replace 2023 Prius Prime with new Rav 4 Prime - blasphemy?
Discussion in 'Gen 5 Prius Main Forum' started by GeoJ, Mar 9, 2026.
  1. GeoJ
    GeoJ Active Member
    225
    203
    United States
    I agree, it is not my usual MO, I have always driven cars into the ground. And that is partly because I have always thought it to be the most economical way of owning a car. So this would be unique for me, and probably not optimized from an economic perspective. But, it would take advantage of the value in a low miles Prius Prime. And would be done for other reasons. As I'm just starting my thinking here, I've not looked into how much it will cost.
    Lots of good food for thought in these responses, including considering waiting for the 2027 model. Or, I could try to pick up a 2026 at model year change, perhaps get some kind of a deal although I know they are infrequent in these cars.
    Gokhan and Mendel Leisk like this.
    52,785
    I wouldn’t be surprised if you got close to what you paid for the Prius
    Prodigyplace likes this.
  3. Gokhan
    Gokhan Senior Member
    6,707
    2,652
    Paramount CA
    No, if you wait, you will definitely lose money because your trade-in will depreciate. Even the outgoing 2025 RAV4 is selling for only $893 below MSRP on average. Get one at or slightly below MSRP in April or May when they first arrive.
    Toyota RAV4 Plug-in Hybrid—Build & price your new Toyota—TrueCar
  4. notspam3
    notspam3 Member
    134
    71
    Toronto
    2024 Prius Prime
    XSE Premium
    You never know, with recent inflation and new car sales lagging he might get a pretty good deal on a trade in. Used seems to be going for the price of new around here.
  5. PriusCamper
    PriusCamper Senior Member
    13,411
    5,413
    Pacific Northwest, USA
    Other option you could consider is a lift kit to raise you Prius up a couple inches.
  6. Gokhan
    6,707
    2,652
    Paramount CA
    Come on, now! :)
  7. Gokhan
    6,707
    2,652
    Paramount CA
  8. Prodigyplace
    12,710
    11,848
    Central Virginia
    You might want to look at this thread on the 2025 RAV4 Plugin. At least when they refreshed the Camry for Gen 5, many of the previous generation parts fit the newer models.
    This person bought a 2025 Camry XSE and modded it for fuel efficiency & hendling. He got bored and traded it for a 2025 RAV4 Plugin. He has been documenting his modes, what worked, and what did not.
    https://www.rav4world.com/threads/petitfrererav4s-2025-rav4-phev-maintenance-upgrades-adventures-and-more.340098/
    Gokhan likes this.
  9. PriusCamper
    13,411
    5,413
    I mean spending $5K on an air bag suspension would offer way more options for snow travel... Also mounting a plow on the front to keep the Prius from getting stuck and high centered.
  10. PriusCamper
    13,411
    5,413
    Yeah... I mean if you're a millionaire and your accountant is using depreciation to get around paying taxes its one thing. But if you don't have much money and you're depending on financing to buy a brand new car, you might as well have a bumper sticker that indicates that you're enslaved by a corrupt financial system in a way where you're always losing big money and don't actually own anything because your financial lenders not only own all your stuff, but they own you too!
    Gokhan likes this.
  11. Gokhan
    6,707
    2,652
    Paramount CA
    According to Consumer Reports’ first drive, the Gen 6 RAV4 is much improved over the Gen 5 RAV4 in virtually all respects, including power, handling, ride, noise, BEV range, software-defined multimedia with OTA updates, and more.
    The things they didn’t like were:
    1. The car did not increase in size, and the driver’s area still feels small and caged, with more legroom, headroom, and arm room desired.
    2. The interior feels plasticky and cheap for an expensive car.
    Other than those two points, the review is very good. I can’t post it because it is copyrighted.
    2026 Toyota RAV4 PHEV first-drive review—Consumer Reports
  12. PriusCamper
    13,411
    5,413
    Lol... It didn't get bigger? Seriously, how big do vehicles need to get?
  13. mva
    mva Active Member
    174
    102
    B.C. Canada
    2024 Prius Prime
    SE
    My wife and I have been considering the same idea - trading our 2024 Prius Prime in for a 2026 RAV4 plugin. The main reason is the poor visibility in our Prius. Here in Canada I would probably be buying an SE model because I don’t like the 20” wheels on the higher trims.
    Pros
    Rav4 SE has 84 km EV range versus 72 km for the Prius SE
    Rav4 can tow 3500 lbs therefore I can eventually get rid of my pickup truck.
    AWD, much more ground clearance and better visibility.
    Faster charging, much faster for higher models.
    Improved battery conditioning and cold weather EV performance according to posts above.
    Cons
    Both Electric and gasoline consumption are significantly higher in the Rav4 plugin 41 mpg combined versus 52 mpg in the Prius SE (27% more fuel on long trips).
    Rav4 battery is 22.7 kWh verses 13.7 kWh in the Prius therefore approximately 40% more electrons are needed per mile of EV travel!
    The RAV4 is still quite efficient but nothing like the Prius.
    We will be giving up many features that my SE has that are only in higher trim level in the new Rav - for example I love having the two 15 amp, 120 volt outlets.
    Gokhan likes this.
  14. GeoJ
    GeoJ Active Member
    225
    203
    United States
    Thanks. I'm liking the increase in EV mileage. Not liking plasticky feel, will check out how bad that is. No increase in size does not bother me. Also liking that the changes are incremental, not a full re-design, even though the new model seems to be thought of as better - but that makes me less concerned on buying in a "new model" year. Especially with Toyota. I will have to check out when the dealer gets these in for test drive, hopefully by late spring.
    Gokhan likes this.
  15. Prodigyplace
    12,710
    11,848
    Central Virginia
    The transaxle could very well be the same as the 2025 & 2026 Camry. I think both vehicles use the same 2.5L engine. That again means it is not quite a first year model.
  16. Mendel Leisk
    42,273
    Does the latest RAV4 Plug-In have a spare? That'd be a plus.
    Gokhan likes this.
  17. Gokhan
    6,707
    2,652
    Paramount CA
    Of course. It is a RAV4. It comes with a temporary spare.
  18. Prodigyplace
    12,710
    11,848
    Central Virginia
    I believe my son's 2023 has a spare, I know all the newer Camrys have space saver spare tires.
  19. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Weekend longer trips... like what?
    My trips up north (175 miles each way) and my trips out to my wife's parents (120 miles each way) are covered by DC fast-chargers, even before this year's NEVI funded builds. I went from a Prius Prime to a bZ4X then to a 2026 bZ. So, I know the real question comes down to what you are paying extra for to get a PHEV rather than a BEV.
    Since most of your driving is already electric miles, it begs the question how much a gas engine would really be used.
  20. Prodigyplace
    12,710
    11,848
    Central Virginia
    Since when are PHEV more expensive than BEV? That is what you are implying.
