OEM 42450-47040 2010-15 HUB & BEARING ASSY, REAR AXLE, RH or LH
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gatorback, Mar 3, 2026 at 8:50 PM.
  1. gatorback
    gatorback Junior Member
    57
    My passengers are indicating that there is a noise, which indicates the right rear bearing assembly needs to be replaced.
    1) What is the decision process / inputs to decide between OEM ($180- $440) vs aftermarket ($60 eBay/ AMZN)?
    2) If buying OEM through eBay, what is the litmus test to verify it is truly OEM?
    42450-47040 TOYOTA GENUINE PRUIS 2010-15 HUB & BEARING ASSY, REAR AXLE, RH or LH | eBay
    3) If buying online from a Toyota parts center, the incremental cost is approximately $100 over eBay.
    If you have replaced said assembly, what was your experience? Please indicate if you bought OEM, where you bought it from and the cost. If you were faced with the decision again, would you do it differently?
  2. CR94
    CR94 Senior Member
    2,740
    1,198
    Northwestern S.C.
    Would you trust parts from a supplier who can't spell PRIUS correctly?
    Brian1954 and StarCaller like this.
  3. Tombukt2
    13,336
    2,401
    you would think not I've learned better . My own spelling n shiet. They did not spell Prius theys home did .over 40 beRo vs installed all hep stuff except back in the 80 90 wen I could buy Toyoda as cheap as I buy trq etc long time ago employed by Toyoda I paid nothing just the way it used to be . The last twenty installed brands you can ot spell so Viola. I've received no failure calls about any bearings hubs so far .so I keep using shiet I cannot spell. No matter antique status in a few years he he he.
  4. ASRDogman
    ASRDogman Senior Member
    7,788
    3,975
    Stay away from trq! They are crap!
    Timken or Moog(made in America) are good.
