Noise coming from under the hood intermittently
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jotowers, Mar 4, 2026 at 10:22 AM.
  1. Jotowers
    Jotowers New Member
    Monday
    Fresno CA
    2009 w/ 222k miles
    What is this sound? I only hear it occasionally. It comes from the driver's side. It happens while driving and while in park. It will stop once I shut the car off
    52,309
    What sound?
    Maybe a pump
  3. ChapmanF
    18,475
    There are several sounds that can fit that description. If you can post a recording, that helps, or you can search for other similar threads where other people posted recordings, and notice which of those sound like yours.
  4. Prodigyplace
    12,643
    11,818
    Central Virginia
    The gasoline engine? LOL
    Jotowers likes this.
  5. PriusCamper
    PriusCamper Senior Member
    13,000
    5,285
    Pacific Northwest, USA
    What is the sound that OP is not going to describe? Lol... I think its a trick question!
    If a car makes a sound and the person who is hearing the sound doesn't describe what the sound actually sounds like to people on PriusChat, does the car really make a sound?
  6. ChapmanF
    18,475
    Well, the OP described when it happens, which I guess is the easier part to put in words, without trying to do the "well, it's kind of screechy, with a little bit of whong-ong-ong-ong, only not as buzzy as that" kind of thing.
    If there were only one gen 2 Prius sound that could happen at the times described, that might be enough to ID it.
    Trouble is, there's more than one. So posting a recording is more helpful, or listening to the recordings from other people's older threads to pick out which one it sounds like.
  7. PriusCamper
    13,000
    5,285
    Now this is what I'm looking for... Lol... Not like it helps that much, but is always kind of fun. Way better than when they post a video and you can't hear it at all.
  8. Jotowers
    Jotowers New Member
    Monday
    Fresno CA
    Lol I'm a new member so it won't let me post a link and I can't figure out how to add the video I have
    PriusCamper likes this.
  9. Jotowers
    Jotowers New Member
    Monday
    Fresno CA
    I'm trying to contribute to be able to gain access to add links
  10. dolj
    dolj Senior Member
    8,536
    4,336
    Wellington, New Zealand
    I suspect the OP (Jotowers) intended to post a link to his video, but then, because he is a new user with less than 5 posts, found he couldn't.
    So, OP, make 5 comments on some other threads, then come back and post your link.
    Also note, that with less than 5 posts, each of your new post have to wait for a moderator to approve them. Another reason to get you post count up to over 5.
    Prodigyplace and Brian1954 like this.
  11. JC91006
    JC91006 Senior Member
    16,817
    8,597
    If there is a continuous sound coming from the driver's side, I would have to guess it's a bad 3 way valve. This sound would be described by many as a stuck cd trying to eject over and over and over.
  12. dolj
    dolj Senior Member
    8,536
    4,336
    ... or, if you're old enough, like a broken floppy disk drive unable to find the track it is seeking.
    Prodigyplace likes this.
  13. Jotowers
    Jotowers New Member
    Monday
    Fresno CA
    Yes that's exactly what it sounds like! It only comes on occasionally and no check engine light yet. Is this something I need to address immediately?
  14. Jotowers
    Jotowers New Member
    Monday
    Fresno CA
    I want to post my link but it say I need to post 3 more times not just comment on others posts
  15. Jotowers
    Jotowers New Member
    Monday
    Fresno CA
    https:// photos.app.goo.gl/wP5ygnkTNNoUmGWe7
  16. PriusCamper
    13,000
    5,285
    Looks like you made more than 5 comments and they're approved so your free to post links... I watched your Google Photos video but it wasn't a noise I could hear. Can you describe the noise?
    #16 PriusCamper, Mar 5, 2026 at 2:45 PM
