Noise coming from under the hood intermittently
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jotowers, Mar 4, 2026 at 10:22 AM.
  1. Jotowers
    Jotowers New Member
    Monday
    Fresno CA
    2009 w/ 222k miles
    What is this sound? I only hear it occasionally. It comes from the driver's side. It happens while driving and while in park. It will stop once I shut the car off
    52,307
    What sound?
    Maybe a pump
  3. ChapmanF
    18,473
    There are several sounds that can fit that description. If you can post a recording, that helps, or you can search for other similar threads where other people posted recordings, and notice which of those sound like yours.
  4. Prodigyplace
    12,640
    11,815
    Central Virginia
    The gasoline engine? LOL
    Jotowers likes this.
  5. PriusCamper
    PriusCamper Senior Member
    12,997
    5,284
    Pacific Northwest, USA
    What is the sound that OP is not going to describe? Lol... I think its a trick question!
    If a car makes a sound and the person who is hearing the sound doesn't describe what the sound actually sounds like to people on PriusChat, does the car really make a sound?
  6. ChapmanF
    18,473
    Well, the OP described when it happens, which I guess is the easier part to put in words, without trying to do the "well, it's kind of screechy, with a little bit of whong-ong-ong-ong, only not as buzzy as that" kind of thing.
    If there were only one gen 2 Prius sound that could happen at the times described, that might be enough to ID it.
    Trouble is, there's more than one. So posting a recording is more helpful, or listening to the recordings from other people's older threads to pick out which one it sounds like.
  7. PriusCamper
    12,997
    5,284
    Now this is what I'm looking for... Lol... Not like it helps that much, but is always kind of fun. Way better than when they post a video and you can't hear it at all.
