Who still has the 'Original Hybrid Battery' on their Gen. 2
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Oct 26, 2024.
  1. Chodronish
    Chodronish Member
    171
    40
    Illinois
    Four Touring
    My 2008 with about 153K miles is still on the original traction battery. Gen 2 is so reliable that I am afraid to get anything else!
  2. Simbaboy
    Simbaboy Active Member
    134
    112
    Mid-Michigan
    2009 Prius, Michigan weather all its life.
    300,000 Miles. Original hybrid battery. 3rd 12 Volt batter.
    Ebay AC a few years ago.
    Tires, wipers are the only expenses. Best car ever and I have many.
    Simba
  3. ski.dive
    ski.dive Active Member
    967
    246
    Hutchinson Island,FL. Mt. Snow,VT
    My 2008 Prius which I purchased NEW, still has the original hybrid battery- It has 146K miles
    xw20_driver likes this.
  4. 4thesporty
    4thesporty New Member
    Fort Worth
    A month ago I bought a clean one owner 2007, always serviced at a dealership (with all records) with a clean bill of health.
    Last week I had to replace the original battery in it with a new one bought from the dealership, so 19 years and ~209K miles. However, judging from the records, looking at dates and mileage readings, this car was not driven much the last few years which probably contributed to the battery issue. Hope to get a long life of commuting out of this car now.
  5. xw20_driver
    xw20_driver Member
    118
    58
    PNW
    2007 Prius Touring currently 207K and purchased 13 months ago with 195K. Previous owner(s) had installed a now defunct Nexcell Project Lithium Jack's special highly touted lithium pack at some point. Not long after I purchased it I got a red triangle of death with a failing battery. I ended up buying a new OEM Panasonic pack from Toyota and installed it myself. Currently getting around low 40 mpg.
  6. Brian1954
    Brian1954 Senior Member
    2,542
    1,008
    South Central PA, USA
    You created a similar thread 1 and 1/2 years ago.https://priuschat.com/index.php?posts/3489307
    Let's see who responds to this new thread.
  7. bisco
    52,649
  8. Tideland Prius
    16,643
    *Threads merged*
  9. rogerthat
    rogerthat Active Member
    411
    128
    Georgia
    You mention "low 40 mpg".. what is your average as you should be hitting well above 45pmg with a new battery? It has been cold in PA, so maybe that could be a major issue for mpg.
  10. Eunice Aikman
    Eunice Aikman Junior Member
    Palm Springs
    168K on my 2008 and am seeing some weird signs so not sure if it’s starting to go. Hybrid charge decreases over night but does go back up into the green when driving. Anything else I should be looking for?
  11. xw20_driver
    xw20_driver Member
    118
    58
    PNW
    I was seeing around 45mpg range last summer and fall. Winter mpg pretty dismal in the low 40s range. We are probably 80% suburb non-freeway driving with lots of hills and elevation changes. Winter temperature had been on average upper 30s to upper 40s this winter.
    #31 xw20_driver, Mar 7, 2026
  12. rogerthat
    411
    128
    Georgia
    What's your average mpg?
  13. bisco
    52,649
    I think you’re right, and Palm Springs will be hard on the battery.
    That being said, you can drive it until it sets a code, or replace it proactively
  14. iamgroot
    iamgroot New Member
    I just purchased a 2009 prius 170k miles with original hybrid battery. Dr. Prius says it has 48% life left but i am getting around 48-51mpg in city driving. I did all the necessary maintenance which previous owner didn't do like spark plugs, pcv valve, throttle body and intake manifold cleaning, maf, air filters, hybrid fan cleaning. After doing all of these my mpg improved a bit.
    And for the hybrid battery when i checked with techstream i could see all modules voltages are mostly uniform under 0.2v delta. I am curious if i could recondition this battery as i am on a budget. And i am new to this forum and i am not sure where to post for help. Is it possible to rent a grid charger/discharging kit in florida? Any help is appreciated.
  15. Zeppo Shanski
    Zeppo Shanski Active Member
    305
    172
    Chicagoland
    I drive an '05-G2. I swapped mine out summer-time last year. It was somewhere in the 195-thousand lap zone.
  16. SilentKiller
    SilentKiller New Member
    St Cloud, Fl
    Well I just recently acquired my 2008 Gen 2, it has 167K miles. As part of my initial refresh, I went completely through it, giving it a thorough tune up and cleaning. It's history showed that for the last few years it was bounced around the auction scene, the car fax showed no entries for any type of battery servicing.
    It seems to be a solid car that has spent its life in Florida. Aside from correcting all the cosmetic rigs from the shade tree mechanics I do believe out of fear and general lack of knowledge no one has attempted to touch the original battery pack. it is not working optimally, but I will know more once I learn to use the Dr Prius app and determine its battery health. In the meantime I am hoping that driving it every day will help begin to shake out any more skeletons, but I fear that a battery replacement is in my future.
  17. priuslyfe
    priuslyfe Member
    320
    70
    yes same battery. 350K miles and counting.
  18. Blueness
    Blueness New Member
    Farmington, NM
    2018 Prius Prime
    Is there a way to look up the battery info via OBD2?
  19. FALC0N
    FALC0N New Member
    I replaced mine about a year ago. It lasted 17 years and 372,000 miles.
  20. PrimalPrius
    PrimalPrius Member
    138
    America
    Never a light bulb, bearing hub, tie rod end, ball joint, strut, belt, plugs, coil, air filter, transmission fluid, brake pads, rotors, shoes, drums? Nothing?
    (Oil and filters surely).
