P0A40 P0A41 2005 no start after rain
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Perfxctpisces, Mar 8, 2026.
  1. Perfxctpisces
    Perfxctpisces New Member
    Chicago
    Car was driving fine until I went through some slightly flooded streets, when it was time to park I had the “transmission p lock mechanism is abnormal” message so I put my parking brake on. Came back out 2 hours later and car wouldn’t ready up with red triangle of death on dash. Thought it was from my old 12v so I got that changed but still no ready up. FIXD scanner is showing P0A40 and P0A41. Also some side info my splash guard is gone I literally just lost it a few weeks ago and didn’t get around to changing it.
    52,803
    The water caused a short in the resolver system.
    Unfortunately, the only solution is close inspection of all the wiring, plugs and ecu.
    Try drying everything out thoroughly
  3. Perfxctpisces
    Chicago
    Thanks so much!
