Summary : Pretty Good Condition. Maybe Mild Climate Related? Just tested our 150k mile 2011's HV battery (original). Condition is pretty good. I wonder how much it has to do with our mild climate (Seattle) and car is nearly always garage parked (stay at home mom's car, not work transportation vehicle potentially parking outdoors all day) Mostly shorter around town hilly trips. A couple of longer interstate drives. Most of the failures I read about seems usually from hot climates. Test Setup Test is starting with 50%+ SOC. Car in reverse. Foot on brake and accelarator to discharge the battery with electric motor trying to reverse while monitoring max/min battery module voltage until battery gets low and engine comes on to charge (In my case, engine didn't come on the entire 5min recording window which is another sign of good health) This is a basic test applying a load (electric motor drawing constant power to reverse) and watching the the max differences in battery module's discharge rate. I followed mostly this post link to Arts Automotive Post Recorded Parameters I did min and max module voltage, min and max module #, battery SOC Test Start ( Data @ ~45s on graph ) Test End ( Data @ ~300s on graph ) Detailed Summary SOC didn't drop much. Was wondering if I was apply a load. Car pushed against the brakes as soon as I depressed the accelerator and battery is clearly discharging so must be working This was my 3rd successive test run (more on this later) max/min module voltage gap was < 0.1V at start and < 0.2v at the end total discharge time 4 1/2 min Interesting Info I did 3 tests. First test has higher SOC (wife just came home and charge bar on center info panel was like 2-3 from full). Between each test I let the engine run to charge battery until it stopped (about middle of the SOC bar on center info panel) Each cycle, the min/max voltage gap during discharge got smaller and start to end SOC drop also seemed smaller. Above graph was on the 3rd run. Center of the pack modules exhibits more wear than the outer edges. Same as everyone's observation and obviously due to less cooling in center. The pattern is as follows At low SOC, center modules voltage is lower than outer. A classic inverted bell curve as someone said. When discharging, center module voltage drop faster than the outer When charging, center module seems to rise faster than the outer Next Step Generally speaking, I guess nothing and probably another 50-100k miles more service life. However, if I rotate the inner modules to outer and outer to inward. Perhaps can increase longevity as the current weaker inner weaker modules would be living much cooler. Its a lot of work but maybe push first module failure out 50k miles? No one really knows of course.
hard to say, peoples experiences are all over the place. one common factor is, they like to be used. that's because the car is balancing the modules. when they sit too much, they cells slowly drain, reducing lifespan. at 150k, you're in good company
Yes indeed, I see a lot of "bought another car, Prius sat idle for awhile and now HV is dead" When I did my 3 test cycles, voltage gap between min/max module got progressively smaller. First test was after car sat 1+ hour since last drive cycle and I would see gaps of 0.3V. Next subsequent cycles got a lot tighter towards 0.1V. Obviously, the inner module voltage gap to the outers became less. Besides getting cycled, I'm wondering if temperature might be a contributor as well. First test on a car that sat say an hour after last drive probably have bigger temp differential between outer and inner modules. Load cycling a couple of times probably gets them to more consistent temps. I also checked the module voltages when the car sat for a whole day with SOC of 2-3 bars. I saw like 0.3V difference btw middle and outer modules. If the battery just sat, middle modules might sag even more eventually trigger HV fault. Anyway, as you say, keep using the car so battery charges and balance at the top (charged cells bleed heat while the rest catches up)
5 months has gone by and seem to notice more signs of what I think is capacity degradation. Basically compared to when it was new Can't drive as long with engine off On long downhills and regen, engine comes on sooner to bleed off excess charge. Here is the Techstream graph of a short drive from my community gate entrance to home. google maps says 0.5 miles. Several slow to near stop / actual stops. Red arrows pointing upwards are where the stops and near stops are Yellow and Red line are the min/max block voltages. Imbalance is highest at higher SOC (blue). As SOC reduce, imbalance reduces as well. Each time as vehicle speed (brown) reduce to come to a stop. Block voltages (red, yellow) rise with regen charging Eventually SOC (blue) gets too low and engine kicks on (green) Seems everything make sense. It's a 150k mile small capacity battery heavily cycled (Toyota seems to like to keep it between ~40 to ~70 SOC) in a relatively mild temperature climate (Seattle) and car used quite often with short trips. Here is the individual graph. Need more vertical space to see clearly. Techstream seems to only allow all overlap or all split.
