inverter coolant bleed
Discussion in 'Generation 1 Prius Discussion' started by ronlewis, Mar 4, 2026.
  1. ronlewis
    ronlewis Active Member
    1,061
    206
    texas
    2001 Prius
    OK, what am I doing wrong? swapped a brake actuator into this car, which required removing the inverter, coolant lines, and a water pump below it. Lost a good bit of coolant in the process, maybe a beer can's worth, no more than two. Now, I got it back together, filled the reservoir, and coolant is not circulating in the reservoir, but I hear the pump running and squishy sounds.
    Got two clear hose stuck on each bleeder screw looped over to the reservoir. When I loosen the bleeder screws nothing much happens. The right side has pushed coolant about halfway to the reservoir, then stopped. Nothing has come out of the left bleeder screw.
    I've turned the key to ACC and let the pump run for a minute, bleeders shut. Turn the key off, open the bleeders and nothing. Did the same and left the key on, nothing. Ran the engine for several minutes, turn it off and open bleeders, nothing. Actually ran the engine with bleeders open, nothing.
    I'm guessing the system is air locked. How do I "jump start" it so that coolant circulates enough to expel air bubbles.
    One note, when I loosen the right side bleeder, a little coolant leaks from around the threads. Is that where I'm losing my air?
    Also, coolant level has dropped a few times, and I've topped it up, probably about a beer can full.
  2. ChapmanF
    19,052
    The extra fun part about bleeding the inverter loop in gen 1 is that the two bleeders connect on different sides of the pump. The one closest to the fender connects near the discharge (pressure) side of the pump, so you can go ahead and open it while the pump runs, and stuff will come out.
    The one closest to the middle of the car connects near the inlet (suction) side of the pump, and if you open that bleeder up while the pump is on (without making careful arrangements), you let stuff in. If the stuff you let in is air, your bleeding job becomes eternal.
    If you follow the steps in the repair manual, Toyota wanted you to turn the car on, running the pump, turn it off, stopping the pump, open the bleeder, close the bleeder, repeat. It's tedious as all get-out.
    It turns out the suction the pump produces is about −10 inches of water (relative to the open reservoir), and that bleeder is more than ten inches above the ground, so if you want a less-tedious way to bleed the loop, you can do it ➡this way⬅. That link also talks about the leaks-around-the-threads issue.
    ammdb likes this.
  3. ronlewis
    1,061
    206
    texas
    2001 Prius
    OK! Let me try again. Thx.
  4. ronlewis
    1,061
    206
    texas
    2001 Prius
    LOL, I'm being ignorant again. I still wasn't seeing any movement, so I was trying to siphon air out of that left bleeder. I got an empty liter bottle, poked a hole in the cap big enough for my hose, and filled it half way with coolant. With the other end on the closed bleeder, I turned it upside down to fill the hose with coolant. Set it on the ground and opened the bleeder, and sure enough, it starts sucking bubbles out of the bleeder. I've done that over and over, probably 20 times.
    On the pressure side, I'd let the pump run for a minute, then open the bleeder, and nothing. Tried a few times, never saw any significant amount of coolant in the hose, and no bubbles. Left the pump running, same thing. So, I started sucking on the hose, like I siphoning that side as well, and I'd get lots of bubbles. Did that 20x or so as well. Going back and forth between the bleeders, and keeping the reservoir full.
    Never did get the reservoir to circulate though, and I'm not sure if I wasn't just sucking air from the leaky threads on the pressure bleeder - didn't have anything to seal it with. A couple of times and got that bleeder hose to fill up and actually pump coolant out without me sucking, and the bubbles stopped. And the passenger hose quit showing lots of bubbles, but it never did just flow on its own.
    Anyway, it got dark so I quit for the night. Not sure if I'm making progress or not. Need to get some sealer for those threads - will plumber's tape work? That liter bottle seals up nicely - doesn't leak when I hold up upside down to drain coolant into the hose. Wonder if it needs to have a vent hole to siphon properly. Seems to work the way I'm doing it. Bubbles definitely coming out of the bleeder. Just seems like I would have gotten all the air out by now. I can't drive it right now - I got a rear axle hub off and the new one doesn't come in until Monday. I've started the engine and let it run a while, but that doesn't seem to do anything. On the pressure side, does the end of the hose need to be submerged in coolant?
    Definitely got the taste of coolant in my mouth, but haven't swallowed any.
  5. ChapmanF
    19,052
    That'll keep you from succeeding. Is there a store nearby where you can get some?
    Be careful. Ethylene glycol is no good for a person.
    This surprises me—you mean you've never seen any sign of movement in the reservoir. That should happen even while you're at work on bleeding. It's not like "ahehehehe, I'll never pump fluid at all till the last bubble's out!"
    There have been some threads where people end up finding a clog in the system. In one of them, I remember, it was a bolt inside one of the hoses (now how on earth did that get there?).
  6. ronlewis
    1,061
    206
    texas
    2001 Prius
    LOL, yep, I was pretty careful not to swallow any.
    So plumber's tape won't work? I've got a Home Depot near by.
    Other than the reservoir getting lower, I've not seen it circulate. No bolts.
  7. ChapmanF
    19,052
    Never tried it for this application. They might also have a glycol-resistant non-hardening sealant if you ask them. Or if there is an Autozone or the like near the Home Depot, they might.
  8. ronlewis
    1,061
    206
    texas
    2001 Prius
    Probably not, but does it matter that the back of the car is jacked up? Left it on jack stands waiting for the axle hub to arrive.
  9. ronlewis
    1,061
    206
    texas
    2001 Prius
    Very frustrating. Both bleeders shut, let the pump run for 10 minutes, turn it off and open the pressure side, it pushes coolant out a couple of inches and stops. No bubbles. Repeat the process, maybe another half inch out, then nothing. Ditto on the suction side.
    I pulled the pressure bleeder out to coat with Permatex blue thread sealant. Coolant comes out of the open pressure side. So, I put it back together, close the bleeder, run the pump several minutes, turn off, open the bleeder, again nothing. Repeat, but this time, after turning off the pump, I take the bleeder off, and fluid comes out of the pressure side, a lot, drains the reservoir.
    I guess that the bleeder screw is clogged, although I can blow through it, and when I put it back on, I can suck lots bubbles out of the pressure side. So, I swap it with a screw from another car. No difference.
    Finally, with the pressure fitting out, I turn on the pump, and coolant comes out strong.
    Why doesn't it pump coolant out with the bleeder installed? This is crazy. Never have seen the reservoir circulate, just drain. I listened to one of my other cars and can't even hear the pump (I don't hear well), but it circulates great. The project car's pump is loud, squishy sounds, and was working fine before I started this job, but no circulation. I'm going to take it to a Toyota tech. The dealer won't work on cars that have a salvage title, which this one does.
  10. ronlewis
    1,061
    206
    texas
    2001 Prius
    Well, guys, don't know what I did, but I fixed everything.
    So, I had given up on bleeding the inverter coolant. That was needed because I'd removed the inverter and the water pump below it to remove the brake actuator. Lost a good bit of coolant in the process. Tried to bleed as described above and never saw the reservoir circulate.
    I knew I needed to also bleed the brakes for the replacement actuator and figured I'd mess with that instead, and if it didn't work, take it to a shop to do both. So, I watched some YouTubes and cleared the original ABS codes using a paperclip in the OBDII. The YTs were on Gen2s, but I figured they'd be the same, but no. The YT said I'd hear the booster pump turn on just by opening the door. And without turning the key on, I could depress the brake pedal then loosen the bleed screws on each wheel a few times until I saw clean fluid.
    The pump didn't turn on when I opened the door, or when I turned the key on. But I pumped the pedal a few times to clear the codes. They went away. Then, started over - took the tire off and broke the bleeder screw loose. Put a clear hose over the screw, then pumped the brakes a bunch. I could see fluid come out the hose, but there was still an inch of bubble in the hose right at the screw. Turned the key on, pumped again, same thing. Did that a couple three times, at one point I recall the pump turning on, but always ended with the inch long bubble by the bleeder screw, and never saw clear fluid.
    I quit at that point. Never did anything to the other wheels. Did fill up the brake and coolant reservoirs. Gave up for the night.
    Today, I drove to a foreign car repair shop I've used for little jobs before. Guy wasn't real clear on what he needed to do, but said he'd done others before and would figure it out at $190/hr. But not until Friday. I went to the dealership - nice service lady I'd dealt with before had told me in the past that they aren't allowed to work on salvage title cars, but I wanted to know what the book rate was for bleeding the ABS before taking it to that shop. She said $280. And she checked with her boss and they would let their shop do that low-risk job.
    I went home to get the car to drive it up there. Start it up and get the orange triangle and CEL. Hadn't been seeing those at all before. And when I drove, it had major hesitation and loss of power. I'm now pretty sure the power issue was due to a rear brake shoe being stuck - I had also changed a rear axle hub and rolled the adjustment gear to get the drum back on - think I rolled it the wrong way. After driving around the block and hitting the brakes hard a few times, all that cleared up.
    But so did the brakes. They work fine now. I've driven it several miles hitting the brakes hard and they feel great. No alerts on the dash.
    And, the coolant reservoir is circulating too!!! The car runs great in every way - except now the Door Ajar light is on. It's one of the passenger doors I replaced after the wreck. I can open the door and push the button and it turns off, but it comes on with the door closed. Door seems to work fine and lined up fine.
    So anyway, I'm going to fix that now. Just amazed that my brakes and inverter coolant seem good. I haven't gotten the ABS to actually activate though - need to find some gravel or wet pavement - but before the brakes would work with the ABS lights on, but were kind of mushy. Now, the pedal feels great and it stops on a dime.
    Guess this isn't a great thread for anyone trying to fix their brakes or coolant to review, who knows why they started working, but that's OK with me.
    #10 ronlewis, Mar 9, 2026
