Infotainment Update (Europe)
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by AndersOne, Mar 5, 2026.
  1. AndersOne
    AndersOne Active Member
    342
    199
    Europe
    2023 Prius Prime
    It seems there have been some relevant updates last year, rolled out to basically all Toyotas with similar infotainment - new ones should have it out of the box.
    Some changes:
    • Car Play doesn't cover the normal Toyota menu anymore (and has optional fullscreen mode)
    • Can silence "youre too fast beeps" via touchscreen
    • Some even more ugly 3d visualization of energy flow
    Did you get anything? In my case i didnt get a singular update OTA but my dealer said there is something (after I asked them) but then they failed to apply it during service as it takes up to 5 hours. I will go back.
    Just as heads up to anyone that never had an update - it might be possible and apparently Toyota still sucks with OTA.
    Not surprising. They cant even keep the server stable when its cold in the morning and many people suddenly want to remote heat via app.
    EDIT: Im not talking about the maps!
  2. Mendel Leisk
    41,933
    Im not sure why they persist in providing that; it’s hands-down the most distracting/pointless gimmick, and of course the default display, at least on our gen 3.
    AndersOne likes this.
  3. KMO
    KMO Senior Member
    2,012
    735
    Finland
    2023 Prius Prime
    I've got an update with the new energy flow etc, but that came when I had my head unit replaced after a map update failure.
    Do you think the update has really been done OTA for anyone?
    The speed beep touchscreen indication is there for me on that new head unit, but it only indicates state and doesn't work as a button - I was assuming that was due to lack of some update to the main dash.
  4. AndersOne
    342
    199
    Europe
    2023 Prius Prime
    I read that some people in Germany got an update OTA but given service said its 5 hours I cant imagine how that would work. (CHR got this update OTA last year too).
    As for the speed limit button, I tested that in a newer corolla and chr ( you click on it and it turns the sound off) and the newer Prius 5 have it too. Would be a bummer if the update is only as you say it. After all it needs to connect from infotainment to the main dash yeah.
    #4 AndersOne, Mar 6, 2026
  5. HamiltonPrius
    HamiltonPrius Member
    210
    99
    Parts unknown in Virginia
    2026 Prius
    I logged into my house internet today and looked for an update…..no updates available
  6. AndersOne
    342
    199
    Europe
    2023 Prius Prime
    Yours seems a little bit newer anyway but mine never had an update. In any case, OTA doesn't seem to work for some for whatever reasons. Unfortunately I have to wait one more month for my next appointment.
  7. Fenrise
    Fenrise New Member
    Poland
    2025 Prius Plug-in
    The whole "OTA Upgradability" of Toyota could be considered just a false advertising. There is just nothing and that position in the Menu to check for updates can be a fake button as well.
    My 2025 from April prodiction already has the "mute RSA by touching the speaker icon" and ugly Power Flow chart. The only update I could do are the maps, via manual download and putting on the USB drive.
    There is so much more that 12 inch display just screams to do with it, instead of plain white spaces for 1/2 of the screen. Simple more advanced statistics in the power flow screen, like how much energy you recovered during the trip and regenerative braking. Engine temperature indicator, to know when you can turn the heater on to save the heat generated from the battery. Or just "split your mid to 3 sections you want to see, (like map, power flow, Tyre pressure, as example) The 7 inch head up screen also is painfully simplified and with tons of wasted, blank space. I know that not everyone need gimmicks and fancy graphics, but some basic customisation is a standard nowadays. Just like new CH-R where it's 12 inch Digital Cockpit have full customisation available. The Prius and Bz4X looks totally barebone compared to others.
    Beside that, the car itself is great at its efficiency and refinement. Just that software side looks way behind compared to the others, like Ford, Kia, or even Stellantis. Do not mentioning Tesla.
  8. KMO
    KMO Senior Member
    2,012
    735
    Finland
    2023 Prius Prime
    FWIW, on that one tiny detail there, the big energy flow display does have a engine temperature indication - it's blue when cold, orange when up to temperature, and grey when not running. IIRC, it's more subtle on the new display than the original.
  9. AndersOne
    342
    199
    Europe
    2023 Prius Prime
    Good to know - these days I drive mostly in AUTO EV/HV to save some money on gasoline and was confused about the engine running or not given it was blue.
  10. KMO
    KMO Senior Member
    2,012
    735
    Finland
    2023 Prius Prime
    For just engine running or not, the "leaf car" EV light on the main dash shows that more obviously.
