What's Causing This??? Another P0301!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Hybrid Hobo, Mar 8, 2026.
  1. Hybrid Hobo
    Hybrid Hobo Member
    217
    55
    New Jersey
    Something is VERY wrong with my Prius.
    Many of you will remember my post about 8 weeks back: Check engine light came on, extremely rough idle, machine gun noise & violent car shaking when running the climate control, etc.
    My OBD gave a P0301. Turns out that one of the spark plugs was fouled, so I changed them. Again, that was 8 weeks ago.
    Prior to that event, approximately 8 weeks before, I had the EXACT problem, and my mechanic swapped the plugs.
    Today, it seems to have happened again while driving on the highway. Check engine came on, and the OBD says P0301.
    This is the THIRD time that I'm dealing with this within 6 months. There is NO way that 3 sets of spark plugs can go bad in that time on their own. So...
    There must be a bigger issue/root cause here.
    I'm noticing a common theme: this problem usually seems to happen while driving up (or shortly after) very steep hills on the highway for longer than 10 minutes or so. I never have any issues on flat roadways. 2 of the last 3 occurrences were WHILE driving up very steep highway terrain for 10-45 minutes.
    Additionally, the car feels VERY sluggish when going up large inclines, and the engine RPM's are on the louder side. Not roaring in volume by any stretch, but it seems that the engine is working overkill to make it up high inclines.
    What do you think the culprit is?
    I am reluctant to pay to change the spark plugs again as I'll probably encounter this again soon enough. I need to invest that money in fixing whatever the root cause is.
    P.S. - I have been RELIGIOUSLY checking my oil every few days. It doesn't seem to be burning/leaking much - if anything at all IMO. I topped it off yesterday before this event happened today. Which is on top of changing the oil filter itself about 3 or 4 months ago.
    P.P.S. - While the only code on the OBD is the P0301 (like previous times), the EVAP icon is also blinking, which I don't recall happening the prior times...unless my memory is off.
  2. rjparker
    11,103
    6,967
    Sounds like a lot of oil burn in that cylinder. Might try a leakdown test.
    High vacuum or rpms can pull more oil through a ring/cylinder problem or a valve seal. A leakdown test can tell which one.
    I would also swap coils 1 and 2 on the off chance a coil was weak. Just because its easy.
    One thing for sure you don't want to drive it with a constant misfire. Buy one iridium plug for cylinder 1.
  3. PriusCamper
    PriusCamper Senior Member
    13,463
    5,431
    Pacific Northwest, USA
    You gotta start making plans for what you're going to do when this car is going to be too expensive to keep repairing!
    Your hybrid battery is deteriorating and making the engine work harder. You've ignored my advice for years about leaving your car running all night every night to run the heater or AC depending on the time of year and we already talked about how carbon buildup can foul engines that are left idling for too long.
    To be clear, your car camping needs are more than your car is able to provide and fouled plugs every 6 weeks and now 8 weeks is a problem that's going to cost you all the money you've been able to save by living in your car. Get ahead of this problem before it gets more out of control.
    A new Sodium-Ion battery would massively reduce the amount of time your engine would turn on and off everynight and then you could use that battery pack on the next Prius you buy when the innevitable engine failure arrives.
    #3 PriusCamper, Mar 8, 2026
    Hybrid Hobo likes this.
  4. Hybrid Hobo
    Hybrid Hobo Member
    217
    55
    New Jersey
    Thanks, RJ. I don't know about any of the things you mentioned aside from the coil packs. But they might be good leads to investigate.
    Since I'm at a rest stop for the night, figured I'd check my oil again, even though I topped it up yesterday. It doesn't appear to have gone done at all...not even a smidgen.
    I really don't think I have an oil burning/leaking issue, or at least not a moderate or major one. Levels have been pretty consistent over the last few weeks, and it seems to use a regular amount.
    The bigger culprit is what's causing the misfires and the P0301 codes. And again, it has to be tied to struggling with larger inclines, because this matter keeps happening after traversing very steep, mountainous terrain for longer than a few minutes. Or, it's the coincidence of the century, which I don't think is the case.
  5. Hybrid Hobo
    Hybrid Hobo Member
    217
    55
    New Jersey
    I hear you loud & clear, brother. I'm just trying to do the best I can with what I have...which ain't much.
    You've been an encyclopedia of knowledge thus far on all things Prius, but are you certain when you say that "the battery is deteriorating and making the engine work harder?"
    I don't doubt you for a second. However, I need to hone in on the IMMEDIATE, specific issue currently at hand to see if it's worth repairing.
    As I mentioned prior, I'm close getting a truck & a camper, but I'm trying not to buy anything fast until I find something that fits my needs. I'm another 3 or 4 months away. Of course...
    If I'm staring at a $1,500 to $2,000 repair bill for this, I may very well have to make rush purchases...which usually don't end well.
  6. BiomedO1
    4,598
    2,412
    Left Coast
    I answered that question 8 weeks ago, when you first asked. Have you done anything to control the oil burn issue? Your just going to oil foul the next set of spark plugs you install in another 8+ weeks down the road; unless you address your oil burn issue. Did you switch to the thinner 0w30? That might explain some of this.
    This coupled with low power is more than likely your engine is worn-out. A good mechanic, with the proper diagnostic tools can tell you for sure - NOT a mobile mechanic. Most of those that I've meet, can barely turn a wrench without breaking something else. Don't get me wrong; most of them can "rubber-band" something together to get your back home - but not an in-depth fix.
    Unless you take care of the underlying problem; your just going to continue to have issues.
    #6 BiomedO1, Mar 8, 2026
  7. PriusCamper
    13,463
    5,431
    hybridautomotive.com has a FAQ page to explain to you how to restore battery capacity through deep cycling and someone on here can probably loan you the gear.
    If I were in your situation I'd put more plugs in and find a place to stay for a week and get it cleaned up and sell it while it still functions and that way the cost of a truck with a camper shell won't be as much.
    If someone else owned your Prius and didn't run the car all night every night the vehicle will have a much longer lifespan.
  8. rjparker
    11,103
    6,967
    Unlike Priuscamper, I am not here to sell you anything and make a commission. Neither is Biomed.
    Two quarts in 7 weeks is major. More so if most of it is going through cylinder 1.
    A good engine should burn NO observable oil in 7 weeks, ever.
    However a leakdown test might tell you its a valve seal. That is reasonably easy for a good mechanic to fix. Parts are cheap, labor might be a couple of hours.
    If the leakdown test said piston rings then its engine time, replace vehicle or don't run it hardly at all except to actually go somewhere.
    Even then I would get a harbor freight ratchet, extension and spark plug wrench and change that plug myself every 6 to 8 weeks. The plug is cheap.
    Luckily its warming up and with a new spark plug it keeps running.
    Believe me, this is bad when it happens. The damper between the engine and the transaxle is ready to fall apart and its an engine out repair. Don't run it like this!
    It could be a $20 fix if you did it each time. Stopping the oil fouling or getting rid of the car is the long term solution.
    #8 rjparker, Mar 8, 2026
    xw20_driver likes this.
  9. PriusCamper
    13,463
    5,431
    I just watched Hybrid Hobo's youtube video about all this... He hasn't been seen on PriusChat since Sunday... I'm sure things aren't going well based on this thread and him not being on here with an update in past few days. This is especially difficult because his home is his vehicle.
    Do we got anyone in the New Jersey area who can help him out?
    View his video here:
    Car Camping Dude - YouTube
    #9 PriusCamper, Mar 11, 2026
  10. rjparker
    11,103
    6,967
    It would be better to stop trying to sell him a hybrid battery when clearly he has a severe plug fouling issue.
    My guess is cylinder 1 has a severe piston ring oil control problem or an equally severe valve seal problem. His mobile mechanic got it running a couple months ago with new spark plugs (again). A leakdown test is perfect for this situation. With constant high vacuum operation while camping, a relatively simple valve seal might be it.
    BiomedO1 likes this.
