replace 2023 Prius Prime with new Rav 4 Prime - blasphemy?
Discussion in 'Gen 5 Prius Main Forum' started by GeoJ, Mar 9, 2026.
  1. GeoJ
    GeoJ Active Member
    218
    198
    United States
    2023 Prius Prime
    XSE
    This idea is half-baked, early, that is. I have a 2023 Prius Prime XSE with 33k miles on it. I like the car but it does have drawbacks, such as the tire options, the visibility, no spare tire (and limited place to keep one), and somewhat difficult to get into because of roofline (not really a big issue for me). I drive in snow country, and now in spring on dirt roads in mud country, and some in my family have concerns that this car is not the right car for those conditions. I am typically someone who buys a car and drives it until it dies.
    What I like about the car is the way it drives, smaller size, great mph and especially that I can do most of my daily driving on the EV with easy plug in to household outlet, yet still have gas engine for weekend longer trips. And I like the way it looks.
    So, my crazy half-baked idea is to replace it now with a Rav 4 Prime. Just starting to think about it, and not sure this is the right forum for inputs, but, any thoughts welcome!!
    #1 GeoJ, Mar 9, 2026
    Prodigyplace, bisco and Gokhan like this.
  2. Gokhan
    Gokhan Senior Member
    6,560
    2,617
    Paramount CA
    It depends on what you want. The Gen 6 RAV4 PHEV is an upgrade over the Gen 5 Prius PHEV, featuring TSS 4.0 and software-defined vehicle (SDV) capabilities. The software-defined multimedia system and gauge display will be much better, addressing the drawbacks of the Gen 5 Prius, and it even includes a built-in dashcam.
    The mpg/mpge will be about 10% lower than your 19-inch-wheel Prius PHEV, which isn't too bad considering it is a larger vehicle with more cargo space.
    It also depends on your budget, but I guess it won’t cost you much with your trade-in.
    #2 Gokhan, Mar 9, 2026
    GeoJ likes this.
  3. Winston Smith
    Winston Smith Active Member
    410
    286
    OH
    2024 Prius
    LE AWD-e
    I think about a Corolla Cross or Rav4 every time I grunt my way into or out of my Prius. I've never been in a Rav4, but I liked the Corolla Cross quite a bit.
    If getting around in mud and neglected roads is your concern, does weight matter? If I understand this correctly, the plug-in Rav4 is a porker. I don't doubt that the Rav4 Prime with AWD might be better when it gets slippery and has about the same footprint as your Prius.
    As I use cars, I can only take on one passenger in a Prius, it has poor visibility and an adequate trunk. A Rav4 would be more practical, but I wouldn't care to drive an SUV.
    bisco and GeoJ like this.
  4. bisco
    52,417
    I have never had either, but I do believe you need the right tool for the right job.
    I can commiserate on access and egress, Because I have the same problem with our hycam, and am also researching rav4 prime.
    All the best with your search!
    GeoJ likes this.
  5. PriusCamper
    PriusCamper Senior Member
    13,102
    5,310
    Pacific Northwest, USA
    So begins the posts about people giving up their Gen5 for something better... Wonder how many we'll see in coming years? As for switching to Rav 4 Prime... Seems like you'll have to wait month or years to find one availble to buy based on how Toyota is doing distribution of them these days.
  6. Prodigyplace
    12,687
    11,833
    Central Virginia
    If buying new, I assume you mean a RAV4 Plug In PHEV. They retired the Prime labeling.
    My son traded his 2015 Prius V for a 2023 RAV4 Prime XSE. He briefly looked at the Corolla Cross and kept looking. He transports his small dogs to dog agility events. He is able to to his regular commute on EV but has absolutely no range anxiety because of the Hybrid function. I believe on the RAV4 the battery is under the passenger compartment and liquid cooled.
    If you can love without the plug, a Camry may be a good option. I like my 2025 Camry XLE that replaced my totalled 2017 Prius. Since 2025 model year, all Camrys are Gen 5 Hybrid. There is no ICE-only model.
    GeoJ likes this.
  7. mingc
    mingc Member
    83
    60
    Portland, OR
    2023 Prius
    XLE AWD-e
    I really like my 5th Gen but I tend to agree with those concerns. The 5th Gen is a small car built for the urban environment, not muddy dirt roads that may not get snowplowed in the winter.
    GeoJ likes this.
  8. rjparker
    10,579
    6,635
    The new Rav4 Plugin handles great, is very quiet and has acoustic glass, is very fast and is sure footed. The ride is smooth and interior space is excellent. I would take it in a heartbeat over the Prius equivalent.
    Prodigyplace and GeoJ like this.
  9. martaorplq
    martaorplq New Member
    Poland
    2017 Prius v wagon
    It’s not a crazy idea at all, especially given the conditions you’re driving in. The Prius Prime is great for efficiency and daily EV driving, but the low clearance, limited tire options, and lack of a spare can be real downsides on snow and muddy dirt roads. The RAV4 Prime would keep many of the things you like: plug-in capability, strong efficiency, and a gas engine for longer trips. You’d also gain AWD, more ground clearance, better visibility, and generally more practical space. The tradeoff is that it’s bigger, less efficient, and likely more expensive. If your environment is rougher year-round, the switch could make daily life a lot easier.
    GeoJ likes this.
  10. GeoJ
    GeoJ Active Member
    218
    198
    United States
    2023 Prius Prime
    XSE
    Thanks. These response are making me think I should test drive the Rav4 Plugin (not Prime!). And then see if they are truly that hard to find. I have to replace tires on my Prius within the next 6 months and if I do this swap should probably not buy new tires, instead should do the swap. I am not a SUV fan but also think drivability of a small SUV like this will have better handling and is not the same as some huge gas guzzling SUV.
  11. Winston Smith
    410
    286
    OH
    2024 Prius
    LE AWD-e
    You might want to have a look at the lateral acceleration numbers for the two cars. Despite the oddly skinny tires, the Prius is at .79 (Motortrend) and .84 (C&D) while the Rav4 is at .79 and .80 respectively.
    Reviews online typically note that handling isn't great in a Rav4.
    Have any of them gotten stuck in the last couple of winters?
    You don't appear to mind buying a car in its first model year. Some people would have an objection to buying any 2026 Rav4 on the principle that Toyota will learn what it did wrong and might apply a fix in the 2027 model year.
  12. GeoJ
    GeoJ Active Member
    218
    198
    United States
    2023 Prius Prime
    XSE
    Good points. I only purchased the first year model of the new Prius because I ended up in crisis mode, no car and thought the new Prius was my best option (it was). I don't typically like buying a car in first model year, and maybe can wait on Rav4 until 2027 come out. As for handling, I will test drive it, and hope it is not too bad. Won't be as good as my Gen 5 Prius, I would guess, but might be ok. Never actually been stuck in my Prius!
  13. Winston Smith
    410
    286
    OH
    2024 Prius
    LE AWD-e
    Ideally, a new car is a solution. I've noticed that it can be a solution for:
    1. a problem I have and should address,
    2. a problem I think I will encounter, but never do, or
    3. a problem I concoct in order to buy it because I want it.
    If none of us ever used #3, few of us would be driving what we drive. #2 may be responsible for most Jeeps and sportscars.
    PrimeDan likes this.
  14. notspam3
    notspam3 Member
    97
    53
    Toronto
    2024 Prius Prime
    XSE Premium
    If the RAV4 floats your boat then go for it.
    I always check with my insurance to get a quote on rates before I make a final decision. Last time we ended up buying a CRV because the insurance was $400/yr cheaper than the RAV4. From what I've seen the RAV4 PHEV gives you a tow rating if that's important to you. The Prius PHEV is just a commuter vehicle.
    douglasjre likes this.
  15. Mendel Leisk
    41,947
    To me the obvious blasphemy (and so far apparently not addressed, judging from a quick skim) is that it seems economically foolhardy, cashing in a 2023 model year so soon. Seems to be the rage though. :whistle:
  16. rjparker
    10,579
    6,635
    You can't look at this from a retired person's standpoint who wants to keep a 2010 until they are gone.
    The 2026 Rav4s and especially the Plugin is more of a refresh than a new model. Same engine, size, drivetrain tweeked for a couple of horsepower, a better integrated mfd and Lexus like soundproofing including acoustic glass.
    The Plugin's battery weight creates a low center of gravity in an awd vehicle.
    Given recent Toyota hybrids are really holding their value, trading up is not a big deal. With a high value tradein you get a significant sales tax reduction on the new car as well.
    Gokhan likes this.
  17. Gokhan
    6,560
    2,617
    Paramount CA
    A ton of new RAV4 PHEVs will arrive by the end of May.
  18. Gokhan
    6,560
    2,617
    Paramount CA
    Blasphemy, rage, really? Many people lease rather than purchase to get the newest cars every two years or so.
  19. Mendel Leisk
    41,947
    I’d think from most any perspective a 3 year turnaround is pretty brief.
  20. Gokhan
    6,560
    2,617
    Paramount CA
    Toyota is always conservative when doing redesigns. The Gen 4 and Gen 5 Priuses are practically the same car as well.
    The Gen 6 RAV4 PHEV system is a redesign. It gets much better fuel economy than the Gen 5 PHEV system.
    All-new Toyota Gen 6 PHEV system | PriusChat
    And the multimedia system is also a complete overhaul.
    With the Gen 6 RAV4, Toyota modernizes its obsolete multimedia system at last | PriusChat
    Last but not least, Gen 6 RAV4 is Toyota’s first SDV.
    So, I would say that, despite the same cover, there are many major changes inside.
