Just need to vent...
Discussion in 'Fred's House of Pancakes' started by Mendel Leisk, Jul 6, 2022.
  1. Mendel Leisk
    41,834
    For most caps yes. But have you encountered poorly manufactured ones, that are essentially defective, require vices and power tools?
  2. fuzzy1
    10,597
    Not yet. Though my older spouse (who is still recovering from a broken dominant wrist) has run into the strength problem.
  3. ChapmanF
    18,473
    Has anyone vented about "with au jus" yet?
  4. Mendel Leisk
    41,834
    With, with juice? Sounds good, double-tap adjective.
  5. hill
    8,899
    What, there's something about a French dip that's worth venting about?
  6. Stevewoods
    Stevewoods Senior Member
    663
    1,194
    Seattle, WA
    Apparently even the prez had troubles with those safety caps. Bob Woodward said Richard Nixon asked presidential aide Stephen Bull to open a pill bottle for him. Bull noticed the container had teeth marks where Nixon had apparently tried to chew his way into the container.
    Funny thing is Nixon signed the bill in 1970 that ordered the use of child-proof containers.
    IIRC, Nixon would have been around 60 at the time of the alleged incident as he was born in 1913.
    #3306 Stevewoods, Feb 26, 2026 at 4:49 PM
  7. cyberpriusII
    1,157
    1,827
    Hyampom
    It's a bit strange on the childproof caps.
    I would expect there to be some sort of general standard? I have some very "dangerous" items and the special caps could be defeated by an infant (poetic license). While some marginally somewhat minor danger compounds arrive in a package that requires massive brain and brawn.
    kris
    #3307 cyberpriusII, Feb 28, 2026 at 1:12 PM
  8. ETC(SS)
    7,326
    Adult-proof packaging......
    futurist and Isaac Zachary like this.
  9. Isaac Zachary
    Isaac Zachary Senior Member
    2,664
    1,372
    I need that on any junk food the wife brings home, because she doesn't eat any of it.
    ETC(SS) likes this.
  10. ETC(SS)
    7,326
  11. Trollbait
    12,657
    Pharmacy switched to caps that can be flipped for non-child proof use. Thing is the anti-tamper mechanism means there is a lip on the cap that can be uncomfortable to grip when flipped.
    Your pharmacy might have straight, non-anti-tamper caps available if you ask.
  12. fuzzy1
    10,597
    My understanding is that they are required to provide a non-CRC (non child resistant container) when requested.
  13. bwilson4web
    16,336
    Channel locks!
    “childproof caps”
  14. Mendel Leisk
    41,834
    Channel locks alone won’t cut it; you need simultaneous compression between the underside of child-proof cap and top of bottle, to hopefully mesh the internal teeth, paramount to achieve counterclockwise rotation of the actual cap. Coupling channel-locks (or self-locking pliers to dismiss the need for three hands) with a vice or hydraulic press, success (aka bottle opening), may be achieved. Or the bottle walls may collapse, split open, and there you go, contents exposed and able to be pried out through the gaps.
    alternately: mount bottle upside down on lath style mechanism, bring cutter to bear to remove bottle bottom, pour contents into regular jar, spent jam or mustard jar for example, seems feasible.
    oh we’ll get there. :)
    #3314 Mendel Leisk, Mar 1, 2026 at 7:26 AM
  15. bwilson4web
    16,336
    Oh boy, a good excuse for a CNC lath!
  16. futurist
    futurist Member
    55
    101
    United States
    2024 Prius
    Or, just find out what the thread pitch is, and 3D-print a cap. Need to get the old bottle cap off, but it'll be the last time you need to go through that. Doesn't need to conform to whatever regs the original did, if it's just you in the house using it.
    Any children however... maybe do need that lathe to fab up a manual adult-proof-cap opener that adapts to a bunch of container designs :p
  17. ChapmanF
    18,473
    Having bought a set of tires last week, I now see a news feed overrun with tire ads.
    Holding out for the day there's enough AI in the ad placement algorithm to figure out somebody who just bought a set of tires maybe isn't the hottest prospect for a bunch more tire ads just now.
    3PriusMike likes this.
  18. Mendel Leisk
    41,834
    I got a wall-mount exhaust fan through a local automotive/hardware place a few months back, and my reddit feed regularly includes a post from the place, with a pic of the fan (or alternate sizes) with the admonishment "that project is not going to finish itself", and perhaps I should visit them for additional tools. Project's done btw.
  19. Mendel Leisk
    41,834
    I bought a fan through Princess Auto a month or two back, my Reddit feed of late:
  20. ChapmanF
    18,473
    The weirdest thing is why they think I'd be wanting to buy tires right after I just bought tires.
    Maybe I'm not giving the AI enough credit. Maybe it's so smart it knows I bought Vredesteins and they have a 100-day free return policy, and now it's trying to change my mind about them.
