What would cause this brake pad wear, and any guesses about some unusual symptoms?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MrPete, Mar 2, 2026 at 10:47 PM.
  1. MrPete
    MrPete Active Member
    506
    191
    Colorado, USA
    I'm doing a complete 4 wheel rotors+pads replacement on our 2011+ 250k mile prius.
    Rear wheels now complete (rotors were at 7.8mm.)
    Physical evidence of issues:
    * Right rear outside pad has worn flat on the upper (close to rotor edge) side, several mm of differential wear (See photo.)
    * All four rear caliper slider pins had sludgy black grease. They moved but not easily. (Redoing with the official Toyota grease made a night and day difference!)
    * Rotating wheels definitely made a small scraping sound: pads in contact at least lightly.
    In the last month, I noticed:
    * Occasional small vibration while braking
    * The car was outside overnight in very cold weather (0-10F). In the morning, it did NOT want to roll for the first 5+ minutes until warmed up. Scary to me.
    My questions:
    * What could cause the differential pad wear? Could it be the sludgy slider pin grease?
    * Could the grease also have caused the roll resistance, perhaps brakes still acting even though parking brake released?
    Thanks for your insights!
  2. VelvetFoot
    VelvetFoot Active Member
    1,153
    454
    New York State
    2026 Prius
    What does that mean? The engine warmed up? You're not warming up the brakes, unless you're driving with, say, the parking brake dragging-on one or the other wheel perhaps. That'd cause some wear, lol.
    I'm thinking something's going on with the parking brake. No evidence of dragging, eg, mpgs went down suddenly?
    Is the parking brake action smooth, from the hand lever to the brakes?
    Parking brakes freeze up some times, literally, if they get wet during the day and freeze overnight.
    Not a Gen 3 owner. I've owned some cars, but I'm not a mechanic.
  3. Mendel Leisk
    41,834
    With the back wheels off the ground, if you give them a decent push, will they free-spin at least couple of turns? See rear brake drag link in my signature.
    (on a phone turn it landscape to see signatures)
  4. ChapmanF
    18,473
    I don't clearly see in your pad photo what you are trying to show.
    Could it be like what's going on in ➡this post⬅?
    I also found it quite challenging to photograph the pads in a way that showed what I meant.
  5. MrPete
    506
    191
    Colorado, USA
    Sure is hard to photograph!
    So:
    * notice the pad in back has a slot still, edge to edge. Pad is about 5mm thick, Slot 2mm.
    Now the pad in front :
    * the far edge has the slot. That goes on the inner diameter of the rotor ("down" side when placing the pads) Pad ~5 1/2 mm thick
    * but the near edge has no more slot. 2mm thick pad.
    So,that pad (on the outside/wheel side of the rotor), is worn at an angle?!
    As for the parking brake: I made no adjustments and it doesn't stick. (did not remove or reattach to do the brake job.)
    So far the only major change is properly lubing the pins.
  6. ChapmanF
    18,473
    Ah, so not stepped wear as in my photo, but a flat wear face that is angled with respect to the back of the pad?
    Is that "pad in front" the one in contact with the caliper piston?
    There are features provided (a pin on the back of the pad, and notches in the face of the piston) to prevent the piston from turning as it extends (because a threaded post, internal to the caliper, is a key part of how the parking brake works).
    If the piston didn't stay properly aligned (notch to pad pin) when the brake was last assembled, the pad can end up at an angle because its pin is out of the piston notch, and that angled pad wear is the result.
    Mendel will have more info.
  7. MrPete
    506
    191
    Colorado, USA
    Correct about the wear. No, this is not the piston side.
  8. Mendel Leisk
    41,834
  9. MrPete
    506
    191
    Colorado, USA
    Can't be the piston. One thought going back a few years... I drove a few thousand miles with the out of alignment rear axle. It was bad enough that I wore out a tire VERY quickly. Perhaps it also wore the brake pad and I didn't notice. :(
    I'll be watching the new brakes carefully, and check everything after a few months...
  10. ChapmanF
    18,473
    Very hard for me to picture an alignment problem causing that, as the caliper bracket is mounted to the same flange the hub is. Almost gotta think there was something foreign caught between the outboard pad and the bracket. Or the misalignment involved someone replacing the hub, and getting something foreign beneath its flange? Or when mounting the caliper bracket?
    Still, I think something under the hub flange or bracket would have led to angled wear of both pads. Just one pad still makes me think something was between that pad and the bracket.
  11. mjoo
    mjoo Senior Member
    1,163
    1,333
    Michigan
    You can add too much grease to the caliper pins (thinking that more lube is better) and it'll cause the brakes to drag.
    MrPete and Brian1954 like this.
  12. ChapmanF
    18,473
    It won't slant the pads, though.
    MrPete likes this.
  13. MrPete
    506
    191
    Colorado, USA
    Back to the slow car weirdness.
    Good Questions, @VelvetFoot
    I may not be able to further diagnose w/o another cold snap, and have changed the parameters with new brakes. In any case:
    • Not just engine warmup, at least that wasn't my impression. I could easily test that with the Hybrid Assistant app.
    • Parking brake isn't normally an issue. No (normal weather) MPG drops.
    Now with front brakes also complete, and two more VERY sludgy pins, and all pins having been at least kinda sludgy, my sense is:
    • Sludge-slow pins is the likely primary issue.
    • Using the correct Toyota grease for the pins is crucial for our weather/environment extremes.
    • I need to check the pins regularly until I see a reasonable interval.
    QUESTIONS:
    • How often do others service their caliper pins? It is not all that difficult if you have the right tools.
    • Have others serviced front and back pistons? I *never* have pulled one apart. Supposedly there are reasonably priced parts kits.
  14. MrPete
    506
    191
    Colorado, USA
    The worst (right rear) wheel still spun, so that says something.
    I don't think I have a solid answer to the pad wear pattern...
    As has been noted, most issues will not affect only a single pad.
  15. ColoradoBoo
    ColoradoBoo Senior Member
    1,266
    873
    Monument, Colorado USA
    A bad wheel bearing can effect the brakes....have you checked the play with the tires off the ground? (Grab the tire at 12 and 6 and check for movement and do the same at 9 and 3.)
  16. ChapmanF
    18,473
    I inspect my brakes every time I rotate tires. In doing that, I take the pads out, measure them, measure the rotors, and slide the caliper side-to-side on the pins. They usually feel a bit resistant/peanut-buttery at first, because the caliper motions in normal use are so small and the grease kind of sets that way. Four or five push-pulls on the caliper wakes the grease back up, and as long as the motion feels smooth and greasy then, that's the end of anything I do with the pins.
    I inspect the rubber boots. If a boot is damaged so it can let salt water in, I'll take that pin out, clean and regrease, and reinstall with a new boot. Haven't had any such need yet on my 2010.
    If I saw damage to the piston rubber dust seal, I would rebuild the caliper.
    If I observed warmth in my 15-minute brake drag test, I'd investigate why, and rebuild the caliper if that's the issue (say, the piston is either binding, or lacking proper return).
    Absent any reason to go into the caliper, I leave it be.
    The slide pins are far from the only, or even most common, things that can bind up the brakes. The fitting kit (small springy clips that hold the pad ears in the bracket) is what I most often find needing replacement, and that's when I find anything needing replacement at all. First the factory dry Teflon-like coating wears off, then they start to rust.
    My most common inspection outcome is I put my freshly measured and inspected parts back together and call it a day.
    Tire rotation happens often enough that even if I notice an incipient problem, I might have caught it early enough to just put everything back together anyway, with "note to self: buy fitting kit for next time" or whatever.
    MrPete likes this.
