Short-term storage
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jayloc, Mar 8, 2026.
  1. Jayloc
    Jayloc New Member
    Greenville,sc
    So I have a 2013 prius that I'm currently not driving as a daily driver anymore. I may drive it a few times out the month,around 250 miles or so.my question is would it be ok to drive it once a week for about 20-30 min in order to maintain the hybrid battery via the inverter, and maybe start it up in park in ready mode letting it run for the 1min or so till it automatically shuts off,during the middle of the 1 week?
    52,515
    That would be fine, but you should put a maintainer on the 12 volt, or disconnect the negative cable
    BiomedO1 likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,180
    5,333
    Pacific Northwest, USA
    You can buy a charger to keep the hybrid battery pack fully charged and balanced... Or you could switch to lithium or sodium chemistry that doesn't have the self discharge problem that NiMH cells have in OEM pack.
    But given the engine problems that Gen3 Prius have, you're probably better off selling it while its still in good condition and buy an old truck that doesn't have these hassles and has more uses as a rarely driven vehicle. It's just a matter of time before everyone will be more aware of Gen3 engine failure problems and the re-sale value of the Gen3 prius will fall in big ways.
  4. BiomedO1
    4,323
    2,270
    Left Coast
    If your driving it a few times a month and about 250 miles - IMHO, should be enough exercise for it.
    1. put an automatic battery maintainer/RV battery charger on the 12V
    2. I would probably do some sort of mouse deterrent strategy for the car - so they won't chew on the wires and turn it into a mouse house.
    Good Luck...
    Brian1954 likes this.
  5. Jayloc
    Jayloc New Member
    Greenville,sc
    Thank you so much for the advice.
  6. ETC(SS)
    7,388
    250 miles a month is 3,000 miles a year.
    For some people that's 'normal use.'
    You're worried about the Traction (hybrid) battery but Priuses have really poor 12v batteries, so that's probably where I would focus my attentions.
    I'm presuming that you've read all the threads and know all the things about the head gasket issues - so be sure and keep an eye on your coolant.
    Your car is 13 years old and anyone with kids knows that's when they start acting out....;)
  7. Jayloc
    Jayloc New Member
    Greenville,sc
    Thanks for the advice.
  8. Jayloc
    Jayloc New Member
    Greenville,sc
    Thank you for your insight and advice.
  9. Mendel Leisk
    42,032
    From page 30 of the North American Owner's Manual:
    "Several months" is a little vague, say three?
    As mentioned, the 12 volt battery is the more immediate concern. Do you have 120 volt AC outlets convenient to the car where it's parked? If so, a smart charger, near-constantly connected, would be my tactic. Owner's Manual recommends to keep it no more than 4 amp rating, IIRC, 4~5 amps would likely be fine. Manual also says to remove battery from car before charging, which I never do.
  10. Jayloc
    Jayloc New Member
    Greenville,sc
    Good advice, thank you so much
  11. rjparker
    10,648
    6,679
    Normal driving "a few times out [of] the month, around 250 miles" is plenty for the hybrid battery.
    Running it only in Park for a minute or two without a full warmup is actually a bad idea. Just drive it as you do now.
    #11 rjparker, Mar 11, 2026
  12. rjparker
    10,648
    6,679
    ...dup
    #12 rjparker, Mar 11, 2026
