Dreaded P0A80 Code - Car Running / Charging Good.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriuSocal, Jan 25, 2026.
  1. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
    On the car currently? or when I did what you quoted?
  2. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
    Here is the info that specifically says enter INSPECTION mode for the Universal Trip.
    P0A80 Confirmation Drive Steps for 2015 Prius
    To clear the P0A80 diagnostic trouble code (DTC) in a 2015 Toyota Prius, follow these universal trip steps carefully:
    Preparation
    • Connect Techstream: Attach the Techstream diagnostic tool to the vehicle's DLC3 port.
    • Power On: Turn the power switch to the "IG" position and turn on the Techstream.
    Clearing DTCs
    1. Clear DTCs: Use the Techstream to clear any stored DTCs, even if none are present.
    2. Power Off: Turn the power switch off.
    3. Power On (READY): Turn the power switch back on to the "READY" position and turn on the Techstream again.
    Universal Trip Procedure
    1. Enter Inspection Mode: Start the engine with the power switch in the "IG" position to enable inspection mode.
    2. Idle the Engine: Let the engine idle for at least 30 seconds.
    3. Drive the Vehicle:
      • Drive at a speed of 25 mph or more for a total of at least 5 minutes.
    4. Wait: After driving, allow 10 minutes to pass before turning off the engine.
    Final Check
    • Check DTCs Again: After completing the universal trip, use the Techstream to check if the permanent DTCs, including P0A80, have been cleared.
    Following these steps should help in successfully clearing the P0A80 code. If the code persists, further diagnosis may be needed to address underlying issues with the hybrid battery system.
    So, am I missing something and can this be once and for all accurately confirm which it is? I read DO NOT DRIVE vehicle in inspection mode as it can cause damage to the transaxle and above it clearly says to enter Inspection mode and DRIVE the car…..? I read Maintenance and Inspection mode are the same thing and in order to put vehicle in such mode the dance has to be performed so it is very confusing.
    If anyone has ACTUALLY DONE this and can by experience chime in rather than providing links or written instructions it would be much appreciated because the written instructions arent very clear and contradicting.
    #102 PriuSocal, Mar 9, 2026 at 5:25 PM
  3. rjparker
    10,451
    6,554
    This confirmation driving pattern is intended to clear permanent codes.
    It also verifies your hv battery is now good.
    Toyota often makes you do steps that seem useless and normally would not be done as a way to verify you really want to do a procedure.
    They program the ecus to respond to sequences like this using their scanner, Techstream. Which is why paying a dealership to do it might make sense.
  4. ChapmanF
    18,491
    Sometimes the manual says to do something in inspection mode. When it says that, you do that, just proceed carefully.
    Gen 1 and gen 2 had just a single inspection mode, which would keep the engine running, and disable traction control. There were warnings against driving that way, because traction control protects the transmission from damage in some loss-of-traction situations, so in inspection mode, you're not protected from those situations. So avoid any kind of driving likely to involve a loss-of-traction situation.
    Gen 3 split the single inspection mode into two, "maintenance mode" and "certification mode" (in Techstream, they appear as "inspection mode - 2wd for measuring exhaust gas" and "inspection mode - 2wd for cutting TRC", respectively; their non-Techstream dances involve different numbers of go-pedal pumps).
    I used to think it was a clean separation, like the first mode had the engine effects and not the traction effect, and vice versa for the second mode. But another spot in the manual says the first mode still has both effects, while the second mode only disables TRC.
    So even if you use the first mode you still have to drive sanely while the mode is active.
  5. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
    I appreciate the info above but I feel its redundant to whats been said in the last 6 pages of this thread and we are dancing around an actual clear answer. By all means I appreciate the chime but what im looking for at this point isnt explanations of what does what but what to actually do for this universal trip. I am getting from @ChapmanF that it would be ok to drive the vehicle in inspection mode like its saying has to be done and instructions against it are for theoretical legal reasons and toyota to save their arse.
    Also, the last procedure doesnt mention the park put in neutral and wait for HV SOC to drop to 30%.
    This is what I am ready to do… Please chime in if any part of this is NOT correct, as after all the inconsistencies is what I understand:
    1. Connect my scanner to the vehicle
    2. Power On: Turn the power switch to the "IG” position
    3. Perform a force clear on the scanner even though NO current codes exist nor is CEL on.
    4. Power Off: Turn the power switch off.
    5. Power On (READY): Turn the power switch back on to the "READY” position
    6. Put vehicle into inspection mode by performing dance procedure (brake twice, neutral, brake twice yadda yadda)
    7. Let vehicle idle for at least 30 secs
    8. Drive at a speed of 25 mph or more for a total of at least 5 minutes.
    9. Stop and with the select lever in N, leave the vehicle until SOC drops to 30%.
    10 Once it hits that number, check for codes and see if the permanent code is gone.
    (Universal trip consists of steps 6-8)
  6. ChapmanF
    18,491
    Right, that's because that isn't part of a Universal Trip, it's just part of the confirmation driving pattern for P0A80.
    Most codes' confirmation driving patterns are something like "do some stuff, do a Universal Trip, do some other stuff". For P0A80, the other stuff involves deep-discharging the battery, so the ECU can watch how it performs.
  7. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
    Understood….so drivre in inspection mode or no???? LMAO
    The part where right before the universal trip requires the car to be on but next step staing perform an universal trip requires the car to be off to put into inspection mode THIS IS BEYOND FRUSTRATING that no CLEAR CONCISE answers are available.
  8. Brian1954
    Brian1954 Senior Member
    2,387
    959
    South Central PA, USA
    Just follow the procedure that you included in your post #95. That procedure came from the Toyota service manual, not from some other website that you found when you did a search.
  9. ChapmanF
    18,491
    I think PriusSocal is noticing the way that procedure has a step 5 that says to turn the car on (READY) and turn on Techstream, followed by a step 6 that is a Universal Trip (whose own sequence of steps starts with the car not READY, so inspection mode can be selected).
    That seems a bit like something that got by the editors of the repair manual, and I think I would approach it by kind of blurring the two steps together, so 5 is "make the car READY in inspection mode", and 6 is "do the rest of a Universal Trip". :)
    By the way, I have noticed if I drop a comment in the form when I am signed in to TIS, people really do get back to me and fix goofs in the manual. I'm not signed into TIS right now, just looking at an old download. But if somebody else is reading and has signed in to TIS, they could check if the current online copy still has that rough edge and, if so, drop a comment on it.
    Of course, checking online could reveal that it was already commented on and fixed years ago, and we're just still looking at our old downloads and going ¿o_O?.
    PriuSocal likes this.
  10. Mendel Leisk
    41,855
    If it’s a quite a spread, both I guess.
  11. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
    EXACTLY LOL.
    Anyhow, I did the steps and did NOT put the car in inspection mode due to that specific contradiction IMO. It did NOT remove the permanent code. I did 25mph for 7 mins and stopped the car til SOC got to 30 and checked codes and permanent was still there. BTW, bluedriver did give me the option to clear codes even of there was no active ones. I may try this again but this time driving the 5 min at 25 mph under inspection/maintenance mode and see if thats the way.
    I also checked all 14 modules and all were reading near identical values while car was on at 16.47 +/- .20 and I really do not know what else to look at as the battery appears to be working correctly and none of my scanners (autel ap200, blue driver, icon t10) give me a sub code. If the second try under inspection mode doesnt remove the code, the next thing is going into the battery and checking the HV battery ECU connectors for corrosion and the bus bars for same. Pretty stressed about this as I cannot get my tags since it will not pass smog with the permanent code. And, now the count is back down to 2 warm up cycles and 24 miles :/
    BTW, I had contacted Hybrid Pit as someone here suggested for help and they didnt even know that a confirmation drive / universal trip was. So i left it at that lol.
