Sensors Stop Working When Driving While Snowing
Discussion in 'Gen 5 Prius Main Forum' started by VelvetFoot, Mar 3, 2026 at 7:17 PM.
  1. VelvetFoot
    VelvetFoot Active Member
    1,153
    454
    New York State
    2026 Prius
    That wouldn't be so bad, but you can't minimize the nag screen which takes up half the cluster. There are lights too, that light up, so I can't see why it shouldn't be an option. I like that screen. :)
    I wonder if there is a parameter somewhere that can be set, or a secret button sequence..... :)
  2. VelvetFoot
    1,153
    454
    New York State
    2026 Prius
    And, in another snow-related matter, you can see what the visibility out the rear window is like, by size of the heating grid. Not too huge, lol.
    And I believe the Michelin X-Ices did give some additional traction, even after the plows slushed things up with the salt. I live on a town road on a hill, ie, not so quick on the plow/salt/dirt, so they were good for sure there.
  3. PriusCamper
    PriusCamper Senior Member
    12,992
    5,284
    Pacific Northwest, USA
    Maybe you can resolve some of these problems if there's settings in Toyota Techstream?
  4. VelvetFoot
    1,153
    454
    New York State
    2026 Prius
    That would be excellent.
  5. Prodigyplace
    12,638
    11,814
    Central Virginia
    You can't acknowledge the nag screen? That is what happens on my 2025 Camry.
    VelvetFoot likes this.
  6. VelvetFoot
    1,153
    454
    New York State
    2026 Prius
    Mine comes right back after acknowledging. Yours doesn't?
    edit: If you don't have a feature that doesn't require it, it might come back. I couldn't get that to work with the front radar though. (These sensors were covered with snow)
  7. Winston Smith
    Winston Smith Active Member
    389
    264
    OH
    2024 Prius
    LE AWD-e
    I can back out of mine, but the warning returns shortly.
    Even worse, the adaptive quality of the cruise control quits well ahead of the warning.
    Prodigyplace and VelvetFoot like this.
  8. KMO
    KMO Senior Member
    2,005
    730
    Finland
    2023 Prius Prime
    Almost no warning can be dismissed - they pop back up after 10 seconds. That includes basically all TSS problems, as well other "xxx failure, visit your dealer" messages.
    The only things that can be dismissed are stuff like "fuel low" or "service due".
  9. VelvetFoot
    1,153
    454
    New York State
    2026 Prius
    I wouldn't even want to use that sensor stuff while it's snowing. I just like the screen and use it a lot.
    Prodigyplace likes this.
  10. Prodigyplace
    12,638
    11,814
    Central Virginia
    I do not recall mine coming back but I have not driven with the front radar snow covered. I have most every safety feature on my XLE, but no dashcam.
  11. Prodigyplace
    12,638
    11,814
    Central Virginia
    My 2017 Prius used to warn NOT to use it in bad weather.
  12. Mendel Leisk
    41,833
