Does my 2008 Cylinder #1 look OK?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DavidinNevils, Mar 7, 2026 at 6:27 PM.
  1. DavidinNevils
    DavidinNevils Junior Member
    26
    Georgia
    I'm not sure what to make of these borescope images.
    Does the cylinder look damaged or OK, please?
    Thanks!
  2. Hayslayer
    Hayslayer Active Member
    457
    264
    Crosshatch is still there, like most. The small vertical lines don't look significant. Why is there moisture (water/coolant?) in the cylinder?
    Is that the right sparkplug or is that a gen 3 plug you're using, it looks like an SC16HR11?
    Gen 2 Denso should be an SK16R11
    I hope like crazy you're not using that gen 3 plug in your gen 2. Holy F.
    SK16R11 gen 2 thread is 14mm and reach is 19mm
    SC16HR11 thread is 12mm and reach is 26.5mm
    #2 Hayslayer, Mar 7, 2026 at 6:44 PM
  3. DavidinNevils
    26
    Georgia
    Sorry, I'm fussing with two of our 3 Prius's and posted this in the wrong sub-group with the wrong title.
    These pics are from our Gen 3 - 2012.
