light last year. So little bumper damage there. But not sure what to do really.
    Is there a way to test that easily. In techstream saw water pumps I tried opening the lid on both coolant pumps and running engine but couldn't see any movement. But then it's only running on petrol at moment. Hybrid system isn't running.
