Just need to vent...
Discussion in 'Fred's House of Pancakes' started by Mendel Leisk, Jul 6, 2022.
  1. bisco
    52,335
    no, but if I did, I'd see a doctor. :eek:
  2. rjparker
    10,437
    6,545
    The problem is corrosion inside the chrome cap of a 2 piece lug nut. Probably caused by salt on the roads.
    Replace with 1 piece lug nuts and it won't happen again.
    #3342 rjparker, Mar 7, 2026 at 9:40 PM
    Merkey, Trollbait and Isaac Zachary like this.
  3. Stevewoods
    Stevewoods Senior Member
    663
    1,199
    Seattle, WA
    Lugnuts swelling...
    When I had the mumps. So do not need a vaxx
    Isaac Zachary likes this.
  4. Isaac Zachary
    Isaac Zachary Senior Member
    2,671
    1,380
    Thanks! I'll have to look into those. I got my second set from a Toyota dealer, hence why it happened again I assume.
  5. ColoradoBoo
    ColoradoBoo Senior Member
    1,266
    874
    Monument, Colorado USA
    I assume you have a torque wrench for those lug nuts? (80 ft/lbsi is pretty standard for Toyota sedans...100 ft/lbs for the bigger SUVs and Trucks.)
    futurist likes this.
  6. ChapmanF
    18,486
    The 'again' has me wondering: were these Toyota lug nuts? Did you have Toyota lug nuts before the prior replacement? Was the prior replacement for swelling, or some other reason?
    I've experienced lug nuts swelling, but I think more of my experience of that sort has been with cheaper aftermarket ones. I don't think I've run into it with the ones from Toyota.
    #3346 ChapmanF, Mar 8, 2026 at 5:14 PM
  7. mikefocke
    4,039
    1,834
    Sanford, NC
    Massive respect for those that land on the 'farms. During a spring Middies cruise I was in the O-club one night with a bunch of young pilots who were going out for their carrier quals the next day. Watched as one didn't make it on takeoff. Not a pretty feeling.
    Watching their practice landings at Pensacola on solid ground is so much different than on board even in relatively calm seas.
