If you travel long distances on the Interstate, you'll want a full size spare
Discussion in 'Fred's House of Pancakes' started by Georgina Rudkus, Feb 24, 2026.
  1. cyberpriusII
    1,157
    1,840
    Hyampom
    Mentioned this before. If you are "lucky" enough to drive a Subaru AWD, odds are you may be changing two tires.
    Manual says included compact spare may only be used on right rear wheel and for no more than 50 mph at no more than 50 miles.
    Would a full-sized spare face the same restrictions. Maybe so as tread depth would be off?
    kris
    #21 cyberpriusII, Mar 4, 2026
  2. Trollbait
    12,698
    The 50mph for 50 miles is the stated limit for all temporary spares; even applies to full size ones.
    For no limits, get a fifth wheel and set of five tires. Then do 5 wheel rotations.
  3. cyberpriusII
    1,157
    1,840
    Hyampom
    No thankyou. Have enough mouse homes around here.:eek:
  4. Mr.Vanvandenburg
    1,358
    597
    2020 Prius Prime
    It seems if say a front tire gets flat the spare has to be put on the front, then the good right rear is taken off and the flat tire from the front put on the right rear, then the spare on front is taken off and replaced by the good rear tire, then finally the right rear flat tire can be swapped for the spare, and all is done with the one jack the car comes with. I guess that’s what they want.
  5. Trollbait
    12,698
    Might also have to pull the AWD fuse.
  6. ETC(SS)
    7,379
    VERY least.
  7. Stevewoods
    Stevewoods Senior Member
    663
    1,206
    where I am
    Not possible on the last two or three generations of Subarus. Since 2015?
    I've had two punctures on my Generation 5(?) Outback. Both front passenger's side. Pain to swap about the tires, esp. on dirt, but it beats walking or waiting 3-4 hours for a wrecker. If the leak is not too radical, carring a 12V inflator can sometimes get you to a shop without changing tires
  8. Trollbait
    12,698
    Been carrying a plug kit since the HHR, perhaps longer. Last used with the Outback. So far, haven't had a flat that the kit couldn't fix. Since I don't travel in cell phone dead zones, I wouldn't worry much about a lack of spare if I end up with such a model.
  9. cyberpriusII
    1,157
    1,840
    Hyampom
    Thinking about Bob's advice with patch kit makes most sense.
    After all, hardly any flats (2 or3?) in nearly 20 years. Towing added to my auto insurance is only a few dollars a year. They must know something.
  10. Mendel Leisk
    41,962
    Maybe google how imperative that is? Seems a little nuts.
    I’d speculate it’s because the spare is smaller outside diameter (OD). Is that the case? It shouldn’t be: while temp spares tend to be diminutive, their OD’s stay (or should stay) close to stock tire OD.
    the owners manual should include specs for the stock an temp spare tires. If you can post these, it’d be interesting, to see how the OD’s compare.
    #30 Mendel Leisk, Mar 7, 2026
  11. Trollbait
    12,698
    The AWD system is supposedly sensitive to diameter differences. Enough that tires be replaced in sets of four. Subaru would have you disable the AWD by pulling a fuse in earlier models when using a spare.
    Semi-related, the HHR SS spare couldn't go on the front as it wouldn't fit over the brake rotors.
  12. ETC(SS)
    7,379
    I did, and it is!
    You used to be able to use a fuse to enable FWD-only but the newer Subies do not have this ability.
    That's a real shame.
    They could have at least equipped the car with a compact spare of the same diameter.
    ALL compact spares are only meant for emergency use, to limp to the nearest repair center but at least there's no threat of wrecking an "always-on Symmetrical All-Wheel Drive system" because you suffered a blow-out more than 50 miles from the nearest dealer.
    BUT WAIT!!!
    It gets crazier....According to the Googles....
    EVEN THEN?
    It seems that if the tyres are more than a quarter of the way through their service life you have to replace ALL FOUR OF THEM?
    That's too bad - especially since virtually all Subies are AWD!!
    Hard pass.
    I always replace all four at the same time anyway...unless one of them needs to be replaced sooner because of a non-repairable failure - and then I just replace THAT ONE TIRE and THEN all four of them when the remaining three are sufficiently word to require a replacement.
    o_O
  13. cyberpriusII
    1,157
    1,840
    Hyampom
    Yes, replace all four, never only one or two or three
    K
    #33 cyberpriusII, Mar 7, 2026
  14. bwilson4web
    16,391
    Another approach:
  15. ETC(SS)
    7,379
  16. Mendel Leisk
    41,962
    Around 14 min they add a compact spare, manage to get it under the hatch floor. The usual cobble?
    ETC(SS) likes this.
  17. ETC(SS)
    7,379
    Thanks.
