Replaced hybrid battery 7/2025. Big red triangle today.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Nanorama, Mar 7, 2026 at 12:06 PM.
  1. Nanorama
    Nanorama Junior Member
    Washington dc
    Hello there-Wise Prius owners,
    Whether or not it was a good idea, last July I replaced the original hybrid battery in my 2005 Prius sedan because we only had 150,000 mi on the clock. Subsequent to that replacement, we had an incident of red triangle that turned out to be a loose wire connection to the new hybrid. We also replaced the regular battery in September. This morning I got into the car and got the red triangle of death. It's the weekend so there's nobody to call. If anybody can give me a hint what the red triangle might indicate, I would appreciate any insight! And if anybody has had repeated issues of red triangle and has thoughts about whether I should continue to throw money at a 21-year-old car, let me know. Thanks!
  2. JC91006
    JC91006 Senior Member
    16,825
    8,600
    The red triangle can be anything, you can go to a local Auto supply (autozone or O'reilly) and they should be able to scan it for free. You should first check the oil level, make sure that's good.
    If you've replaced the batteries with new batteries, that should not be an issue.
  3. dolj
    dolj Senior Member
    8,547
    4,341
    Wellington, New Zealand
    ... and in relation to the big hybrid vehicle (HV) battery in behind the rear seat, we mean a factory brand new battery supplied by Toyota, not a new to you recondition/remanufactured/rebuilt/re-anything battery. The latter are a crap-shoot; the former is the most reliable option.
  4. Mendel Leisk
    41,855
    Did it start normally, engine ran, or just at a standstill with the warning?
    Do you have a digital multimeter? If so you can get some idea of the 12 volt battery’s condition,
    how’s the hybrid battery’s state-of-charge indicator behaving, about the usual, or?
    notice any changes in the car’s performance/sound, or how easy it goes into electric-only propulsion?
  5. Brian1954
    Brian1954 Senior Member
    2,387
    959
    South Central PA, USA
    The red triangle (master warning light) means there is a problem with the hybrid drive system. So it could be a lot of things, like the hybrid battery, brake system, inverter assembly, electric drive motors, etc.
    You need to read the trouble codes to determine the problem.
  6. bisco
    52,341
    I would not throw any more money at a 21 year old car
  7. JC91006
    16,825
    8,600
    I would throw some cheap parts at it though. Since the car has a new Hybrid battery and I'm sure that wasn't cheap
  8. bisco
    52,341
    if you can diy it, absolutely
  9. ChapmanF
    18,489
    Reading the trouble codes really is the key. The red triangle comes on for around 200 different reasons, and that's too many possibilities to get very far by guessing "I wonder if it could be this?".
    Not all scan tools can read the Prius hybrid system codes. If you go to a place like Autozone and they put their scan tool on and tell you there aren't any codes (and yet the triangle is lit), then you just need to someplace with a better scan tool and find out what the trouble codes are. (Don't just add to the many threads where that happened to somebody and they come here and post "I have the triangle lit and no codes".)
    There's a fun thread around here from some time recently where somebody wanted to argue with my 200-possibilities figure for reasons that light comes on. They thought I was exaggerating.
